									Vaillant aroTherm Plus 10kW thoughts? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/</link>
            <lastBuildDate>Fri, 15 May 2026 01:10:46 +0000</lastBuildDate>
                        <title>RE: Vaillant aroTherm Plus 10kW thoughts?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48739</link>
                        <pubDate>Tue, 09 Sep 2025 21:26:25 +0000</pubDate>
                        <description><![CDATA[@realevil the fans and fan speed / coil size (height, width and passes) are relevant to the capacity it is only taller due to being a 10kW, it is very unlikely to be any noisier due to havin...]]></description>
                        <content:encoded><![CDATA[@realevil the fans and fan speed / coil size (height, width and passes) are relevant to the capacity it is only taller due to being a 10kW, it is very unlikely to be any noisier due to having 2 fans, if anything it probably quieter but you can find this out and ask for the data sheet , Ecodan do the smaller single fan at 11.2kW but has more passes on the coil and again is quiet. The Vaillant is a very good machine.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48739</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48705</link>
                        <pubDate>Mon, 08 Sep 2025 16:20:47 +0000</pubDate>
                        <description><![CDATA[Good unit. 
And the 10 kW is the same as the 12 kW I believe. So if your installer has done a good heat loss, in theory you have some &quot;headroom&quot;.]]></description>
                        <content:encoded><![CDATA[<p>Good unit. </p>
<p>And the 10 kW is the same as the 12 kW I believe. So if your installer has done a good heat loss, in theory you have some "headroom".</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48705</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48670</link>
                        <pubDate>Sun, 07 Sep 2025 19:56:30 +0000</pubDate>
                        <description><![CDATA[@realevil Fwiw I have the 7kW model with which I&#039;m, very happy.  There is a &#039;warts and all&#039; review on this forum, written by me. 
It&#039;s not perfect, but I don&#039;t know of a perfect machine at ...]]></description>
<p>If you need the larger one then you don’t get a choice!</p>
<p>BUT there plenty of well informed people who prefer the 10kW version. It’s quieter because its two fans run slower.</p>
<p>Defrost cycles need extra power so the 10kW is best for that too.</p>
<p>@realevil Fwiw I have the 7kW model with which I'm, very happy.  There is a 'warts and all' review on this forum, written by me. </p>
<p>It's not perfect, but I don't know of a perfect machine at the current tine.  However it's pretty good on all major measures and has a good control system, much better than many competitors, as well as performing well.  If I were buying again, I would buy another Vaillant.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48670</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48668</link>
                        <pubDate>Sun, 07 Sep 2025 19:51:44 +0000</pubDate>
                        <description><![CDATA[If you need the larger one then you don’t get a choice!
Defrost cycles n...]]></description>
                        <content:encoded><![CDATA[<p>If you need the larger one then you don’t get a choice!</p>
<p>Defrost cycles need extra power so the 10kW is best for that too.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48668</guid>
                        <title>Vaillant aroTherm Plus 10kW thoughts?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48660</link>
                        <pubDate>Sun, 07 Sep 2025 18:32:03 +0000</pubDate>
                        <description><![CDATA[Hi,
Any thoughts on this (larger) heat pump? Was main recommendation from a local heat Geek and certainly seems like a solid unit. The 7kw model is too small for the heat loss.
&amp;nb...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>Any thoughts on this (larger) heat pump? Was main recommendation from a local heat Geek and certainly seems like a solid unit. The 7kw model is too small for the heat loss.</p>
<p>I guess my main thoughts are around noise for this twin fan unit and also if the 2 fans help or hinder defrost cycles?</p>
<p>It will be outside a kitchen window so noise a worry though no bedroom has a window facing it.</p>
<p>Thanks!!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>realevil</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-plus-10kw-thoughts/#post-48660</guid>
