									Bivalent oil boiler system to work alongside ground or water source heat pump - Ground Source Heat Pump (GSHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:10:40 +0000</lastBuildDate>
                        <title>RE: Bivalent oil boiler system to work alongside ground or water source heat pump</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-30688</link>
                        <pubDate>Thu, 09 May 2024 19:06:27 +0000</pubDate>
                        <description><![CDATA[I can provide a lot of detail on LED lighting.
But no one else would find it hidden away on this topic!
I use some LED-bulbs, and also create my own LED lights using component parts.They a...]]></description>
<p>replace the 85 halogen MR16 downlighter in the house with LED (any recommendations for a wife who thinks LED is too blue / harsh?). I have already replaced a load of strip lights and every GU10 I can find.</p>
<p>I can provide a <span style="text-decoration: underline">lot</span> of detail on LED lighting.</p>
<p>But no one else would find it hidden away on this topic!</p>
<p>I use some LED-bulbs, and also create my own LED lights using component parts.<br />They achieve greater efficiency and longer life.</p>
7302
<p>Please raise this issue in a separate topic and tag me there (insert my forum ID with the @ symbol at the start).<br />I'll then receive an email to alert me that I've been mentioned.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Transparent</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-30688</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-30680</link>
                        <pubDate>Thu, 09 May 2024 15:20:52 +0000</pubDate>
                        <description><![CDATA[Hi @ldnajt 
I&#039;m curious to know what you ended up doing? It sounds as though we have a similar setup to you, and I&#039;m looking at bivalent systems, it would be great to hear if you had any fe...]]></description>
                        <content:encoded><![CDATA[<p>Hi <a title="LDNAJT" href="https://renewableheatinghub.co.uk/participant/ldnajt">@ldnajt </a></p>
<p>I'm curious to know what you ended up doing? It sounds as though we have a similar setup to you, and I'm looking at bivalent systems, it would be great to hear if you had any feedback or advice on what you decided to implement.</p>
<p>Thanks</p>
<p>Olly</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Hiddenheatpump</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-30680</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-7429</link>
                        <pubDate>Tue, 15 Mar 2022 10:33:27 +0000</pubDate>
                        <description><![CDATA[Posted by: @ldnajt 
LEDs come in a range of colour tem...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="2448" data-postid="7426" data-mention="ldnajt">
<div class="wpforo-post-quote-author"><strong> Posted by: @ldnajt </strong></div>
<p>replace the 85 halogen MR16 downlighter in the house with LED (any recommendations for a wife who thinks LED is too blue / harsh?).</p>
<p>LEDs come in a range of colour temperatures. Some of the warm ones are really quite yellow.</p>
<p>On other things, I think you can have a boiler alongside a heat pump but it will be without any grant funding... there are posts on here about the difference between a grid import/export battery and an Uninterruptable Power Supply so it may not be as simple as you expect to keep the boiler running unless it has two power inputs... home pellet boilers I have met smell funny but may have been misconfigured... and I do not agree it need be a choice between renewable heating and a warm house, but it may depend on the house if renewable heat is affordable.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>mjr</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-7429</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-7428</link>
                        <pubDate>Tue, 15 Mar 2022 10:26:56 +0000</pubDate>
                        <description><![CDATA[@ldnajt, welcome to the forums. Going bivalent is, to my mind, a sensible strategy, especially if you can run your oil boiler on a biofuel like HVO. We actually run our air source heat pump ...]]></description>
                        <content:encoded><![CDATA[<p><span>@ldnajt, welcome to the forums. Going bivalent is, to my mind, a sensible strategy, especially if you can run your oil boiler on a biofuel like HVO. We actually run our air source heat pump with our oiler boiler as a bivalent system and you can <a href="https://myhomefarm.co.uk/going-bivalent-ashp-hvo" target="_blank" rel="noopener">watch this video</a> if you have the time to see how it's performing. </span></p>
<p>I'll address the water and ground source. Water source, to my understanding, is much cheaper to install (as you don't have to drill holes or dig trenches). The coils simply get placed in the water and the piping is run to the heat pump unit in the house. The most important thing about water source is that the water is 'moving'. It needs to flow out and be replaced with "new" water that brings its own heat. If that doesn't happen at an acceptable rate, the body of water will freeze over. Water source, to my knowledge, is more efficient that ground source, provided there's moving water. This is one of the main reasons we weren't able to use our pond. </p>
<p>So the quick and easy answer is that yes, you can get your oil boiler to work as a bivalent/hybrid system with a ground or water source heat pump. It's a matter of finding a suitable installer to get the job done properly. In terms of installers, I'd start by taking a look at the GSHPA website. In terms of heat pump units, Kensa are a market leader. </p>
<p>I would stay away from pellet boilers – everyone I've spoken to says they're a nightmare to maintain.</p>
<p>Solar thermal – definitely go with that if you have the budget. It's a quick and easy win. You should also consider solar PV.</p>
<p>Glad you replaced the halogens. We did the same at our house. It cost us over £200 in warm LED bulbs, but that paid itself back quite quickly, which will be even quicker with the current electricity tariffs. </p>
<p>Batteries are an interesting one. We're looking into it now for the first time, but there are others here that will provide far more insight into their benefits.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-7428</guid>
                        <title>Bivalent oil boiler system to work alongside ground or water source heat pump</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-7426</link>
                        <pubDate>Tue, 15 Mar 2022 09:56:01 +0000</pubDate>
                        <description><![CDATA[Hello, I didn&#039;t know where best to post this, as it covers about every one of the subgroups, so here&#039;s hoping (and apologies if I&#039;ve missed the general section!).
I am looking for some help...]]></description>
                        <content:encoded><![CDATA[<p>Hello, I didn't know where best to post this, as it covers about every one of the subgroups, so here's hoping (and apologies if I've missed the general section!).</p>
<p>I<span> am looking for some help, on a specific question but then more generally a sense-check in terms of the things to consider for ideally reducing bills in a house we plan to live in for the next 20-40 years.</span></p>
<p><span>The specific question – </span><strong>is it possible to have an oil boiler system running alongside a water source (or air, or ground) heat pump?</strong></p>
<p><span>"why would you do that?" is a reasonable question - the reason being that we've had our oil fired boiler die after 7 years (just out of warranty). I have a young family who are getting bored of the oil radiators around the house, and I suspect my desire to fully explore renewables is going to meet the wall of my wife wanting a warm house. I know the days are getting warmer, so I might have a little more time than she thinks. However, I imagine that the lead times for renewable installs is probably going to be an issue, so we need to spend £5-10k in the next few weeks to tide us over. </span></p>
<p><span>It is frustrating as I’d planned to fully explore the topic of renewable sources for our house this summer, figuring that leaving it a while after the storms would mean demand had dropped off… Lesson learned.</span></p>
<p><span>There is a less significant point about retaining an oil boiler for the house in that we also use an oil boiler elsewhere, fed by the same tank, to warm a small office I use a day or two a week.</span></p>
<p><span>So, I think I'm in the position of needing to replace an oil boiler today, but wanting to supplement and ideally essentially replace its use in the house within the next few months with a mix of renewable sources. My ignorant question is, is it possible to have a WSHP (we have access to a nearby large body of water for this) or A/GSHP, supplemented by oil? In my mind, I could see that if it worked, this could be ideal, with oil taking the edge off colder days.</span></p>
<p><span>For background, we live in a c16th century house, which is (relatively) well-insulated (to the extent it's advisable) and double-glazed. The sleeping part of the house is old and cold but was renovated 20 years ago and is cold mainly because the radiators are small, and the downstairs living bit is half an extension with UFH.</span></p>
<p><span>In terms of use, we use c6000 litres of oil a year, and terrifyingly about 35-40,000 kW. I know it's a lot. While it doesn't explain it all, we have lots of halogen lights, an electric aga that my wife turns off for c3 weeks a year, and a pool run with ASHP for 3 months a year.</span></p>
<p><span>Aside from the short term conundrum, I am looking at all options, and the order of attack for me is (I think), as follows: </span></p>
<ol>
<li>replace boiler (because I have to, but I might get away with it until summer if the weather stays ok)</li>
<li>replace the 85 halogen MR16 downlighter in the house with LED (any recommendations for a wife who thinks LED is too blue / harsh?). I have already replaced a load of strip lights and every GU10 I can find.</li>
<li>fully investigate installing GSHP or WSHP. We have water about 80m from the house, and 50 of the 80m is a field that we could also use for GSHP. It would be amazing to use the pond for this, or we could use the field, but I understand that water is a better medium for this.</li>
<li>To power at least a bit of this, and reduce our electricity consumption somewhat, install a solar array in the same field. We are fortunate to have space facing south, in an unshaded spot, for about 100m2 of panels, if not more. My simplistic view is that we use so much power that we should go as big as we can on this.</li>
<li>Battery - I'm not sure we need one as I think we'll use the energy we generate year round. I haven't got the maths to work on this, but after being without power for 3 days post the recent storms I am less about price and more interested in a solution that keeps the oil boiler working!</li>
<li>Other thoughts include:</li>
</ol>
<li>Pellet boiler – friends rave about them, but I’m not sure I can make this work. We have the space for a boiler and a 5-6 tonne store, but across the drive and it feels like a big faff to then be reliant on outside suppliers.</li>
<li>Combi pellet / wood – we don’t have the wood for this</li>
<li>Solar thermal for the house – this could work or at least reduce our use of oil in summer (but perhaps overkill if the solar panels are diverting supply into the immersion heater)</li>
<li>Solar thermal for our swimming pool – this seems extravagant / stupid for 3 months of use, but also quite satisfying!</li>
<p><span>Apologies for the ramble, but there’s a lot to consider and I’ve yet to find a really good generalist, rather than an e.g. solar expert, or a pellet expert!</span></p>
<p><span>If anyone has anyone they rate, I’d welcome an introduction. We are based in North Hampshire, near Hook.</span></p>
<p><span>I welcome any and all criticism and suggestions - I reckon that I know just enough to be really dangerous!</span></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>LDNAJT</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/oil-boiler-alongside-renewables-adding-renewable-energy-lots-of-questions/#post-7426</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:10:40 by W3 Total Cache
