									IVT Greenline multiple alarms - Ground Source Heat Pump (GSHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/</link>
            <lastBuildDate>Sat, 05 Sep 2026 17:49:03 +0000</lastBuildDate>
                        <title>RE: IVT Greenline multiple alarms</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-25202</link>
                        <pubDate>Thu, 28 Dec 2023 23:17:49 +0000</pubDate>
                        <description><![CDATA[Hi I was an engineer for ice b4 they went bust that many alarms could possibly be the rego, gt8 and 9 alarms only really an issue once they get 15 degrees apart normally a good service will ...]]></description>
                        <content:encoded><![CDATA[<p>Hi I was an engineer for ice b4 they went bust that many alarms could possibly be the rego, gt8 and 9 alarms only really an issue once they get 15 degrees apart normally a good service will clean out any magnetite, ice never fitted magnetic filters which all gshp and ashp should have as standard. You can call alto energy basically the ppl from ice who started again without the main director they do a call out service and repair depending where u are in the UK? I'm based Yorkshire and North East </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Fgasengineer1066</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-25202</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17559</link>
                        <pubDate>Sun, 19 Mar 2023 17:39:29 +0000</pubDate>
                        <description><![CDATA[Thank you Brendon Uys for responding.
Should the Ground Loop Pump (GLP) come on with the other one - i.e. at the same moment?
I didn&#039;t think of trying to run the unit when I had the GLP  c...]]></description>
<p>I have run some checks. The power supply is good, the refrigerant is clear (not yellow) there is considerable pressure in in the refrigerant circuit, the Ground Loop Pump works when on separate cable.</p>
<p>Question: Should the Ground Loop Pump come on when the Central Heating Pump comes on? Because it doesn't.</p>
<p>The ground loop pump must run when the heating is on, it may be a connection problem or the board has failed. You can as a temporary measure try connecting the brine pump to a separate source and then run the heat pump.</p>
<p>Thank you <a title="Brendon Uys" href="https://renewableheatinghub.co.uk/participant/heacol">Brendon Uys</a> for responding.</p>
<p>Should the Ground Loop Pump (GLP) come on with the other one - i.e. at the same moment?</p>
<p>I didn't think of trying to run the unit when I had the GLP  connected to a separate supply - good idea. Should I leave the loom plug disconnected for this test?</p>
<p>The problem I have is that all the alarms now come on almost immediately after the Hot pump starts and lock the unit. Acknowledging the alarms makes no difference.</p>
<p>I could not see how to clear the error log in the manual, do you know please?</p>
<p>If after clearing the alarms the unit works with the GLP on a separate supply, why do you think caused no power to it from te unit?</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>AF1</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17559</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17557</link>
                        <pubDate>Sun, 19 Mar 2023 17:10:27 +0000</pubDate>
                        <description><![CDATA[The ground loop pump must run when the heating is on, it may be a connection problem or the board has failed. You can as a temporary measure try connecting the brine pump to a separate sourc...]]></description>
The ground loop pump must run when the heating is on, it may be a connection problem or the board has failed. You can as a temporary measure try connecting the brine pump to a separate source and then run the heat pump.<br />
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>BU</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17557</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17549</link>
                        <pubDate>Sun, 19 Mar 2023 16:39:03 +0000</pubDate>
                        <description><![CDATA[@heacol, do you have any insights or thoughts to answer AF1&#039;s question?]]></description>
                        <content:encoded><![CDATA[<p>@heacol, do you have any insights or thoughts to answer AF1's question?</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17549</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17529</link>
                        <pubDate>Sun, 19 Mar 2023 09:28:23 +0000</pubDate>
                        <description><![CDATA[I have run some checks. The power supply is good, the refrigerant is clear (not yellow) there is considerable pressure in in the refrigerant citcuit, the Ground Loop Pump works when on separ...]]></description>
                        <content:encoded><![CDATA[<p>I have run some checks. The power supply is good, the refrigerant is clear (not yellow) there is considerable pressure in in the refrigerant citcuit, the Ground Loop Pump works when on separate cable.</p>
<p>Question: Should the Ground Loop Pump come on when the Central Heating Pump comes on? Because it doesn't.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17529</guid>
                        <title>IVT Greenline multiple alarms</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17465</link>
                        <pubDate>Sat, 18 Mar 2023 08:17:03 +0000</pubDate>
                        <description><![CDATA[Hi, Newbie here needing help.  Initial alarm was CT8 &amp; CT9 at 37C heat pump would run for about 5 minutes. Now multiple alarms CT1 through CT11 HP runs for 5 seconds. Any assistance grea...]]></description>
                        <content:encoded><![CDATA[<p>Hi, Newbie here needing help.  Initial alarm was CT8 &amp; CT9 at 37C heat pump would run for about 5 minutes. Now multiple alarms CT1 through CT11 HP runs for 5 seconds. Any assistance greatly appreciated.  There are more alarm displays but have reached maximum permissible.</p>
3356
3357
3358
3359
3360
3361
3362
3363
3364
3365
3366
3367
3368
3369
3370
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ivt-greenline-multiple-alarms/#post-17465</guid>
Served from: renewableheatinghub.co.uk @ 2026-09-05 18:49:03 by W3 Total Cache
