									How Poor Water Quality Can Destroy Your Circulation Pump - Safety, Regulations, Tools, Plumbing &amp; DIY Installations				            </title>
            <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:25:47 +0000</lastBuildDate>
                        <title>RE: How Poor Water Quality Can Destroy Your Circulation Pump</title>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-34204</link>
                        <pubDate>Mon, 09 Sep 2024 07:06:45 +0000</pubDate>
                        <description><![CDATA[Hi @Graham Brennand, Grant&#039;s installers don&#039;t seem very consistent on glycol. Grant recommend it, but a lot of their systems, mine include, use water with anti-corrosion/fouling agent such a...]]></description>
                        <content:encoded><![CDATA[Hi @Graham Brennand, Grant's installers don't seem very consistent on glycol. Grant recommend it, but a lot of their systems, mine include, use water with anti-corrosion/fouling agent such as Sentinel and fit anti-freeze valves instead. You're glycol will be a mix of glycol and water however, usually the glycol is to around 25% concentration maximum in typical domestic systems to provide sufficient frost protection to the outdoor unit. Grant's equipment is already well protected - with the circulating pump energised below 4degC outdoor air temperature. In a location subject to power cuts and very low winter air temperatures, the glycol is a good safeguard against risk of freezing, I've never been totally convinced that anti-frost valves are 100% effective.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>AllyFish</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-34204</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-34111</link>
                        <pubDate>Wed, 04 Sep 2024 13:33:33 +0000</pubDate>
                        <description><![CDATA[What to be aware of with water, is that the stability of the water changes with temperature. There is a calculator online at Lenntech for LSI which allows you to determine the Langelier Inde...]]></description>
                        <content:encoded><![CDATA[What to be aware of with water, is that the stability of the water changes with temperature. There is a calculator online at Lenntech for LSI which allows you to determine the Langelier Index of your water from test results, but also change the temperature and see the impact.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>Mark Burton</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-34111</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33659</link>
                        <pubDate>Thu, 22 Aug 2024 14:27:10 +0000</pubDate>
                        <description><![CDATA[Your water will not taste salty the levels are not high enough. But the subject is not is softener water ok to drink - generally is just fine and dandy to drink it. The subject is heating sy...]]></description>
@toodles Do you use yours for drinking?  We do; it doesn't taste salty at all.
Your water will not taste salty the levels are not high enough. But the subject is not is softener water ok to drink - generally is just fine and dandy to drink it. The subject is heating system water.
But the chart on water from a softener, 
A domestic Ion Exchange softener - Sodium replaces calcium carbonate, 46 mg/litre of sodium for every 100 mg/litre of calcium carbonate (hardness minerals) taken out of the water. Other mineral will still remain in the water, so the total dissolved solids PPM, could still be quite high. So it requires measurement.
Deminerised water made via a ion exchange resin is a different process. Ion exchange resins can be used to demineralise water by removing dissolved ions and inorganic salts. In this process, the resins exchange non-desirable cations and anions in the water with hydrogen and hydroxyl ions, respectively, to create pure water (H2O).
The water used under VDI2035 is a balancing act between conductivity and total dissolved solids.
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>Anonymous 5011</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33659</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33658</link>
                        <pubDate>Thu, 22 Aug 2024 14:06:05 +0000</pubDate>
                        <description><![CDATA[Mind you, the water softener was not cheap; I seem to remember that this most recent one cost over £1K installed! Gulp, Toodles.]]></description>
                        <content:encoded><![CDATA[Mind you, the water softener was not cheap; I seem to remember that this most recent one cost over £1K installed! Gulp, Toodles.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33658</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33657</link>
                        <pubDate>Thu, 22 Aug 2024 13:41:51 +0000</pubDate>
                        <description><![CDATA[@ianmk13 Yeap, we have had this type of water softener for 30 years plus and have always been able to drink the water it passes! &#x1f609; Toodles.]]></description>
                        <content:encoded><![CDATA[@ianmk13 Yeap, we have had this type of water softener for 30 years plus and have always been able to drink the water it passes! &#x1f609; Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33657</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33654</link>
                        <pubDate>Thu, 22 Aug 2024 13:30:11 +0000</pubDate>
                        <description><![CDATA[@toodles Do you use yours for drinking?  We do; it doesn&#039;t taste salty at all.]]></description>
                        <content:encoded><![CDATA[@toodles Do you use yours for drinking?  We do; it doesn't taste salty at all.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>IanMK13</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33654</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33610</link>
                        <pubDate>Wed, 21 Aug 2024 17:50:10 +0000</pubDate>
                        <description><![CDATA[@johnmo We have a Kinetico Minimax softener and the literature tells me that the resin beads in the chambers remove calcium and magnesium and as part of the recharging cycle, the final salt ...]]></description>
                        <content:encoded><![CDATA[@johnmo We have a Kinetico Minimax softener and the literature tells me that the resin beads in the chambers remove calcium and magnesium and as part of the recharging cycle, the final salt solution is flushed out of the chamber before the valve reconnects the chamber to the house supply. I think this is an ion exchange process. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33610</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33608</link>
                        <pubDate>Wed, 21 Aug 2024 16:41:18 +0000</pubDate>
                        <description><![CDATA[Not sure it does, most plumbers fill with water and then chemical dose and walk away. If they come back for a service add more. Most people have not actually heard of VDI 2035.
If done wi...]]></description>
VDI 2035 guideline serves as the main standard for heating water treatment
softening
If done with a water softener instead of Ion Exchange resin, the salt content can cause other issues and also stop the natural alkaling of the water as it goes through numerous heat cycles.
So you can end up with corrosion but for other reasons.
Most water on ships is deminerised via a steam generator then condensed.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33608</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33617</link>
                        <pubDate>Wed, 21 Aug 2024 15:39:12 +0000</pubDate>
                        <description><![CDATA[My Grant ASHP is running with a  gylcol fluid, no water involved.]]></description>
                        <content:encoded><![CDATA[My Grant ASHP is running with a  gylcol fluid, no water involved.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/">Safety, Regulations, Tools, Plumbing &amp; DIY Installations</category>                        <dc:creator>Graham Brennand</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33617</guid>
                        <link>https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33604</link>
                        <pubDate>Wed, 21 Aug 2024 15:28:09 +0000</pubDate>
                        <description><![CDATA[A late friend of ours used to be the chief engineer on the Queen Mary; he regularly checked the quality of the water taken on board for the boilers. He told us that the water collected in Ne...]]></description>
                        <content:encoded><![CDATA[<p>A late friend of ours used to be the chief engineer on the Queen Mary; he regularly checked the quality of the water taken on board for the boilers. He told us that the water collected in New York was some of the best that they used and measured 0.5 on a scale he used. He referred to the local water as ‘Liquid Bricks! Now, we live in a very hard water area in Berkshire and apparently, the water here measured 22 on that same scale. We have a water softener on the main in and all our usage is softened (other than toilet and garden supplies.)</p>
<p>This means the water used to fill our heating system has been softened but in no other way treated. I just hope that this softening has at least taken care of one of the nastiest elements! Regards, Toodles.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/safety-regulations-tools-diy-installations/how-poor-water-quality-can-destroy-your-circulation-pump/#post-33604</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:25:47 by W3 Total Cache
