									This does not make sense - documents needed for EPC score - Solar Photovoltaic (PV)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/</link>
            <lastBuildDate>Sun, 11 Oct 2026 21:35:23 +0000</lastBuildDate>
                        <title>RE: This does not make sense - documents needed for EPC score</title>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/4/#post-18051</link>
                        <pubDate>Tue, 04 Apr 2023 12:54:49 +0000</pubDate>
                        <description><![CDATA[@allyfish
Hi Everyone,
Rather than just discuss this problem on the forum, I would encourage you to write to your MP and ask what is being done to rectify this problem. Below is a copy of ...]]></description>
                        <content:encoded><![CDATA[<p>@allyfish</p>
<p>Hi Everyone,</p>
<p>Rather than just discuss this problem on the forum, I would encourage you to write to your MP and ask what is being done to rectify this problem. Below is a copy of the message that I sent today.</p>
<strong>Hi Andrew,</strong>
<p>
<strong>A number of forum members on the Renewable Heating Hub, of which I am a moderator, have highlighted the fact that recent EPC assessments have been lower than anticipated because they had installed an ASHP.</strong>
<p> 
<strong>One of the members posted this report, which although quite dated, was highlighting this problem approximately 8 years ago.</strong>
<p>https://www.yorkshireenergysystems.co.uk/epcandheatpumps
<p><strong>Could you please explain what, if anything, is being done to remedy this obvious problem, since the Government is trying to encourage homeowners to install energy efficient heating systems such as heat pumps. It would appear that the present EPC assessment methodology is seriously flawed, and needs urgent revision.</strong>
<p> 
<strong>Another forum member installed an Air to Water heat pump himself, and found that the cost of all the materials and equipment, along with a sufficient allowance for labour costs, produce a figure that was approximately £5000 less than the quotes from a number of installers. I strongly suspect that the BUS grant of £5000 is not actually benefiting homeowner's, but is instead going into the pockets of the installers.</strong>
<p> <strong>I can confirm the same, as approximately 2 years ago I installed an Air to Air ASHP at our home myself, which does not qualify for the BUS grant, but since the equipment and materials (excluding my labour) came to less than £1000, not getting a grant was of little consequence. My primary objective was to better utilise the excess electricity generation from our 4kW solar PV system, and in so doing reduce our overall gas consumption by something in the order of 50%. As I write this, our home is being heated completely by solar energy, which has been the case since approximately 8 am today, and will probably continue to do so until after midnight.</strong> <p> 
<strong>Even during Spring and Autumn there is a great deal of solar energy available, we human's just need to get much better at capturing and utilising it in the most efficient manner.</strong> <p>
<strong>I look forward to your reply.</strong> <p>
<strong>Regards,</strong> <p>
<strong>Derek.</strong>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/">Solar Photovoltaic (PV)</category>                        <dc:creator>Derek M</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/4/#post-18051</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/4/#post-18038</link>
                        <pubDate>Tue, 04 Apr 2023 07:01:49 +0000</pubDate>
                        <description><![CDATA[@ronin92 that&#039;s a good find, thank you. Having had a speed-read of the research paper, it seems the elephant in the room may be the simple affordability of heating houses assigned lower EPC ...]]></description>
                        <content:encoded><![CDATA[<p>@ronin92 that's a good find, thank you. Having had a speed-read of the research paper, it seems the elephant in the room may be the simple affordability of heating houses assigned lower EPC gradings E, F &amp; G. That could be a significant aspect of the predicted vs actual metered energy consumption. Chances are the thermostats are set lower in such buildings, more rooms are left unheated, and the occupants accept lower levels of thermal comfort as a price to pay for being able to manage the cost of very expensive gas and electric they consume. EPCs do not factor any of this into the SAP calculation method.</p>
<p>The EPC process is deeply flawed, and whole house permeability/leakage tests are not mandated in the survey method. That alone can be grossly under or overestimated, especially for properties more exposed to the elements. It is almost as significant a factor as the U values of the building fabric, especially for older 'draughtier' properties.</p>
<p>This matters, because domestic EPCs are a legal requirement for the sale, purchase and letting of property. Also more and more access to grant funded schemes including BUS is linked to EPC grading. The BRE domestic SAP process is deeply flawed for assessing dwellings with heat pumps: https://www.yorkshireenergysystems.co.uk/epcandheatpumps/</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/">Solar Photovoltaic (PV)</category>                        <dc:creator>AllyFish</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/4/#post-18038</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-18037</link>
                        <pubDate>Mon, 03 Apr 2023 21:28:38 +0000</pubDate>
                        <description><![CDATA[More evidence that the EPC regime is not fit for purpose
The over-prediction of energy use by EPCs in Great Britain: A comparison of EPC-modelled and metered primary energy use intensity
                        <content:encoded><![CDATA[<p>More evidence that the EPC regime is not fit for purpose</p>
<h1 id="screen-reader-main-title" class="Head u-font-gulliver u-h2 u-margin-s-ver"><span class="title-text" style="font-size: 10pt">The over-prediction of energy use by EPCs in Great Britain: A comparison of EPC-modelled and metered primary energy use intensity</span></h1>
<div id="ab015" class="abstract author">
<h2 class="section-title u-h4 u-margin-l-top u-margin-xs-bottom"><span style="font-size: 10pt">Abstract</span></h2>
<div id="as015">
<p id="sp0015">This analysis compares the difference between the Energy Performance Certificate (EPC)-modelled and smart-meter measured annual energy use on a like-for-like basis in 1,374 gas-heated British households from the Smart Energy Research Lab (SERL) Observatory. EPCs and metered energy use were converted to primary energy use intensity (PEUI) to provide a comparison of the same quantity for the first time.</p>
<p id="sp0020">We show that EPCs predict significantly more energy use than metered in homes in Great Britain. EPC bands A and B show no statistically significant difference, but all other bands show a significant gap which increases as EPC rating worsens. The PEUI gap widens from −26 kWh/yr/m<sup>2</sup> (−8%) for band C to <span style="color: #ff0000">−276 kWh/y/m<sup>2</sup> (−48%) for bands F and G</span>. Unlike previous research, we show that the difference persists in homes matching the EPC-model assumptions regarding occupancy, thermostat set-point and whole-home heating; suggesting that <span style="color: #ff0000">occupant behaviour is unlikely to fully explain the discrepancy</span>.</p>
<p id="sp0025">EPCs are a core tool in the residential energy sector, and the gap between EPC-modelled and metered energy use could have a significant impact on policy, research, and industry. Future research should investigate disaggregated components of energy use, the underlying thermal model, and assumptions regarding building characteristics.</p>
</div>
</div>
<p><a href="https://www.sciencedirect.com/science/article/pii/S0378778823002542" target="_blank" rel="noopener">Link</a></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/">Solar Photovoltaic (PV)</category>                        <dc:creator>ronin92</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-18037</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16773</link>
                        <pubDate>Thu, 23 Feb 2023 20:39:49 +0000</pubDate>
                        <description><![CDATA[😀  that&#039;s awesome!. Hot tub sounds so good😍
I will just get a big paddling pool and fill it up for the kids for free! 
Can&#039;t wait to abuse the extra power too😍]]></description>
                        <content:encoded><![CDATA[<p>😀  that's awesome!. Hot tub sounds so good😍</p>
<p>I will just get a big paddling pool and fill it up for the kids for free! </p>
<p>Can't wait to abuse the extra power too😍</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/">Solar Photovoltaic (PV)</category>                        <dc:creator>Andris</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16773</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16772</link>
                        <pubDate>Thu, 23 Feb 2023 20:35:50 +0000</pubDate>
                        <description><![CDATA[I used about 6,500kw for power in the house. However a good chunk of that is my abusing the solar in the summer running AC, a pool heater and a hot tub. So not really representative lol]]></description>
                        <content:encoded><![CDATA[<p>I used about 6,500kw for power in the house. However a good chunk of that is my abusing the solar in the summer running AC, a pool heater and a hot tub. So not really representative lol</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/">Solar Photovoltaic (PV)</category>                        <dc:creator>batalto</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16772</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16771</link>
                        <pubDate>Thu, 23 Feb 2023 20:31:12 +0000</pubDate>
                        <description><![CDATA[@batalto I see, my total of heating use is a bit of a guess as I don&#039;t have a meter. I use 10000kw total usage. Heating about 3500kw. Hot water 2500kw and 4000kw is washing drying all other ...]]></description>
                        <content:encoded><![CDATA[@batalto I see, my total of heating use is a bit of a guess as I don't have a meter. I use 10000kw total usage. Heating about 3500kw. Hot water 2500kw and 4000kw is washing drying all other electrical items.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16771</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16769</link>
                        <pubDate>Thu, 23 Feb 2023 20:22:25 +0000</pubDate>
                        <description><![CDATA[@derek-m no, that&#039;s actual heat pump use regardless of source.]]></description>
                        <content:encoded><![CDATA[<p>@derek-m no, that's actual heat pump use regardless of source.</p>
3157]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16769</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16768</link>
                        <pubDate>Thu, 23 Feb 2023 20:19:42 +0000</pubDate>
                        <description><![CDATA[@derek-m funny I was thinking the same.]]></description>
                        <content:encoded><![CDATA[@derek-m funny I was thinking the same.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16768</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16767</link>
                        <pubDate>Thu, 23 Feb 2023 20:15:20 +0000</pubDate>
                        <description><![CDATA[Did you include your solar generation in those figures?]]></description>
<p>@andris I used 7,000kw last year. Slightly bigger house 263m2, 4 people (2 young children).</p>
<p>So that's 26.6kw/m2 per annum</p>
<p>Did you include your solar generation in those figures?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16767</guid>
                        <link>https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16766</link>
                        <pubDate>Thu, 23 Feb 2023 20:11:59 +0000</pubDate>
                        <description><![CDATA[@andris I used 7,000kw last year. Slightly bigger house 263m2, 4 people (2 young children).
So that&#039;s 26.6kw/m2 per annum]]></description>
                        <content:encoded><![CDATA[<p>@andris I used 7,000kw last year. Slightly bigger house 263m2, 4 people (2 young children).</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/solar-photovoltaic-pv/this-does-not-make-sense%f0%9f%a4%94/paged/3/#post-16766</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-11 22:35:23 by W3 Total Cache
