									Water law settings... A year on - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/</link>
            <lastBuildDate>Sat, 13 Jun 2026 22:25:40 +0000</lastBuildDate>
                        <title>RE: Water law settings... A year on</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-62359</link>
                        <pubDate>Wed, 29 Apr 2026 09:40:44 +0000</pubDate>
I&#039;ve adjusted a few parameters 
201 is now 16°.     -4°
202 is now 27°.    43°
If that makes sense.
See what happens next winter.]]></description>
<p>I've adjusted a few parameters </p>
<p>201 is now 16°.     -4°</p>
<p>202 is now 27°.    43°</p>
<p>If that makes sense.</p>
<p>See what happens next winter.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Profzarkov</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-62359</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-61558</link>
                        <pubDate>Fri, 10 Apr 2026 15:35:06 +0000</pubDate>
                        <description><![CDATA[Yes it does
Apart from the abbreviations!
We&#039;re in West Wales and so temps never go below zero.... usually!
I&#039;ll have a play.
Many thanks 
                        <content:encoded><![CDATA[<p>Yes it does</p>
<p>Apart from the abbreviations!</p>
<p>We're in West Wales and so temps never go below zero.... usually!</p>
<p>I'll have a play.</p>
<p>Many thanks </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-61558</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-61556</link>
                        <pubDate>Fri, 10 Apr 2026 15:25:01 +0000</pubDate>
                        <description><![CDATA[That depends on your house.  The only way to find out is to turn hive and any TRVs up high, then turn down/up the low OAT WL setting until the house is just at the right temperature.  You ca...]]></description>
<p>I know I should scrap or at least raise the thermostat up high. What values would then be needed in the water law...</p>
<p>That depends on your house.  The only way to find out is to turn hive and any TRVs up high, then turn down/up the low OAT WL setting until the house is just at the right temperature.  You cant really do this now until next season!  You need to do it slowly, ~one degree per day.</p>
<p>I would probably adjust 31 to perhaps 27 or even 25 and 15 to perhaps 8/20.  Logically its 20 at 20 or perhaps 20@17/18 (ie when the OAT is the same as the desired room temp you need no heating) depending on the OAT at which your house in practice reaches the desire IAT with no heating.  This isnt that critical though. </p>
<p>I would also adjust -2 to something lower, perhaps -5/-10.  The reason for this is you want the FT to keep rising if the OAT falls below design temp.  With it set as you propose it will flatline when the OAT reaches -2.  </p>
<p>Hope that makes sense.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-61556</guid>
                        <title>Water law settings... A year on</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-61554</link>
                        <pubDate>Fri, 10 Apr 2026 15:15:51 +0000</pubDate>
                        <description><![CDATA[Hi
I&#039;ve had my system for well over a year now and I&#039;m very happy. The Samsung ASHP plus 5.2kW solar &amp; the Powerwall 3 are all doing very well.
I&#039;ve been reviewing my water law setting...]]></description>
<p>I've had my system for well over a year now and I'm very happy. The Samsung ASHP plus 5.2kW solar &amp; the Powerwall 3 are all doing very well.</p>
<p>I've been reviewing my water law settings &amp; would appreciate any comments.</p>
<p>The dhw temp is now 46°</p>
<p>Quiet mode is on 2400-0730, although I can't find any info on what this actually does. I know - makes it quieter! It's next to our bedroom and is pretty quiet anyway.</p>
<p>201   15° &amp; -2°</p>
<p>202  31° &amp; 44°</p>
<p>I still use my Hive thermostat, mainly to monitor the house temperature &amp; graphs.</p>
<p>I have it set to 19° daytime &amp; 18° overnight.</p>
<p>Cheers </p>
<p>Steve</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/water-law-settings-a-year-on/#post-61554</guid>
Served from: renewableheatinghub.co.uk @ 2026-06-13 23:25:40 by W3 Total Cache
