									Ground source heat pump is unaffordable to run - Ground Source Heat Pump (GSHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:44:20 +0000</lastBuildDate>
                        <title>RE: Ground source heat pump is unaffordable to run</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-28150</link>
                        <pubDate>Mon, 26 Feb 2024 08:48:20 +0000</pubDate>
                        <description><![CDATA[@gshpwoes did you ever resolve your issues above?]]></description>
                        <content:encoded><![CDATA[@gshpwoes did you ever resolve your issues above?]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-28150</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-27037</link>
                        <pubDate>Sat, 03 Feb 2024 22:09:52 +0000</pubDate>
                        <description><![CDATA[@gshpwoes I received the following reply from the Heat Pump Federation directly relating to your case: As the machine is nearly ten years old, it probably doesn&#039;t have very good Internet con...]]></description>
                        <content:encoded><![CDATA[<p>@gshpwoes I received the following reply from the <a href="https://www.hpf.org.uk" target="_blank" rel="noopener">Heat Pump Federation</a> directly relating to your case: <br /><br /><em>As the machine is nearly ten years old, it probably doesn't have very good Internet connectivity for remote diagnosis. If the homeowner wants to email the Federation with whatever design materials they have, we'll see what can be inferred, before sending someone along and incurring that sort of cost. For example, with the postcode, we could review the EPC (Scottish equivalent) and the geology, to get a feel for system sizing. The fact that the radiators are cold in parts suggests a balancing problem. That could be dealt with by a competent heating technician/engineer because distribution problems are common to all technologies to a large extent. So they could find a good local central heating provider to look at that bit of the system.</em></p>
<p>Apart from that, have you made any progress with your system?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-27037</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26843</link>
                        <pubDate>Mon, 29 Jan 2024 16:59:59 +0000</pubDate>
                        <description><![CDATA[@heacol hoping you can advise if this is a fixable problem and if it is, how..? &#x1f91e;]]></description>
                        <content:encoded><![CDATA[<p>@heacol hoping you can advise if this is a fixable problem and if it is, how..? &#x1f91e;</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>GSHPwoes</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26843</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26790</link>
                        <pubDate>Sun, 28 Jan 2024 14:58:25 +0000</pubDate>
                        <description><![CDATA[@heacol can I do anything about this?? &#x1f91e;]]></description>
                        <content:encoded><![CDATA[@heacol can I do anything about this?? &#x1f91e;]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26790</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26789</link>
                        <pubDate>Sun, 28 Jan 2024 14:43:33 +0000</pubDate>
                        <description><![CDATA[@gshpwoes Unfortunately, from looking at the pictures, and the components used, you more than likely have a serious flow issue.]]></description>
                        <content:encoded><![CDATA[@gshpwoes Unfortunately, from looking at the pictures, and the components used, you more than likely have a serious flow issue.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>BU</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26789</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26666</link>
                        <pubDate>Fri, 26 Jan 2024 15:00:34 +0000</pubDate>
                        <description><![CDATA[@editor south east scotland]]></description>
                        <content:encoded><![CDATA[@editor south east scotland]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26666</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26665</link>
                        <pubDate>Fri, 26 Jan 2024 14:56:45 +0000</pubDate>
                        <description><![CDATA[@gshpwoes, which part of the country are you in?]]></description>
                        <content:encoded><![CDATA[@gshpwoes, which part of the country are you in?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26665</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26658</link>
                        <pubDate>Fri, 26 Jan 2024 12:49:21 +0000</pubDate>
                        <description><![CDATA[It certainly appears that way…. Although having your gshp on a c50 seems somewhat excessive. However, I expect it’s because it isn’t an inverter machine, a lot of older gshp weren’t. With th...]]></description>
<p>@hughf I don’t think the immersion is on?</p>
<p>It certainly appears that way…. Although having your gshp on a c50 seems somewhat excessive. However, I expect it’s because it isn’t an inverter machine, a lot of older gshp weren’t. With that come quite a sharp startup surge when the compressor fires up.</p>
<p>Do you know the model number of the unit, the design flow temperature, and the heat loss calcs for the property?</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>HughF</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26658</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26657</link>
                        <pubDate>Fri, 26 Jan 2024 12:31:37 +0000</pubDate>
                        <description><![CDATA[@gshpwoes you can cancel the legionella program for a start. Total waste of time, unless you’re 85 and immunocompromised.]]></description>
                        <content:encoded><![CDATA[@gshpwoes you can cancel the legionella program for a start. Total waste of time, unless you’re 85 and immunocompromised.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26657</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26656</link>
                        <pubDate>Fri, 26 Jan 2024 12:18:36 +0000</pubDate>
                        <description><![CDATA[@hughf I don’t think the immersion is on?]]></description>
                        <content:encoded><![CDATA[@hughf I don’t think the immersion is on?
6148]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ground-source-heat-pump-unaffordable-to-run/paged/3/#post-26656</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:44:20 by W3 Total Cache
