									Weather Compensation Cost not efficiency? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/</link>
            <lastBuildDate>Sun, 08 Nov 2026 02:48:04 +0000</lastBuildDate>
                        <title>RE: Weather Compensation Cost not efficiency?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36460</link>
                        <pubDate>Fri, 25 Oct 2024 14:06:02 +0000</pubDate>
                        <description><![CDATA[@ectoplasmosis perfect this now makes total sense to me.]]></description>
                        <content:encoded><![CDATA[@ectoplasmosis perfect this now makes total sense to me.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>jeegnesh</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36460</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36456</link>
                        <pubDate>Fri, 25 Oct 2024 13:50:44 +0000</pubDate>
                        <description><![CDATA[@jeegnesh It’s all been explained to you already. 
Inactive is pure weather compensation mode, where the only sensor which affects flow temperature and thus heat input into your house is th...]]></description>
                        <content:encoded><![CDATA[<p>@jeegnesh It’s all been explained to you already. </p>
<p>Inactive is pure weather compensation mode, where the only sensor which affects flow temperature and thus heat input into your house is the outdoor temp sensor. There is no longer a concept of an indoor thermostat. </p>
<p>If your system is overshooting your chosen set point temperature, then your weather compensation heat curve setting is set too high. Lower this setting, wait a couple of days and see how your house reacts. This is a process of trial and error, and takes time to end up with the perfect curve setting which suits your particular house. </p>
<p>Make sure any TRVs etc are fully open. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>ectoplasmosis</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36456</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36453</link>
                        <pubDate>Fri, 25 Oct 2024 13:43:04 +0000</pubDate>
                        <description><![CDATA[@ectoplasmosis so it constantly breaches that number and turns on.
I do know if I switch to expanded then it adheres to that temperature. So I guess I am asking what inactive does]]></description>
                        <content:encoded><![CDATA[<p>@ectoplasmosis so it constantly breaches that number and turns on.</p>
<p>I do know if I switch to expanded then it adheres to that temperature. So I guess I am asking what inactive does</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36453</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36451</link>
                        <pubDate>Fri, 25 Oct 2024 13:40:06 +0000</pubDate>
                        <description><![CDATA[@jeegnesh Your chosen set point temp is the desired indoor temperature that you choose via your SensoCOMFORT controller and myVaillant app.
If you’re finding that your house doesn’t drop in...]]></description>
                        <content:encoded><![CDATA[<p>@jeegnesh Your chosen set point temp is the desired indoor temperature that you choose via your SensoCOMFORT controller and myVaillant app.</p>
<p>If you’re finding that your house doesn’t drop in temp enough to hit your chosen setback temp during the scheduled ‘off’ period, then this means that either your weather comp curve needs tweaking, and/or you should select a lower setback temp. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36451</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36450</link>
                        <pubDate>Fri, 25 Oct 2024 13:38:25 +0000</pubDate>
                        <description><![CDATA[So this is it, what is my chosen set point, how does it get that? Considering the Room Temp Mod explanation and mine is set to Inactive.
Inactive
The thermostat is only a display...]]></description>
                        <content:encoded><![CDATA[<p>So this is it, what is my chosen set point, how does it get that? Considering the Room Temp Mod explanation and mine is set to Inactive.</p>
<ul data-hveid="CBMQAQ" data-ved="2ahUKEwini8uP06mJAxUWTKQEHYsLGiEQm_YKegQIExAB">
<li class="K3KsMc">
<div class="zMgcWd dSKvsb" data-il="">
<div class="GmFi7 PZPZlf" data-crb-p="" data-attrid="SGEEntityListItem">
<div class="xFTqob">
<div class="Gur8Ad"><span><strong>Inactive</strong></span></div>
<div class="vM0jzc"><span>The thermostat is only a display, and the heating circuit is not being used<span class="UV3uM"> </span></span>
<div class="NPrrbc" data-cid="_rJ4bZ6eFO5aYkdUPi5foiAI_13">
<div class="BMebGe btku5b k0Jjg fCrZyc LwdV0e FR7ZSc OJeuxf" role="button" aria-label="Expand" data-hveid="CBEQAQ" data-ved="2ahUKEwini8uP06mJAxUWTKQEHYsLGiEQ3fYKegQIERAB"> </div>
</div>
<div class="acn1Z Kwoiqd">
<div id="_rJ4bZ6eFO5aYkdUPi5foiAI_17" class="Kwoiqd"> </div>
</div>
</div>
</div>
</div>
</div>
</li>
<li class="K3KsMc">
<div class="Gur8Ad"><span><strong>Active</strong></span></div>
<div class="vM0jzc"><span>The thermostat adjusts the flow temperature based on the difference between the room temperature and the indoor target. </span><span>For example, if the room needs more heat, the system will increase the flow temperature.<span class="UV3uM"> </span></span>
<div class="NPrrbc" data-cid="_rJ4bZ6eFO5aYkdUPi5foiAI_14">
<div class="BMebGe btku5b k0Jjg fCrZyc LwdV0e FR7ZSc OJeuxf" role="button" aria-label="Expand" data-hveid="CBAQAQ" data-ved="2ahUKEwini8uP06mJAxUWTKQEHYsLGiEQ3fYKegQIEBAB"> </div>
</div>
<div id="_rJ4bZ6eFO5aYkdUPi5foiAI_19" class="Kwoiqd"> </div>
</div>
</div>
</div>
</div>
</div>
</li>
<li class="K3KsMc">
<div class="Gur8Ad"><span><strong>Expanded</strong></span></div>
<div class="vM0jzc"><span>The thermostat acts as an on/off switch for the heating, turning it off if the room temperature is exceeded. </span><span>The system control also regulates to the target room temperature, regardless of the outdoor temperature.</span></div>
</div>
</div>
</div>
</li>
</ul>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36450</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36447</link>
                        <pubDate>Fri, 25 Oct 2024 13:22:37 +0000</pubDate>
                        <description><![CDATA[@jeegnesh Doesn’t matter which room temp mod mode you’re using; the following behaviour happens:
During scheduled ‘heating’ periods, the heat pump targets your chosen set point temp. 
Duri...]]></description>
                        <content:encoded><![CDATA[<p>@jeegnesh Doesn’t matter which room temp mod mode you’re using; the following behaviour happens:</p>
<p>During scheduled ‘heating’ periods, the heat pump targets your chosen set point temp. </p>
<p>During scheduled ‘off’ periods, it targets your chosen setback temp. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36447</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36434</link>
                        <pubDate>Fri, 25 Oct 2024 10:11:51 +0000</pubDate>
                        <description><![CDATA[If I am in inactive mode, then how or when does setback kick in?
Timer mode lets you specify a time and a temperature but as inactive the temperature for sure has no input.]]></description>
                        <content:encoded><![CDATA[<p>If I am in inactive mode, then how or when does setback kick in?</p>
<p>Timer mode lets you specify a time and a temperature but as inactive the temperature for sure has no input.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36434</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36424</link>
                        <pubDate>Thu, 24 Oct 2024 21:07:00 +0000</pubDate>
                        <description><![CDATA[The timer is for if you are in expanded mode the wc is modified by switching off the heating if it’s too warm. You can have a set-back temp overnight or other period with a lower temperature...]]></description>
<p>so this is on Valiant aroTHERM and my settings has the the room temp mod now set to inactive, so essentially no thermostat, hence my question what the timer is for</p>
<p>The timer is for if you are in expanded mode the wc is modified by switching off the heating if it’s too warm. You can have a set-back temp overnight or other period with a lower temperature for a certain time.</p>
<p>The other mode is active which is wc plus aiming to a set temperature (ie like ‘normal’) and that is for certain times.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/paged/2/#post-36424</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/#post-36422</link>
                        <pubDate>Thu, 24 Oct 2024 20:14:08 +0000</pubDate>
                        <description><![CDATA[Got it. Thank you. 
and now Valliant seem to have made my energy data disappear have to wait till it loads back to see what’s been happening. 
damn I wish the openenrgymonitor wasn’t so ex...]]></description>
                        <content:encoded><![CDATA[<p>Got it. Thank you. <br /><br /></p>
<p>and now Valliant seem to have made my energy data disappear have to wait till it loads back to see what’s been happening. <br /><br /></p>
<p>damn I wish the openenrgymonitor wasn’t so extensive and expensive to install. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/#post-36422</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/#post-36421</link>
                        <pubDate>Thu, 24 Oct 2024 19:40:14 +0000</pubDate>
                        <description><![CDATA[@jeegnesh Almost. 
Your heat pump has no idea about your ‘design temp’, which is just the result of a theoretical calculation used to specify your heating system. 
When using a schedule, d...]]></description>
                        <content:encoded><![CDATA[<p>@jeegnesh Almost. </p>
<p>Your heat pump has no idea about your ‘design temp’, which is just the result of a theoretical calculation used to specify your heating system. </p>
<p>When using a schedule, during the ‘on’ periods your Vaillant, depending on the type of room temp modulation setting you’ve chosen (load compensation), will be heating your house at a flow temperature dictated by the outdoor temp sensor and the weather compensation curve value that’s been set in the controller. </p>
<p>During the ‘off’ periods, the heat pump will be doing the exact same thing, but will be shifting the curve accordingly to attempt to achieve the lower ‘setback’ temp set in the controller. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/weather-compensation-cost-not-efficiency/#post-36421</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 02:48:04 by W3 Total Cache
