									Removing Fireplace Gas Fitting - Safety, Regulations, Tools, Plumbing &amp; DIY Installations				            </title>
            <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/</link>
            <lastBuildDate>Tue, 14 Jul 2026 15:59:17 +0000</lastBuildDate>
                        <title>RE: Removing Fireplace Gas Fitting</title>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/#post-19773</link>
                        <pubDate>Sat, 27 May 2023 19:50:30 +0000</pubDate>
                        <description><![CDATA[A further thought if you are not removing the pipe is to fit a stop end or you will get a smell of gas.]]></description>
                        <content:encoded><![CDATA[<p>A further thought if you are not removing the pipe is to fit a stop end or you will get a smell of gas.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>Jancold</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/#post-19773</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/#post-19769</link>
                        <pubDate>Sat, 27 May 2023 08:15:58 +0000</pubDate>
                        <description><![CDATA[Hi, if you tease back the carpet there should be a flange with screws. Remove them and lift the fitting and there is a compression fitting holding the pipe. Anyway that is if it is like mine...]]></description>
<p><span style="font-size: 14pt">i have had the gas supply removed from the house and have removed the old gas fire from the living room but am left with the gas supply fitting protruding from the floor (wooden boarding) and would like to remove it flush with the floor. I cannot see any fixing screws in the two holes in the baseplate of the fitting so before I take a hacksaw to it, I thought I would enquire here in case a reader could advise please; how is this fitting held in place? I am attaching a photo of the fitting in case this helps. Regards, Toodles</span></p>
<p><span style="font-size: 14pt"> </span></p>
<p>Hi, if you tease back the carpet there should be a flange with screws. Remove them and lift the fitting and there is a compression fitting holding the pipe. Anyway that is if it is like mine! cheers</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/#post-19769</guid>
                        <title>Removing Fireplace Gas Fitting</title>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/#post-19753</link>
                        <pubDate>Thu, 25 May 2023 15:19:41 +0000</pubDate>
                        <description><![CDATA[i have had the gas supply removed from the house and have removed the old gas fire from the living room but am left with the gas supply fitting protruding from the floor (wooden boarding) an...]]></description>
                        <content:encoded><![CDATA[<p><span style="font-size: 14pt">i have had the gas supply removed from the house and have removed the old gas fire from the living room but am left with the gas supply fitting protruding from the floor (wooden boarding) and would like to remove it flush with the floor. I cannot see any fixing screws in the two holes in the baseplate of the fitting so before I take a hacksaw to it, I thought I would enquire here in case a reader could advise please; how is this fitting held in place? I am attaching a photo of the fitting in case this helps. Regards, Toodles</span></p>
3982
<p><span style="font-size: 14pt"> </span></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/removing-fireplace-gas-fitting/#post-19753</guid>
Served from: renewableheatinghub.co.uk @ 2026-07-14 16:59:17 by W3 Total Cache
