									Vaillant AroTherm 7kW Air Source Heat Pump - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/</link>
            <lastBuildDate>Fri, 07 Aug 2026 11:36:47 +0000</lastBuildDate>
                        <title>RE: Vaillant AroTherm 7kW Air Source Heat Pump</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-15556</link>
                        <pubDate>Sat, 04 Feb 2023 09:50:52 +0000</pubDate>
                        <description><![CDATA[@duncan-mac interested to know how you&#039;re getting on?]]></description>
                        <content:encoded><![CDATA[@duncan-mac interested to know how you're getting on?]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>webcmg</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-15556</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6666</link>
                        <pubDate>Fri, 11 Feb 2022 16:06:03 +0000</pubDate>
                        <description><![CDATA[Hi Duncan,
Many of the heat pump manufacturers allow the weather compensation curve to be tailored to a particular home, but Vaillant are one of the manufacturers that use predefined heat c...]]></description>
                        <content:encoded><![CDATA[<span style="font-size: 14px;background-color: #ffffff">Hi Duncan,</span><br />
<p>Many of the heat pump manufacturers allow the weather compensation curve to be tailored to a particular home, but Vaillant are one of the manufacturers that use predefined heat curves.</p>
<p>Weather compensation was developed to adjust the water flow temperature, in an attempt to keep the indoor air temperature reasonably constant, with changing outdoor air temperature. The degree by which the water flow temperature needs to be changed for each 1C change in outdoor air temperature is dependent upon the rate at which the heat energy leaks out of your home. This can vary under different weather conditions, sunny days increasing the indoor air temperature in some rooms due to solar gain, windy and/or rainy days causing additional heat loss. So plotting indoor air temperature and outdoor air temperature against water flow temperature will not necessarily produce a repeatable graph, but it should give some idea of how effective the selected heat curve is at maintaining the indoor air temperature at the desired value.</p>
<p>If your controller is located within the main living area, once you have achieved reasonably accurate control using solely weather compensation, the next step would be to enable adaptive control, which fine tunes the required water flow temperature to maintain the indoor air temperature at the desired setting. Even if the outdoor air temperature remains constant, if the indoor air temperature starts to increase, then the water flow temperature would be lowered slightly. The reverse action would take effect if the indoor air temperature started to reduce.</p>
<p>By all means collect the data and produce the graph, which I feel certain many, including myself, would be interested to see.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6666</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6664</link>
                        <pubDate>Fri, 11 Feb 2022 15:13:06 +0000</pubDate>
Hi Derek, just a wee query. Since I have Flow temperatures and outside temperatures at 2 min intervals, if I plot these  on a graph, if the weather compensation is working properl...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m </p>
<p>Hi Derek, just a wee query. Since I have Flow temperatures and outside temperatures at 2 min intervals, if I plot these  on a graph, if the weather compensation is working properly and the internal temperature is either 21 or setback 18, should the resulting graph map onto the 0.80 heat curve the system is set to?</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Duncan Mac</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6664</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6587</link>
                        <pubDate>Wed, 09 Feb 2022 09:52:26 +0000</pubDate>
                        <description><![CDATA[@derek-m I&#039;ve send you a message !]]></description>
                        <content:encoded><![CDATA[<p>@derek-m I've send you a message !</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>heat-pump-newbie</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6587</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6586</link>
                        <pubDate>Wed, 09 Feb 2022 08:27:50 +0000</pubDate>
                        <description><![CDATA[@heat-pump-newbie 
Hi Newbie,
I don&#039;t seem to be able to access the private message that you sent yesterday evening, and for some reason I am not being notified of their existence. Can sen...]]></description>
                        <content:encoded><![CDATA[<p>@heat-pump-newbie </p>
<p>Hi Newbie,</p>
<p>I don't seem to be able to access the private message that you sent yesterday evening, and for some reason I am not being notified of their existence. Can send your message again and remind me how your system is set to operate at the moment.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6586</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6572</link>
                        <pubDate>Mon, 07 Feb 2022 19:27:53 +0000</pubDate>
                        <description><![CDATA[Posted by: @duncan-mac 
@derek-m thank you sorry again for being such a pain.
Hi Duncan,
You are not being a pain.
I have spent most of my career problem solving, which I find most enj...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="26" data-postid="6570" data-mention="duncan-mac">
<div class="wpforo-post-quote-author"><strong> Posted by: @duncan-mac </strong></div>
<p>@derek-m thank you sorry again for being such a pain.</p>
<p>Hi Duncan,</p>
<p>You are not being a pain.</p>
<p>I have spent most of my career problem solving, which I find most enjoyable. 😀 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6572</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6570</link>
                        <pubDate>Mon, 07 Feb 2022 16:51:12 +0000</pubDate>
                        <description><![CDATA[@derek-m thank you sorry again for being such a pain.]]></description>
                        <content:encoded><![CDATA[<p>@derek-m thank you sorry again for being such a pain.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6570</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6569</link>
                        <pubDate>Mon, 07 Feb 2022 16:39:23 +0000</pubDate>
@derek-m sorry I cant seem to see the attachment you mentioned
Hi Duncan,
That&#039;s because I forgot to attach it. 🙄]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="26" data-postid="6568" data-mention="duncan-mac">
<p>@derek-m sorry I cant seem to see the attachment you mentioned</p>
<p>Hi Duncan,</p>
<p>That's because I forgot to attach it. 🙄 </p>
950]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6569</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6568</link>
                        <pubDate>Mon, 07 Feb 2022 16:36:03 +0000</pubDate>
                        <description><![CDATA[@derek-m sorry I cant seem to see the attachment you mentioned]]></description>
                        <content:encoded><![CDATA[<p>@derek-m sorry I cant seem to see the attachment you mentioned</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6568</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6566</link>
                        <pubDate>Mon, 07 Feb 2022 15:49:46 +0000</pubDate>
                        <description><![CDATA[Posted by: @heat-pump-newbie 
@derek-m Would the COP be lower if the radiator pipework running through a cold area doesn&#039;t have enough insulation ?
Hi Newbie,
It depends if the pipework...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="1691" data-postid="6565" data-mention="heat-pump-newbie">
<div class="wpforo-post-quote-author"><strong> Posted by: @heat-pump-newbie </strong></div>
<p>@derek-m Would the COP be lower if the radiator pipework running through a cold area doesn't have enough insulation ?</p>
<p>Hi Newbie,</p>
<p>It depends if the pipework is within the internal area of the building and hence helping to provide heat energy, or if it is say underneath the downstairs floorboards or in the loft, then it may create additional heat demand. The greater the heat demand, the harder the heat pump has to work, and the lower that the overall COP will be.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-arotherm-7kw-air-source-heat-pump/paged/3/#post-6566</guid>
Served from: renewableheatinghub.co.uk @ 2026-08-07 12:36:47 by W3 Total Cache
