Mains water pressure
when my air source heat pump was installed I think the cold water was no longer fed from a tank in the loft but fed directly from the mains. Does that make sense?
It now makes a lot of noise when the cold tap turns on and toilets flush, washing machine fills etc. As it turns off there is then a large clunk noise.
any thoughts how to solve this?
thanks
Check to see if you have a loose pipe where you hear the clunk you speak of. It’s very likely a result of the plumbing being diverted.
Thanks will do.
did anyone else find the system is over-pressured since the ASHP was installed?
Hi @bridgetjohn
Yes ! We had a vented system prior to the ASHP, we now have an unvented system, so mains pressure in all the hot and cold taps. We have 2 loos, one is same as ever, the other sends a thud down the pipework when the flow shuts off. It's been suggested that the answer is to fit a different valve in that loo: a Thomas Dudley Hydroflow bottom entry ball valve !! It's been on my list of 'to do' items for months, meanwhile I've got used to it. Thanks for reminding me.
- 24 Forums
- 1,398 Topics
- 29.4 K Posts
- 16 Online
- 1,180 Members
You can buy a Seplos kit for £500 less than the Fogstar...
By MisterB , 52 mins ago
RE: Is this a bad installation and is there something wrong with my Samsung heat pump?
My system installed last year in November in the loft s...
By David999 , 10 hours ago
RE: Are Solar Diverters Necessary for Homes with ASHPs and Solar PV?
Yeah, my diverter is off almost all the time since we h...
By Andris , 12 hours ago
RE: Creating a second zone on Mitsubishi Ecodan ASHP
Thanks for your time with this Gary. I have a wireless...
By BryanB , 15 hours ago
RE: Error on Immersun – Error 8 Load Short Circuit
@julesmp8 After a whole battery of tests? 😉
By Toodles , 1 day ago
RE: Delivering a smart and secure electricity system: government consultation
@abernyte Well, anything is possible, after all, we hav...
RE: Heat Pump Paradox: The Industry's Adoption Divide
@majordennisbloodnok 😆
RE: ASHP Cut-off Temperatures: What's Your Setting and is a Your Heating Still On?
Not seen a setting on our ASHP for auto cut-off temp. I...
By Vince31 , 2 days ago
RE: How to increase DHW water temperature on Samsung Gen 6 Control Panel
@jamespa I have the Samsung high temp quiet model and w...
By TechnoGeek , 2 days ago
RE: Need a bit of help please: problematic heat pump installation
Thanks for the replies, and looking back it is a bit va...
By Seagrave , 2 days ago
RE: GSHP running UFH but no feedback loop yet.
thanks! It did turn out to be a sort of fault - well, ...
By petew , 2 days ago
RE: My ASHP is not performing as well as I’d hoped: COP just over 2
@hcas - exactly so. I did read one other persons simila...
By HarriUp , 4 days ago
RE: The EPC Dilemma: How Current Ratings Fail Heat Pumps
@toodles your EPC is a limited tool that needs to be af...
By ajn9000 , 4 days ago
Jürgen Klopp: Similarities Between Heat Pumps & Football
We had the unique opportunity to sit down with Liverpoo...
You surprise me, @heacol 🥸
@transparent thank you for your comments. Sorry - the ...
By ajn9000 , 5 days ago
RE: Stiebel Eltron Servicewelt COP figures compared with OpenEnergyMonitor
@shaeney thank you. SE have 2 portals. The standard o...
RE: Issues with installer's use of pipework for Vaillant Arotherm ASHP
@editor Thanks for that, appreciated. I looked and the ...
By JWilliams89 , 5 days ago
DIY Heat Pump Installations: Navigating Legal and Regulatory Hurdles
My interest in DIY heat pump installations began when I...
By Justin , 6 days ago
RE: New Scottish Building Heat Standard
From what I have read it is a start, the issue is more ...
By guthrie , 6 days ago
Latest Topics
By Mars 13 hours ago
By BryanB 4 days ago
By Mars 4 days ago
