									Vaillant AroTherm Plus 7kW - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/</link>
            <lastBuildDate>Fri, 13 Nov 2026 17:52:35 +0000</lastBuildDate>
                        <title>RE: Vaillant AroTherm Plus 7kW</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/paged/2/#post-62690</link>
                        <pubDate>Sat, 09 May 2026 16:50:51 +0000</pubDate>
                        <description><![CDATA[Thank you, watson did allow me to find this one! 
Our experience with Vaillant installers is that they are knowledgeable. We had a relatively low rate of chancers at the pre-survey stage. ...]]></description>
<!-- /wp:heading -->
<!-- wp:paragraph -->
In summary, the Vaillant 7kW heat pump is a mostly well-designed unit with a user-friendly and flexible control interface that operates cost-effectively, at least in my setup. The increase in noise during certain circumstances, particularly during defrost recovery, is disappointing, though it can be managed by scheduling noise reduction mode. Vaillant’s tech support has been very helpful, unlike some competitors who either refer you to your installer or refuse to answer questions altogether.
<!-- /wp:paragraph -->
&nbsp;]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/paged/2/#post-62690</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/paged/2/#post-47193</link>
                        <pubDate>Tue, 24 Jun 2025 13:09:21 +0000</pubDate>
                        <description><![CDATA[If the thermostat is connected to the call for heat terminal on the vaillant or myson then I suspect it&#039;s also a call for cool (IE an &#039;enable&#039;).  If you turn it to max it will probably overr...]]></description>
<p>@judith we had a thermostat fitted for the kitchen as there is a lot of solar gain, and it seems to have stopped that function.</p>
<p>I'm not really bothered though.</p>
<p style="text-align: left">If the thermostat is connected to the call for heat terminal on the vaillant or <span style="text-decoration: underline">myson </span>then I suspect it's also a call for cool (IE an 'enable').  If you turn it to max it will probably override.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/paged/2/#post-47193</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47192</link>
                        <pubDate>Tue, 24 Jun 2025 12:45:01 +0000</pubDate>
                        <description><![CDATA[@judith we had a thermostat fitted for the kitchen as there is a lot of solar gain, and it seems to have stopped that function.
I&#039;m not really bothered though.]]></description>
                        <content:encoded><![CDATA[<p>@judith we had a thermostat fitted for the kitchen as there is a lot of solar gain, and it seems to have stopped that function.</p>
<p>I'm not really bothered though.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Scalextrix</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47192</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47158</link>
                        <pubDate>Sun, 22 Jun 2025 17:06:42 +0000</pubDate>
                        <description><![CDATA[@scalextrix if your under unit heater is like our Myson ‘kick step’ then you just switch it to summer mode and it works when needed in winter just fine.]]></description>
                        <content:encoded><![CDATA[@scalextrix if your under unit heater is like our Myson ‘kick step’ then you just switch it to summer mode and it works when needed in winter just fine.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47158</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47133</link>
                        <pubDate>Fri, 20 Jun 2025 14:47:43 +0000</pubDate>
                        <description><![CDATA[@jamespa I have a hydronic baseboard heater in the kitchen but I don&#039;t think it will work as it only activates the fan above 35C water temp.
Not worth the hassle and cost at the moment for ...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa I have a hydronic baseboard heater in the kitchen but I don't think it will work as it only activates the fan above 35C water temp.</p>
<p>Not worth the hassle and cost at the moment for fancoils elsewhere, but let's see how many more 40C summer days we get through global warming...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47133</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47132</link>
                        <pubDate>Fri, 20 Jun 2025 14:01:44 +0000</pubDate>
                        <description><![CDATA[Mitsubishi 8kW R290 - Two compressors, 6kW variable, 2kW fixed?
If you are decided to go with Vaillant then extra system volume will extend the cycling period (reduce the cycling frequency)...]]></description>
<p>Thanks both, I found the 3kW on a UK document somewhere though I don't have it to add here right now.</p>
<p>We are at that point where the 5kW unit is just a bit too undersized for comfort, and the 7kW is a fair bit over, as such was hoping for a better modulation than 3kW, might look into some additional system volume.</p>
<p>Mitsubishi 8kW R290 - Two compressors, 6kW variable, 2kW fixed?</p>
<p>If you are decided to go with Vaillant then extra system volume will extend the cycling period (reduce the cycling frequency) but of course wont materially change the temperature of onset of cycling or the on/off ratio.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47132</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47131</link>
                        <pubDate>Fri, 20 Jun 2025 13:59:12 +0000</pubDate>
                        <description><![CDATA[They dont.  Fancoils of UFH if you want cooling with any heat pump.  I dont kinow how effective UFH is, but some report it works well enough to be worth the effort.  Fancoils of course nicel...]]></description>
<p>What do you connect that to internally, I'm assuming standard radiators don't work?</p>
<p>They dont.  Fancoils of UFH if you want cooling with any heat pump.  I dont kinow how effective UFH is, but some report it works well enough to be worth the effort.  Fancoils of course nicely blow cold air.  I am not really set up for cooling unfortunately, should have got a couple more fancoils.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47131</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47130</link>
                        <pubDate>Fri, 20 Jun 2025 12:26:01 +0000</pubDate>
                        <description><![CDATA[What do you connect that to internally, I&#039;m assuming standard radiators don&#039;t work?]]></description>
<p>Note that it doesn't come with cooling</p>
<p>What do you connect that to internally, I'm assuming standard radiators don't work?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47130</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47129</link>
                        <pubDate>Fri, 20 Jun 2025 12:23:59 +0000</pubDate>
                        <description><![CDATA[Thanks both, I found the 3kW on a UK document somewhere though I don&#039;t have it to add here right now.
We are at that point where the 5kW unit is just a bit too undersized for comfort, an...]]></description>
                        <content:encoded><![CDATA[<p>Thanks both, I found the 3kW on a UK document somewhere though I don't have it to add here right now.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47129</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47082</link>
                        <pubDate>Wed, 18 Jun 2025 11:58:08 +0000</pubDate>
                        <description><![CDATA[Depends on the flow temperature; the Czech data sheet in the post above has the full detail but ~3kW heating output power at say 12C is more or less it.  Mine cycles at &gt;11C (overcapacity...]]></description>
<p>Thanks for the comprehensive write-up, I am considering the same unit.</p>
<p>Do you know what the turn-down or minimum modulation is on the unit and roughly how much heating power that produces. Vaillant documents seem to suggest 3kW and thats a bit more than I expected.</p>
<p>Depends on the flow temperature; the Czech data sheet in the post above has the full detail but ~3kW heating output power at say 12C is more or less it.  Mine cycles at &gt;11C (overcapacity) and &lt;5C (defrost).  That's pretty much to be expected given the turn down ratio of <em>most</em> heat pumps is at best 3:1 (comparing max o/p at min OAT/Design FT with min o/p at High OAT/Low FT).  The 8kW R290 Mitsubishi has 2 compressors (6+2kW) and does quite a bit better.</p>
<p>I get a scop of ~4 and run on pure WC without room influence (at FT42 at -2) most of the year.  I switch to expanded mode in April when solar gain gets high compared to the load.  I'm saving 20% compared to my gas boiler, paying an average of 19p/kWh for my electricity if I exclude the electric car consumption (which skews the figures - because all car charging is at night time cheap rate).  I'm rather pleased with that. </p>
<p>Despite the excess compressor noise during recovery from defrost the neighbours told me in April that they didn't even know I had fitted a heat pump, and currently the minimal sound it makes is drowned, even if you are standing right next to it, by the noise from the heat pump for the neighbours swimming pool which is sited &gt;20m away!  Note that it doesn't come with cooling as standard although a coding resistor is available (for £500 or £10 depending on whether you buy the one with the correct part number or not) which is supposed to enable cooling, albeit that there appear possibly to be some wrinkles to this.  If cooling is mission critical then you may want to choose a machine that does it out of the box, so there is no ambiguity, otherwise I would say the Vaillant is a good choice.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-7kw/#post-47082</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 17:52:35 by W3 Total Cache
