									Vaillant Aerotherm plus does not reduce flow rate despite low delta T - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/</link>
            <lastBuildDate>Sat, 14 Mar 2026 09:14:02 +0000</lastBuildDate>
                        <title>RE: Vaillant Aerotherm plus does not reduce flow rate despite low delta T</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-39893</link>
                        <pubDate>Fri, 10 Jan 2025 23:31:49 +0000</pubDate>
                        <description><![CDATA[I am still trying to solve the puzzle of our low efficiency. In the meantime however I found out, that the Vaillant aerotherm definitely works with a constant flow rate, which is generally f...]]></description>
                        <content:encoded><![CDATA[<p>I am still trying to solve the puzzle of our low efficiency. In the meantime however I found out, that the Vaillant aerotherm definitely works with a constant flow rate, which is generally fine.</p>
<p>I will put my remaining conundrum into a different thread, as the question of the constant flow rate I think is answered, i.e. it's constant and that's fine, so the problem must be something else. </p>
<p>Thanks all!</p>
<p>Philipp</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>fillib</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-39893</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28645</link>
                        <pubDate>Sun, 10 Mar 2024 18:11:54 +0000</pubDate>
                        <description><![CDATA[On page 63 of the attached file the diagram shows the location of the water pump (item 5, labelled Heating Pump).
Page 89 shows connector X16 providing power to the Heating Pump, while X22 ...]]></description>
                        <content:encoded><![CDATA[On page 63 of the attached file the diagram shows the location of the water pump (item 5, labelled Heating Pump).
<p>Page 89 shows connector X16 providing power to the Heating Pump, while X22 initiates actuation of the Heating Pump. This internal water pump may therefore have two cables connected, one to supply electrical power and the other to control the speed. If the correct water pump has been installed with the necessary cables then I would expect the Vaillant controller to be able to vary its speed. Have you looked inside the unit to confirm what is fitted? What controller are you using?</p>
<p>On the Mitsubishi Ecodan I think that you will find the the water pump is external to the heat pump unit, and the controller can only vary the water pump speed if the correct water pump capable of PWM control has been installed. The controller can then set the pump speed to one of five alternative settings.</p>
6733
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28645</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28599</link>
                        <pubDate>Sun, 10 Mar 2024 02:40:25 +0000</pubDate>
                        <description><![CDATA[Dear @derek-m, dear @hughf,
Thanks! No, there is no error message. The pump that I am talking about (the one producing the maximum flow rate) is the building circuit pump inside the Vaillan...]]></description>
                        <content:encoded><![CDATA[<p>Dear @derek-m, dear @hughf,</p>
<p>Thanks! No, there is no error message. The pump that I am talking about (the one producing the maximum flow rate) is the building circuit pump inside the Vaillant Aerotherm unit.</p>
<p>I posted this question also on facebook and from the feedback there, it seems it is the normal behaviour for Vaillant heat pumps (and Mitsubishi) to run at a constant flow rate (maximum if possible), while dT is NOT kept constant.</p>
<p>Interesting that you mentioned the PWM. The Grundfos UPS3 manual does go on about this, but I don't know how this would work in this context. The Vaillant controller would have to send the speed command to the unit, but I think it only switches it on and off. The speed/pressure setting of the Grundfos pump is done on the unit via a button. </p>
<p>It seems our unit is simply oversized :( </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28599</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28592</link>
                        <pubDate>Sat, 09 Mar 2024 21:38:42 +0000</pubDate>
                        <description><![CDATA[The secondary pump won’t be pwm controlled, I assume? Why do you have a buffer and secondary pump anyway?]]></description>
                        <content:encoded><![CDATA[<p>The secondary pump won’t be pwm controlled, I assume? Why do you have a buffer and secondary pump anyway?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28592</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28586</link>
                        <pubDate>Sat, 09 Mar 2024 18:13:43 +0000</pubDate>
                        <description><![CDATA[I assume that you have received no error messages indicating some sort of problem.
I believe that PWM controlled water pumps revert to full speed if the control signal is lost, I would ther...]]></description>
                        <content:encoded><![CDATA[<p>I assume that you have received no error messages indicating some sort of problem.</p>
<p>I believe that PWM controlled water pumps revert to full speed if the control signal is lost, I would therefore suggest that you check the relevant plugs and sockets on both the pump motor and the PCB.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28586</guid>
                        <title>Vaillant Aerotherm plus does not reduce flow rate despite low delta T</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28583</link>
                        <pubDate>Sat, 09 Mar 2024 16:51:40 +0000</pubDate>
                        <description><![CDATA[Hi all, I hope someone can help us with this Vaillant ASHP question:
Short version: Delta T is too low, but ASHP pumps at max. flow rate. Should it not reduce the flow rate to get clos...]]></description>
                        <content:encoded><![CDATA[<div class="xdj266r x11i5rnm xat24cr x1mh8g0r x1vvkbs x126k92a">
<div dir="auto">Hi all, I hope someone can help us with this Vaillant ASHP question:</div>
</div>
<div dir="auto"> </div>
<div dir="auto">Short version: Delta T is too low, but ASHP pumps at max. flow rate. Should it not reduce the flow rate to get closer to optimum delta T?</div>
<div dir="auto">Our SCOP/COP is consistently around 2.3.</div>
<div dir="auto">The reason seems to be that the delta T is very low, at only ~1- 2°C usually. </div>
</div>
<div dir="auto">Our house is nice and warm at very low flow T of usually far below 30°C (e.g. target flow 26°C outside T ~9°C, heat curve set to 0.45).</div>
<div dir="auto">According to my understanding, low flow T should come with a very good efficiency, but not in our case!</div>
<div dir="auto">I would expect, that at such low flow T and with a house at the target T, the flow rate in the system should also be very low, so that the heating has time to loose the heat into the room. I think this simulator agrees with my understanding (lower flow -&gt; higher deltaT): https://heatpumps.co.uk/heating-simulator-for-radiators/</div>
<div dir="auto">What we see, is that the ASHP, when the compressor is active, maintains a "Cuilding circuit flow rate" of~1205 l/h consistently. This is the maximum flow rate for our unit (Aerotherm plus 7kW, model name "VWL 75/6 A 230V S").</div>
<div dir="auto">The corresponding building circuit pump power is shown as 53% and this stays very constant as well.</div>
<div dir="auto">
<div dir="auto">Sometimes the control unit shows "compressor shutdown". In this case the flow rate is consistently ~844 l/h and pump power ~35%. This is usually when the flowT==returnT </div>
</div>
<div dir="auto">
<div dir="auto">
<div dir="auto">The minimum flow rate of the ASHP is 540 l/h according to specs. </div>
</div>
</div>
<div dir="auto">
<div dir="auto">I phoned the Vaillant helpline today and he was surprised, that the unit would not regulate the speed down, seeing that the delta T is so low. He suggested trying to set a lower "maximum remaining head" setting from 900 mbar (default) to 750mbar but this showed no effect. I also tried 200 mbar (minimum setting), but this had no effect on the flow rate or pump power. </div>
</div>
<div dir="auto">He then admitted that he didn't know the answer.</div>
<div dir="auto">He suggested a quick test of setting flow temp to 45°C and see what happens. I tested for ~20-30 minutes during which the flow T went up to around 36°C and return T was ~29°C, so dT= 7°C. That shows that with constant flow rate, the dT increased with increased flow T. Not sure exactly what to conclude from this, other than in principle we can have the right dT, but we need to find a way to get the system to run at appropriate flow rate for each situation. In the test I basically only simulated an extreme condition, for which the apparently fixed flow rate of 1205m/l seems to be more appropriate and results in a closer to optimal dT. That confirms that the flow rate should usually be lower, right?</div>
<div dir="auto">
<div dir="auto">Does anyone know, why the flow rate is never regulated down?<br />Do I understand correctly that it should usually be lower, or does it always want to be on maximum flow for some reason, no matter the deltaT?</div>
<div dir="auto">My hope is currently that there is some form of setting somewhere that solves our problem at the push of a button. <br />My fear is, that our system is completely oversized and not capable of working at such low requirements as our little house. </div>
<div dir="auto">
</div>
</div>
<div dir="auto">some general information:</div>
<div dir="auto">Vaillant Aerotherm plus 7kW</div>
<div dir="auto">Only radiators (all new and large) all in a single circuit</div>
<div dir="auto">Installed by British Gas in March 2023</div>
<div dir="auto">89sqm 3-bedroom bungalow, reasonably well insulated. Annual gas consumption before ~10,000 kWh.</div>
<div dir="auto">EPG states ~7500 kWh demand. BG survey states &gt;14,000 kWh demand (?!)</div>
<div dir="auto">45l Vaillant buffer tank</div>
<div dir="auto">Grundfos circulation pump from buffer to radiators. I tested all possible different settings for this one, but none had any effect. All work fine for keeping rooms warm. None affects the ASHP circuit pump at all (logical, I guess,  because the buffer separates )</div>
<div dir="auto">No Temperature sensor in the buffer tank. It often comes up as a potential explanation, but this doesn't seem to be it.</div>
<div dir="auto">Room temp. mode : "Inactive"</div>
<div dir="auto">Heat curve setting: 0.45 (works to get room temp almost exactly to set room T, or slightly above)</div>
<div dir="auto">Room T 19.5°C , setback T 17.5°.</div>
<div dir="auto">Mixergy DHW cylinder. DHW SCOP 1.8 (also not great right?, at least close to what they quoted: 1.7)</div>
</div>
<div class="x11i5rnm xat24cr x1mh8g0r x1vvkbs xtlvy1s x126k92a">
</div>
<div dir="auto">PS: I wrote on the Heat Geek facebook group: https://www.facebook.com/groups/964431597548688/permalink/1343396686318842/ </div>
<div dir="auto">
<div>
<div class="x1n2onr6">
<div class="x1n2onr6 x1swvt13 x1iorvi4 x78zum5 x1q0g3np x1a2a7pz" role="article" aria-label="Comment by Tommy Jones 30 minutes ago">
<div class="x1r8uery x1iyjqo2 x6ikm8r x10wlt62 x1pi30zi">
<div class="xv55zj0 x1vvkbs x1rg5ohu xxymvpz">
<div class="x3nfvp2 x1n2onr6 xxymvpz xh8yej3">
<div class="xdl72j9 x1iyjqo2 xs83m0k xeuugli xh8yej3">
<div class="xmjcpbm x1tlxs6b x1g8br2z x1gn5b1j x230xth x9f619 xzsf02u x1rg5ohu xdj266r x11i5rnm xat24cr x1mh8g0r x193iq5w x1mzt3pk x1n2onr6 xeaf4i8 x13faqbe">
<div class="x1y1aw1k xn6708d xwib8y2 x1ye3gou"><span class=""><span class=""><span class="xt0psk2"><a class="x1i10hfl xjbqb8w x1ejq31n xd10rxx x1sy0etr x17r0tee x972fbf xcfux6l x1qhh985 xm0m39n x9f619 x1ypdohk xt0psk2 xe8uvvx xdj266r x11i5rnm xat24cr x1mh8g0r xexx8yu x4uap5 x18d9i69 xkhd6sd x16tdsg8 x1hl2dhg xggy1nq x1a2a7pz x1heor9g xt0b8zv" role="link" href="https://www.facebook.com/groups/964431597548688/user/1322777345/?__cft__=AZUQqwFHeqCJqF9v9-B-qE2vycWjlAWRpFS9g-ZycBS65RLVX538Ge7YNOXrw7n5SDz-AA6oS7ZgkAON3ScYHqfGyQTDcX4Ckbfr9dZMlx65lxavQCIZqp5IyaspHYtvsm7wtvFYm57WheMdVTOK7bVNDfih0XCRcEIq6Cs7vvdUd_4j1HELY6csWpdcBxupDf4&amp;__tn__=R]-R" aria-hidden="false"><span class="x3nfvp2"><span class="x193iq5w xeuugli x13faqbe x1vvkbs x1xmvt09 x1lliihq x1s928wv xhkezso x1gmr53x x1cpjm7i x1fgarty x1943h6x x4zkp8e x676frb x1nxh6w3 x1sibtaa x1s688f xzsf02u">Tommy Jones</span></span></a> (heat geek installer) replied: "</span></span></span>The buffer and secondary pump won't help.
<div dir="auto">Sounds like your system isn't massive and the secondary pump is probably on fixed speed which will create distortion in the buffer causing the return temp on the ashp to increase, this will prompt the hp to<span> </span>increase pump speed to widen the DT.</div>
<div dir="auto">The 7kw arotherm should tick along between 850 &amp; 1200lph depending on demand."</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
<div>
<div class="x1n2onr6 x1swvt13 x1iorvi4 x78zum5 x1q0g3np x1a2a7pz" role="article" aria-label="Comment by Tina Zöllner 20 minutes ago">
<div class="xqcrz7y x14yjl9h xudhj91 x18nykt9 xww2gxu x1lliihq x1w0mnb xr9ek0c x1n2onr6">
<div class="x1rg5ohu x1n2onr6 x3ajldb x1ja2u2z">
<div class="x14yjl9h xudhj91 x18nykt9 xww2gxu x10l6tqk xhtitgo" data-visualcompletion="ignore">
<div class="x14yjl9h xudhj91 x18nykt9 xww2gxu x78zum5 x6ikm8r x10wlt62 x1n2onr6">
<div> </div>
<div class="x9f619 x1ja2u2z xzpqnlu x1hyvwdk xjm9jq1 x6ikm8r x10wlt62 x10l6tqk x1i1rx1s">I responded: Hi Tommy, thanks! I think your explanation is the opposite of how I understood it. I am of course happy to be corrected to solve our problem: would the ASHP not LOWER its speed to widen dT? i.e. if water runs slower through system it will loose more heat?</div>
</div>
</div>
</div>
</div>
<div class="x1lliihq xjkvuk6 x1iorvi4">
<div class="xdj266r x11i5rnm xat24cr x1mh8g0r x1vvkbs">
<div dir="auto">Our current setting of the Grundfos pump (secondary pump) is "constant curve I", so slowest fixed speed. Anyway, I did try all available settings on that pump, giving it some time, but nothing changed the dT. Other users get excellent COP with the same 7kW unit, same buffer and same pump (upsidedownfork on Youtube).</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/vaillant-aerotherm-plus-does-not-reduce-flow-rate-despite-low-delta-t/#post-28583</guid>
