									ASHP Energy Consumption/ Useage - Ground Source Heat Pump (GSHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/</link>
            <lastBuildDate>Sun, 08 Nov 2026 01:55:53 +0000</lastBuildDate>
                        <title>RE: ASHP Energy Consumption/ Useage</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33488</link>
                        <pubDate>Mon, 19 Aug 2024 17:52:39 +0000</pubDate>
                        <description><![CDATA[@johnmo 
Yes, so I understand. However, I took a different route on “SmartHome” and use a Hubitat hub. I won’t be doing anything sophisticated with the Shelly, just getting, hopefully, an a...]]></description>
                        <content:encoded><![CDATA[<p>@johnmo </p>
<p>Yes, so I understand. However, I took a different route on “SmartHome” and use a Hubitat hub. I won’t be doing anything sophisticated with the Shelly, just getting, hopefully, an accurate consumption figure to compare with the Ecodan ASHP figures and thus help in optimising integration with newly installed solar.</p>
<p>I was surprised that no one came up with any alternatives.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>DavidAlgarve</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33488</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33487</link>
                        <pubDate>Mon, 19 Aug 2024 16:48:58 +0000</pubDate>
                        <description><![CDATA[It talks to home assistant.]]></description>
<p><strong>Shelly 3EM</strong></p>
<p style="text-align: justify">It talks to home assistant.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Anonymous 5011</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33487</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33484</link>
                        <pubDate>Mon, 19 Aug 2024 16:32:39 +0000</pubDate>
                        <description><![CDATA[@toodles 
Thanks Toodles. Will try to remember.
On the substance of my original question, i.e. best device to record power used for ASHP, I have looked at reviews of many 3 phase devices a...]]></description>
                        <content:encoded><![CDATA[<p>@toodles </p>
<p>Thanks Toodles. Will try to remember.</p>
<p>On the substance of my original question, i.e. best device to record power used for ASHP, I have looked at reviews of many 3 phase devices and in the absence of any suggestions, I have finally ordered a <strong>Shelly 3EM</strong> so will see how I go with this.</p>
<p>This is a WiFi device and I would have preferred a Zigbee, but it was on a special offer.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33484</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33476</link>
                        <pubDate>Mon, 19 Aug 2024 15:02:04 +0000</pubDate>
                        <description><![CDATA[@davidalgarve I am unsure if this is the problem I sometime experience but having writted my prose, I try to attach a link (URL) that I have ‘copied’ but this hub doesn’t see anything to pla...]]></description>
                        <content:encoded><![CDATA[<p>@davidalgarve I am unsure if this is the problem I sometime experience but having writted my prose, I try to attach a link (URL) that I have ‘copied’ but this hub doesn’t see anything to place in the text.</p>
<p>I have taken to putting the link into a page in Apple’s ‘Notes’ and then selecting that link and requesting ‘copy link’. I am then able to paste that link into my prose like this:</p>
<p><span><a href="https://renewableheatinghub.co.uk/how-to-balance-radiators-the-role-of-the-lockshield-valve">https://renewableheatinghub.co.uk/how-to-balance-radiators-the-role-of-the-lockshield-valve</a></span></p>
<p>And that seems to work for me.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/">Ground Source Heat Pump (GSHPs)</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33476</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33234</link>
                        <pubDate>Thu, 15 Aug 2024 11:49:02 +0000</pubDate>
                        <description><![CDATA[Still will not allow the link!]]></description>
                        <content:encoded><![CDATA[<p>Still will not allow the link!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33234</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33231</link>
                        <pubDate>Thu, 15 Aug 2024 11:47:34 +0000</pubDate>
                        <description><![CDATA[I did try to put an Amazon link in for the ZigBee device but it didn&#039;t work so have tried again below.
On advice from others, I have decided that using the heat pump for DHW around midday, ...]]></description>
                        <content:encoded><![CDATA[<p>I did try to put an Amazon link in for the ZigBee device but it didn't work so have tried again below.</p>
<p>On advice from others, I have decided that using the heat pump for DHW around midday, is more economical that buying and using a PV diverter/ immersion heater and this is just one of the areas that I would like to measure energy usage.</p>
<p><a title="Tuya Smart Energy Meter" href="https://www.amazon.es/dp/B0BX5624GH/" target="_blank" rel="noopener">https://www.amazon.es/dp/B0BX5624GH/</a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33231</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33226</link>
                        <pubDate>Thu, 15 Aug 2024 11:38:39 +0000</pubDate>
                        <description><![CDATA[I don&#039;t either, just use a PV diverter to an immersion charge the cylinder to 70 degrees, could just as easily be a panel heater in the winter.]]></description>
<p>doesn't look as though I am going to get anything for energy exported to EDP</p>
<p>I don't either, just use a PV diverter to an immersion charge the cylinder to 70 degrees, could just as easily be a panel heater in the winter.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33226</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33225</link>
                        <pubDate>Thu, 15 Aug 2024 11:29:06 +0000</pubDate>
                        <description><![CDATA[Thanks Johnmo.
Firstly, I should have made it clear that I am on a 3 phase supply in Portugal and it doesn&#039;t look as though I am going to get anything for energy exported to EDP.
I have tu...]]></description>
                        <content:encoded><![CDATA[<p>Thanks Johnmo.</p>
<p>Firstly, I should have made it clear that I am on a 3 phase supply in Portugal and it doesn't look as though I am going to get anything for energy exported to EDP.</p>
<p>I have tuned the heat pump to a reasonable standard on Weather Compensation, although I still have one more change to make and will see how this winter goes.</p>
<p>My main interest now is in integrating the newly installed solar PV.</p>
<p>I have some Smart Home so I am looking at a Tuya Smart 3 Phase ZigBee Energy Meter:</p>
<p>https://www.amazon.es/dp/B0BX5624GH/?coliid=I3O0H7VZC5HJUF&amp;colid=2QAHDNTIX5ZIP&amp;psc=1&amp;ref_=list_c_wl_lv_ov_lig_dp_it</p>
<p>Comments?</p>
<h1 id="title" class="a-size-large a-spacing-none" data-vivaldi-translated=""> </h1>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33225</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33221</link>
                        <pubDate>Thu, 15 Aug 2024 10:45:15 +0000</pubDate>
                        <description><![CDATA[Do you really need to do anything. I tried to do clever things then realised, the heat pump is most efficient ticking over all the time, it naturally makes use of all PV it can use, so delet...]]></description>
<p>I am interested in overall efficiency, but also information which will assist in integration of solar into the equation</p>
<p>Do you really need to do anything. I tried to do clever things then realised, the heat pump is most efficient ticking over all the time, it naturally makes use of all PV it can use, so deleted all the smart stuff and leave the ASHP to get on with it.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33221</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33220</link>
                        <pubDate>Thu, 15 Aug 2024 10:41:51 +0000</pubDate>
                        <description><![CDATA[A simple electric meter (have works fine)
Or if you need smarter (not used just the first I came across)]]></description>
                        <content:encoded><![CDATA[<p style="text-align: left">A simple electric meter (have works fine)</p>
<p>https://www.cityplumbing.co.uk/p/emlite-eca-2-single-phase-electricity-meter-inc-terminal-cover-eca2-mid-import/p/467563?gmcpid=467563&amp;gclsrc=aw.ds&amp;gad_source=1#fo_c=2832&amp;fo_k=4c50774cb7c987503b959637bda77791&amp;fo_s=gplauk</p>
<p>Or if you need smarter (not used just the first I came across)</p>
<p>https://www.amazon.co.uk/eMylo-Single-Phase-Electricity-Watt-Hour-Consumption/dp/B083QGBGKK?source=ps-sl-shoppingads-lpcontext&amp;ref_=fplfs&amp;psc=1&amp;smid=A2DXIFRDJKR57N</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-grounds-source-heat-pump-gshps/ashp-energy-consumption-useage/#post-33220</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 01:55:53 by W3 Total Cache
