									Where heat loss surveys seem to go against practical reality - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:22:20 +0000</lastBuildDate>
                        <title>RE: Where heat loss surveys seem to go against practical reality</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66560</link>
                        <pubDate>Tue, 08 Sep 2026 13:23:31 +0000</pubDate>
                        <description><![CDATA[@cathoderay @jamespa
I&#039;ve managed to get some nice results myself based on data from Oct-24 to Mar-25. I will shortly put them in the thread below, since they sit very well alongside the ot...]]></description>
                        <content:encoded><![CDATA[<p>@cathoderay @jamespa</p>
<p>I've managed to get some nice results myself based on data from Oct-24 to Mar-25. I will shortly put them in the thread below, since they sit very well alongside the other methods of heat loss calculation.</p>
<p><a href="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/adventures-in-heat-loss-calculations/" target="_blank" rel="noopener">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/adventures-in-heat-loss-calculations/</a></p>
<p>@cathoderay I think the problem we identified with the y-axis intercept on your graph may well be down to not enough data. When I tried doing this with just one month's data, i.e. 31 data points, it was not at all satisfactory; however with 6 months data, and 182 data points, it worked very well.  I'll post something on that too in the other thread.</p>
<p>Many thanks to you both for the discussions on this and helping me get to what appears to be a good practical method, given enough data.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Rob of York</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66560</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66555</link>
                        <pubDate>Tue, 08 Sep 2026 07:32:41 +0000</pubDate>
                        <description><![CDATA[@rob-of-york — I have total energy delivered plus separate space and DHW heating values so can do the analysis either way. However, since we call the result the heat loss and by convention t...]]></description>
                        <content:encoded><![CDATA[<p>@rob-of-york — I have total energy delivered plus separate space and DHW heating values so can do the analysis either way. However, since we call the result the heat loss and by convention that is for the building I can see the benefit in sticking with convention. My main problem at the moment is file  clutter and poorly documented analyses, the bane of ad hoc progress, and I am trying to tidy things up. There is also a small discrepancy in the energy out results depending on how I retrieve and consolidate the data (I have available python, which does the initial retrieval and some basic calculations and puts the data in the csv files, and which I can also use for further analysis, plus spreadsheets (pivot tables etc, but they can't handle very large files) plus sql which can actually do some of the calculations as it selects the data, and finally R which has a steep learning curve, but is very capable once you have got your head round it, and it, along with python, has the best charting output. The great advantage of keeping the data in csv files rather than a more conventional database is that just about anything (including even us humans) can read the data in its raw format. </p>
<p>There are also other minor hiccups that I needs to sort out eg missing data because of power cuts, of which I have had more than a few over the last year or so as one of my lighting circuits has been playing up, at first very intermittently, and then more regularly, almost certainly over-active rodents, and it has both tripped the RCD, and needed the power off while it gets fixed.   </p>
<p>with no way of separating DHW from CH</p>
<p>I, and I am pretty sure others, use the position of the three port two way diverter valve, which is often in the data, and can be logged, and then use simple IF statements to allocate the variables to space or DHW heating. It does mean you need to have some way of communicating with your system though, eg a modbus connection. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66555</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66552</link>
                        <pubDate>Mon, 07 Sep 2026 20:47:56 +0000</pubDate>
I think there is a reasonable argument to simply include the DHW heating in your values. The heat loss calculated will then be for the fabric of the house, plus the heat lost t...]]></description>
                        <content:encoded><![CDATA[<p>@cathoderay </p>
<p>I think there is a reasonable argument to simply include the DHW heating in your values. The heat loss calculated will then be for the fabric of the house, plus the heat lost through hot water that drains away. Since the heat pump has to replace all of the heat for both CH and DHW, arguably that is a good measure to use for heat pump sizing. Otherwise, you end up working out the fabric heat loss and hence the output needed for CH, and then later adding enough to cover DHW on top of that.</p>
<p>I have gas consumption values on a daily basis, with no way of separating DHW from CH, so I'm going to try this myself.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66552</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66550</link>
                        <pubDate>Mon, 07 Sep 2026 17:09:02 +0000</pubDate>
                        <description><![CDATA[OK, this one is fairly easy, because most of what is needed is in a 24 hour data file (logs past 24 hour values every hour on the hour):
The sql used to get the da...]]></description>
                        <content:encoded><![CDATA[<p>OK, this one is fairly easy, because most of what is needed is in a 24 hour data file (logs past 24 hour values every hour on the hour):</p>
15731
<p>The sql used to get the data, variable names are ugly but just about human readable, T00: in the like clause gets the midnight value: </p>
<pre contenteditable="false">"select datetime,amb_24h_mean,round(htg_24h_kWh_out/24,2) from midea_24h_data.csv where datetime like '2026-01-__T00:%' order by datetime"</pre>
<p>The htg_24h_kWh_out variable contains all the space heating for the 24h period, including the pesky hours that also has some DHW heating. </p>
<p>The IAT-OAT version will take a bit longer as the IAT is not in the 24h data file.</p>
<p>Using like '2026-__-__T00:%' will get all 2026 data, I can then plot individual months, 1st Jan to end of heating season, whatever.</p>
<p>Edit 1956h: I've just realised the above code gets data from 31st Dec 2025 to 30 Jan 2026 because 2026-01-01T00:00:00 contains the data for the day before ie 31st Dec 2025 and so on until 2026-01-31T00:00:00 contains the data for 30th Jan 2026. Probably doesn't really matter in the great scheme of things, but sloppy of me not to spot this at the time I did the query.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66550</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66548</link>
                        <pubDate>Mon, 07 Sep 2026 16:47:49 +0000</pubDate>
                        <description><![CDATA[I could but I would like to try to find a more generic solution, working on it now!
<p>Can you add up the energy used for DHW each day? If so then at least for the daily averages, you could get the total heat pump output across all hours and then subtract the DHW contribution.</p>
<p>I could but I would like to try to find a more generic solution, working on it now!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/6/#post-66548</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66544</link>
                        <pubDate>Mon, 07 Sep 2026 14:30:18 +0000</pubDate>
                        <description><![CDATA[Can you add up the energy used for DHW each day? If so then at least for the daily averages, you could get the total heat pump output across all hours and then subtract the DHW contribution.]]></description>
                        <content:encoded><![CDATA[<p>Can you add up the energy used for DHW each day? If so then at least for the daily averages, you could get the total heat pump output across all hours and then subtract the DHW contribution.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66544</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66542</link>
                        <pubDate>Mon, 07 Sep 2026 14:04:35 +0000</pubDate>
                        <description><![CDATA[One bit of data processing that I do may be relevant. The space and DHW energy values are separated out (by way of the position of the diverter valve, which is available over modbus) but bec...]]></description>
<p>One thing that puzzles me though is that your graph against OAT for Oct to mid-Dec appears to show lots of points where the heat output is below 4 kW. It seems odd to me that there are points on that graph between 8C and 11C OAT that have outputs of less than 4kW, but none on the January graph for between 11 and 8 degrees (IAT - OAT), which is the same temperature range, assuming a 19C set point. Perhaps it is worth looking at the Oct to mid-Dec data in (IAT - OAT) form? Are there any differences between your data processing for these two cases?</p>
<p>One bit of data processing that I do may be relevant. The space and DHW energy values are separated out (by way of the position of the diverter valve, which is available over modbus) but because the DHW usually only take 30-45 mins, and then the system returns to space heating, most DHW hours also have a small amount of space heating. Since the values do not represent a full hours heating, I usually deal with these hours rather crudely by removing the offending rows, again rather crudely, by sorting by energy out and deleting the rows that appear to be affected. Looking at the chart data, it looks like I forgot (I did the chart a while ago) to remove the space heating rows affected by DHW heating. The Jan 2026 plot definitely has the affected rows removed.</p>
<p>I need to devise a way of removing these rows better. Removing any rows where there is any DHW energy use might be the answer, for which I think I can use 'q text as data', very useful CLI program that lets you run sql queries on csv files. A 'where htg_kWh_in = 0' clause or something similar should work.   </p>
<p>It is possible that your heat pump would benefit from having a simple thermostat control set a degree or two above the target temperature for the weather compensation. Then when you get lots of solar gain on a sunny but otherwise cold day, the house won't end up too hot - if that is an issue at all. (I'm assuming that the control of your heat pump is completely open loop, i.e. outdoor sensor and weather comp only, with no reference to indoor temperature?)</p>
<p>Very possibly; however. The standard Midea setup is to use the room stat as a basic by season on/off switch, with it set very high eg 26°C during the heating season, and I could dial that down, but there may be a better way, doing it over modbus (which has write as well as read access to the Midea wired controller): just turn the whole thing off when the OAT is say &gt; 15.5°C. </p>
<p>The system is 'open loop', but with the addition of a plate heat exchanger, a Freedom heat Pump warranty requirement at the time of installation. No buffers or low loss headers or any of that nonsense, all TRV valve heads off, lock shields all fully open (so as not to restrict flow, there is bit of history behind this) and yes outdoor sensor which is actually an air intake sensor because it is located next to the air intake of the heat pump, and so is affected by local air temperature changes caused by the heat pump, which can be seen as steps in the OAT, and a standard WCC setup. I do however use the IAT, by way of a python 'auto-adapt' script that bumps up the WCC up or down (by resetting the end points) depending on whether the IAT is too high or too low. This was primarily put in place to give a boost after a setback, and it behaves largely as expected.    </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66542</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66541</link>
                        <pubDate>Mon, 07 Sep 2026 13:03:57 +0000</pubDate>
If the heat pump occasionally over produces some extra heat and the indoor temperature rises accordingly, then that will be captured in the temperature differences, so should no...]]></description>
                        <content:encoded><![CDATA[<p><a title="cathodeRay" href="https://renewableheatinghub.co.uk/participant/cathoderay/">@cathoderay</a></p>
<p>If the heat pump occasionally over produces some extra heat and the indoor temperature rises accordingly, then that will be captured in the temperature differences, so should not affect the validity of the analysis. Unless of course the occupants of the house reacted to the higher indoor temperatures by opening lots of windows!</p>
<p>I have a similar issue with the weather compensation curve for my gas boiler. On its current setting, it flat lines at 30C at 15C outside temperature. However, the boiler is also controlled by a programmable timer thermostat that turns it off overnight and if the room temperature gets too high, so I don't get the overheating problem or at least not by much. Similarly, when there is a lot of solar gain in the west facing rooms on spring and autumn evenings, then the TRVs will switch those radiators off at a degree or two above the set point for the main thermostat in the living room.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66541</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66540</link>
                        <pubDate>Mon, 07 Sep 2026 13:03:22 +0000</pubDate>
                        <description><![CDATA[There may be a &#039;max temp for heating&#039; parameter.  Alternatively you could extrapolate the curve to a higher OAT point and set the T4H2 parameters accordingly.  Not much heat will be emitted ...]]></description>
<p>Because of the shape of the Midea weather compensation curve, specifically the flat line after the T4H2 set point, I think it is well nigh impossible to get it to turn off completely at higher OATs without messing up the rest of the curve.</p>
<p>There may be a 'max temp for heating' parameter.  Alternatively you could extrapolate the curve to a higher OAT point and set the T4H2 parameters accordingly.  Not much heat will be emitted once the rad temp falls below 25-27.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66540</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66539</link>
                        <pubDate>Mon, 07 Sep 2026 12:39:42 +0000</pubDate>
                        <description><![CDATA[I haven&#039;t been able to find a period when the heating was on, and the OAT was definitely above the IAT, but I have found a six hour period when the OAT was close to the IAT, and it clearly s...]]></description>
                        <content:encoded><![CDATA[<p>I haven't been able to find a period when the heating was on, and the OAT was definitely above the IAT, but I have found a six hour period when the OAT was close to the IAT, and it clearly shows the heat pump was still both using and delivering energy. Both are separate calculations, so they sort of confirm each other, that the heat pump was working (running) when it didn't need to, and dong so, I presume, because that is what the weather compensation curve said it should do. The big spike in the middle is DHW heating.</p>
15729
<p>Presumably this is going to mess up the heat loss assessment, the data says the house needs heat when it doesn't.</p>
<p>Because of the shape of the Midea weather compensation curve, specifically the flat line after the T4H2 set point, I think it is well nigh impossible to get it to turn off completely at higher OATs without messing up the rest of the curve.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/where-heat-loss-surveys-seem-to-go-against-practical-reality/paged/5/#post-66539</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:22:20 by W3 Total Cache
