									What&#039;s your current daily damage? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/</link>
            <lastBuildDate>Thu, 19 Nov 2026 00:15:19 +0000</lastBuildDate>
                        <title>RE: What&#039;s your current daily damage?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12407</link>
                        <pubDate>Fri, 09 Dec 2022 23:02:39 +0000</pubDate>
                        <description><![CDATA[46kWh yesterday reported by the heat pump / MELcloud. That would have cost me approx £13.70.
Using the reported consumption figures since it was installed at the end of August, I&#039;ve been co...]]></description>
                        <content:encoded><![CDATA[<p>46kWh yesterday reported by the heat pump / MELcloud. That would have cost me approx £13.70.</p>
<p>Using the reported consumption figures since it was installed at the end of August, I've been comparing my HP's estimated running cost with what my old gas boiler would have cost to produce the same amount of heat. So far it's still cheaper each day than if we'd stayed on gas, and significantly cheaper overall (yesterday would have cost me £16.50 for example). I'm not sure if it will remain cheaper on each individual day for the duration of winter, but I'm fairly certain it will net out cheaper over the course of the year.</p>
1927
<p>A fair chunk of that is down to the battery + TOU tariff though, which makes for a slightly unfair comparison as it doesn't account for my normal electricity use also being more expensive during the day. Having said that, I also have solar panels, but I have ignored them for the above comparison, so maybe it balances out. One day I'll do this properly...</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>scrchngwsl</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12407</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12372</link>
                        <pubDate>Fri, 09 Dec 2022 12:02:23 +0000</pubDate>
                        <description><![CDATA[I used 30kWh yesterday, total for the house was 38kWh.]]></description>
                        <content:encoded><![CDATA[<p>I used 30kWh yesterday, total for the house was 38kWh. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Gurugurugravity</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12372</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12368</link>
                        <pubDate>Fri, 09 Dec 2022 11:44:47 +0000</pubDate>
                        <description><![CDATA[60-100 kw per day this week -  calculated using the loop app (the electric co app takes too long to update but is more accurate re costs), and charging an electric car (which I do every othe...]]></description>
                        <content:encoded><![CDATA[<p>60-100 kw per day this week -  calculated using the loop app (the electric co app takes too long to update but is more accurate re costs), and charging an electric car (which I do every other night especially through colder weather for weekly commutes and car battery charge to 50%).</p>
<p>Thermostat set at 20.</p>
<p>Also have 4.2 PV array so washing machines/dishwashers etc are mix and match on daytime or overnight use obviously depending on amount of sunshine available at this time of year in Lincolnshire.</p>
<p>Currently on Scottish power EV tariff so 6p kw overnight 31p every other time until May or unless a better tarrif comes along 🤞. On RHI and awaiting for Scottish power to pull there finger out for an awaited SEG so costs are/should be offset versus summer use.</p>
<p>Powering X2  10kw Grant Aerona installed this January for approx 350sqm, and still experimenting with water Temps and hive thermostat and water heating. I've just realised 🤦🏻‍♂️ why I was getting spikes in electricity due to hot water being timed right until the 6p cut off without thinking that the heating is off thus spiking just as the 32p/kw starts after 5am thus the thermostat has to catch up I guess. With this in mind hoping for a lesser usage next week. Also turning off the trv in unused rooms but not sure if latency would drag my heat into there?</p>
<p>Looking at batteries - would probably invest in a Tesla Powerwall as these seem to be the only ones that would deliver domestic electricity in a power cut? And especially as my partner is also getting an EV next year. It looks like there will be further rolling out of V2H but pod point won't support this and not sure if would be happy with car battery degradation.</p>
<p>If it is safe probably would invest in more PV and a compatible EV charger instead.</p>
<p>Might also look at installing a diverter in time for summer to use excess PV to charge EV/heat water cylinder.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>bretix</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12368</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12361</link>
                        <pubDate>Fri, 09 Dec 2022 10:49:04 +0000</pubDate>
                        <description><![CDATA[Sorry should have said: Yesterday was 50kWh.]]></description>
<p>I save was 50kWh.</p>
<p>Sorry, I can't interpret that. </p>
<p>Sorry should have said: Yesterday was 50kWh. </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Benseb</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12361</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12360</link>
                        <pubDate>Fri, 09 Dec 2022 10:30:28 +0000</pubDate>
                        <description><![CDATA[Sorry, I can&#039;t interpret that.]]></description>
<p>Sorry, I can't interpret that. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12360</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12349</link>
                        <pubDate>Fri, 09 Dec 2022 07:23:25 +0000</pubDate>
                        <description><![CDATA[So on Weds I realised that using the log burner was turning off the stat and leaving upstairs cold. So I moved the stat upstairs to the landing which is cold. 
usage was 80kWh for the day ...]]></description>
                        <content:encoded><![CDATA[<p>So on Weds I realised that using the log burner was turning off the stat and leaving upstairs cold. So I moved the stat upstairs to the landing which is cold. <br /><br /></p>
<p>usage was 80kWh for the day </p>
<p>Yesterday we decided it was a bit too warm so moved the stat back downstairs and set to 18.5 instead of 18. <br /><br /></p>
<p>I save was 50kWh. On a colder day. <br /><br /></p>
<p>Just shows how much difference a small change can made. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12349</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12228</link>
                        <pubDate>Wed, 07 Dec 2022 12:11:35 +0000</pubDate>
                        <description><![CDATA[Running at 38° flow today. 2° outside most rooms at 19° C however, a few are lagging a little at 17 C, but these are rooms like the landing so it doesn’t matter too much.
im hoping not to g...]]></description>
                        <content:encoded><![CDATA[<p>Running at 38° flow today. 2° outside most rooms at 19° C however, a few are lagging a little at 17 C, but these are rooms like the landing so it doesn’t matter too much.<br /><br /></p>
<p>im hoping not to go over 50kWh per day over the next week or so. We shall see. Maybe ambitious…</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12228</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12223</link>
                        <pubDate>Wed, 07 Dec 2022 10:46:03 +0000</pubDate>
                        <description><![CDATA[Averaging 25kwh per day on a 10kw vaillant . Max consumption is 36.4kwh in a day so far]]></description>
                        <content:encoded><![CDATA[<p>Averaging 25kwh per day on a 10kw vaillant . Max consumption is 36.4kwh in a day so far</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Gemiar</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/3/#post-12223</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/2/#post-12185</link>
                        <pubDate>Tue, 06 Dec 2022 16:35:38 +0000</pubDate>
                        <description><![CDATA[140m2 and heated background circa 18degC daytime 16degC night time. Grant Aerona3 on 24/7. Currently about 24kWh per day for heating and DHW (45degC stat setting on 250l cylinder) combined. ...]]></description>
                        <content:encoded><![CDATA[<p>140m2 and heated background circa 18degC daytime 16degC night time. Grant Aerona3 on 24/7. Currently about 24kWh per day for heating and DHW (45degC stat setting on 250l cylinder) combined. Weekly Legionalla boost by immersion on the Solar iBoost. In addition we'll typically consume about 8kWh per day for lighting, small power, cooking, washing machine, etc. So 32kWh per day on average. I think later this week we'll see that creep to nearer to 40kWh as the temperature and CoP plummets and the ASHP defrost cycles start to add up. We have the log burner on low during afternoons and evenings. We use it to dry clothes in preference to a tumble drier.</p>
<p>If I think of what my my wife and I would have been paying 5 days a week in petrol and diesel respectively on our former commutes then we're in pocket even having the heating on 24/7 while we're both mostly WFH.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/2/#post-12185</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/2/#post-12183</link>
                        <pubDate>Tue, 06 Dec 2022 16:25:17 +0000</pubDate>
                        <description><![CDATA[Small house of approx 90m2. - Partly renovated and insulated 
Avg 7C Day
Consumption ~14kWh
Avg 4C Day
Consumption ~ 17kWh
These numbers are approx 2kWh high as they include DHW p...]]></description>
                        <content:encoded><![CDATA[<p>Small house of approx 90m2. - Partly renovated and insulated </p>
<p>Avg 7C Day</p>
<p>Consumption ~14kWh</p>
<p>Avg 4C Day</p>
<p>Consumption ~ 17kWh</p>
<p>These numbers are approx 2kWh high as they include DHW production.</p>
<p>Room Temp 20C however we have used the log burner on some evenings and reduced the heat pump use.</p>
1900]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Luke</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/whats-your-current-daily-damage/paged/2/#post-12183</guid>
Object Caching 61/71 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-11-19 00:15:19 by W3 Total Cache
