									Will heat pump heat hot water without increasing the temp in my home? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/</link>
            <lastBuildDate>Wed, 14 Oct 2026 13:07:13 +0000</lastBuildDate>
                        <title>RE: Will heat pump heat hot water without increasing the temp in my home?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35847</link>
                        <pubDate>Sun, 13 Oct 2024 10:15:06 +0000</pubDate>
                        <description><![CDATA[@ellyse Is it possible that some of the icons you are not seeing on your own display are for functions that you do not have (naming of parts again!)? Often if a function is not required as i...]]></description>
                        <content:encoded><![CDATA[@ellyse Is it possible that some of the icons you are not seeing on your own display are for functions that you do not have (naming of parts again!)? Often if a function is not required as it has not been fitted, then the setup for it may be suppressed to reduce clutter and simplify the display. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35847</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35846</link>
                        <pubDate>Sun, 13 Oct 2024 10:11:05 +0000</pubDate>
                        <description><![CDATA[The page in the instruction manual shows all possible icons and their position on screen.
It doesn&#039;t imply that all could be present simultaneously.Some combinations are mutually exclusive,...]]></description>
                        <content:encoded><![CDATA[<p>The page in the instruction manual shows all possible icons and their position on screen.</p>
<p>It doesn't imply that all could be present simultaneously.<br />Some combinations are mutually exclusive, and couldn't ever appear together.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35846</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35844</link>
                        <pubDate>Sun, 13 Oct 2024 09:54:26 +0000</pubDate>
                        <description><![CDATA[@transparent Thank you for the link to the user manual (bookmarked it).  I am not seeing all the icons on my screen. Not sure why.]]></description>
                        <content:encoded><![CDATA[@transparent Thank you for the link to the user manual (bookmarked it).  I am not seeing all the icons on my screen. Not sure why.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Ellyse</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35844</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35841</link>
                        <pubDate>Sun, 13 Oct 2024 09:44:37 +0000</pubDate>
                        <description><![CDATA[If you can post a photo of the screen you&#039;ve managed to access, then we will find the right manual for you.
Yes, there are several possible control units by Mitsubishi...... and installers ...]]></description>
                        <content:encoded><![CDATA[<p>If you can post a photo of the screen you've managed to access, then we will find the right manual for you.</p>
<p>Yes, there are several possible control units by Mitsubishi...<br />... and installers may also choose to use others anyway.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/8/#post-35841</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35839</link>
                        <pubDate>Sun, 13 Oct 2024 09:40:47 +0000</pubDate>
                        <description><![CDATA[Finally managed to get the screen to light up and give me a menu. Unfortunately it does not look the same as that picture. 
I did find some info.  At 10.30am today used was 39kw and provide...]]></description>
                        <content:encoded><![CDATA[<p>Finally managed to get the screen to light up and give me a menu. Unfortunately it does not look the same as that picture. </p>
<p>I did find some info.  At 10.30am today used was 39kw and provided was 116kw. </p>
<p>weather compensation curve is set to 55c at -15c.   I have seen some on youtube set theirs lower than that. Wondering whether to try 45c at -15c? not altered it yet. </p>
<p>Hot water was set to 50c, I've dropped it to 47c to see if that's better.</p>
<p>I cannot find any pump settings. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35839</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35838</link>
                        <pubDate>Sun, 13 Oct 2024 09:27:12 +0000</pubDate>
                        <description><![CDATA[@ellyse  - here&#039;s the list of on-screen icons, which I&#039;ve copied from the online FTC7 user-manual:
You require the entire manual of course, not just these two pages.
It is a breach of Bu...]]></description>
                        <content:encoded><![CDATA[<p>@ellyse  - here's the list of on-screen icons, which I've copied from the online <a href="https://library.mitsubishielectric.co.uk/pdf/book/R290HomeownerGuide" target="_blank" rel="noopener">FTC7 user-manual</a>:</p>
8622
<p>You require the entire manual of course, not just these two pages.</p>
<p>It is a breach of Building Regulations Part-L that you do not have the required documentation and training to correctly operate your heat-pump system.</p>
<p>In essence, the Building Regulations come down to <strong>common sense</strong>.<br />It's astonishing that the scheme offered by your Council in conjunction with OVO Energy doesn't satisfy the legal requirements.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35838</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35827</link>
                        <pubDate>Sat, 12 Oct 2024 21:12:20 +0000</pubDate>
                        <description><![CDATA[@ellyse the icons you can get online and what they do. You will need to do that so you know how to lower dhe temp.  The pump speed is determined by flow rate so you need to know that before ...]]></description>
                        <content:encoded><![CDATA[<p>@ellyse the icons you can get online and what they do. You will need to do that so you know how to lower dhe temp.  The pump speed is determined by flow rate so you need to know that before you touch the pump. You wont know costs until it gets cold, and weather compensation is so important to get correct, not just the default settings. <br /><br />But heat loss in your house is paramount to efficiently running your system, so ask them what thickness of insulation was specified for your installation because it looks too thin and fitted badly.  You need to supply photos of the outside install and look to see if the insulation goes through the wall and not just up to it or you will be heating the wall. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>David999</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35827</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35826</link>
                        <pubDate>Sat, 12 Oct 2024 20:46:47 +0000</pubDate>
                        <description><![CDATA[I can&#039;t just ignore this all.  
I had a problem finding the controller cos I was looking for a screen with buttons.  Not the tiny touch screen thing they almost hid on the sidewall. 
It&#039;s ...]]></description>
                        <content:encoded><![CDATA[<p>I can't just ignore this all.  </p>
<p>I had a problem finding the controller cos I was looking for a screen with buttons.  Not the tiny touch screen thing they almost hid on the sidewall. </p>
<p>It's an Ecodan FTC7. I finally found a picture online of what the screen looks like but I do not know what the icons are. </p>
8618
<p>This is not my settings. This pic is clipped from the Mitsubishi website.  Can anyone explain the icons for me please?</p>
<p>I do know the guy that was here Friday increased the hot water temperature. It was only warm/hot before. Now we can't hold a hand under the tap cos it's too hot.  I need to change that.  Also I have heard it's possible to slightly lower pump speed for the radiators?  It's waking us up at night. </p>
<p>as for cost:  Today we did one washer load, two dryer loads, showers, and normal laptop and TV use, and cooked one meal on the cookertop. Add the heatpump, with very little solar as it was a miserable day.  cost so far is £4.53   That is the highest it's been so far since install. No idea if that is good or bad. </p>
<p>Is it correct that you get either a remote control for program (time/temperature) OR get to use Melcloud app.  Not both?  Is that true or bull? </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35826</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35710</link>
                        <pubDate>Fri, 11 Oct 2024 06:45:07 +0000</pubDate>
                        <description><![CDATA[Unfortunately your electrician is speaking out of the wrong orifice.  Weather compensation means altering the flow temperature up or down according to the outside temperature, and has absolu...]]></description>
<p>Weather compensation is my head hitting a brick wall.  Electrician today said "that is only really useful when it's freezing outside. runs the pump to stop it freezing up." "do not mess with it, give the system a month to 'bed-in'".  To which my guy said "she won't touch it", with a pointed look at me. </p>
<p>Sorry.  I've had enough. </p>
<p>Unfortunately your electrician is speaking out of the wrong orifice.  Weather compensation means altering the flow temperature up or down according to the outside temperature, and has absolutely nothing to do with freezing up.  </p>
<p>If you operate without weather compensation your heat pump <em>will </em>cost 15%+ more to run.   Although getting weather compensation 'spot on' can be a bit of a challenge, even a crude curve will significantly reduce costs (and make the house more comfortable because it reduces temperature swings).</p>
<p>If you are happy with this then obviously thats up to you, if not then you have the right to demand it, or an explanation why it is not applicable (which, presumably, should not be BS).  Here is an extract from MIS3005-I the MCS requirements for installers.  If they don't conform to these then MCS can take action including striking them off.  If you wish to pursue the matter then I suggest you show them this and ask them to write down the explanation, advising them that you intend to forward it to MCS.</p>
8588
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35710</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35708</link>
                        <pubDate>Thu, 10 Oct 2024 21:13:01 +0000</pubDate>
                        <description><![CDATA[Weather compensation is my head hitting a brick wall.  Electrician today said &quot;that is only really useful when it&#039;s freezing outside. runs the pump to stop it freezing up.&quot; &quot;do not mess with...]]></description>
                        <content:encoded><![CDATA[<p>Weather compensation is my head hitting a brick wall.  Electrician today said "that is only really useful when it's freezing outside. runs the pump to stop it freezing up." "do not mess with it, give the system a month to 'bed-in'".  To which my guy said "she won't touch it", with a pointed look at me. </p>
<p>Sorry.  I've had enough. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/will-heat-pump-heat-hot-water-without-increasing-the-temp-in-my-home/paged/7/#post-35708</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-14 14:07:13 by W3 Total Cache
