									The Great British Heat Pump Quiz - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/</link>
            <lastBuildDate>Sun, 08 Nov 2026 01:38:07 +0000</lastBuildDate>
                        <title>RE: The Great British Heat Pump Quiz</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/paged/2/#post-45552</link>
                        <pubDate>Tue, 22 Apr 2025 14:18:36 +0000</pubDate>
                        <description><![CDATA[Not sure how that happened &#x1f923; I suspect that it be a bug on the backend when it works out percentages because there are over 100 questions loaded. On my Heat Pumps 101 course, it defi...]]></description>
<p>I was also delighted that I was awarded the certificate despite failing! Thanks for the fun and the learning experience</p>
<p>Not sure how that happened &#x1f923; I suspect that it be a bug on the backend when it works out percentages because there are over 100 questions loaded. On my Heat Pumps 101 course, it definitely doesn't issue a certificate if a passing grade isn't hit, but there are exactly 10 questions. </p>
<p>But I'm glad you got the certificate. 76% is an amazing achievement!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/paged/2/#post-45552</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/paged/2/#post-45551</link>
                        <pubDate>Tue, 22 Apr 2025 14:10:09 +0000</pubDate>
                        <description><![CDATA[Fail! &#x1f615;  Though I must admit, as a humble, non-techie ASHP owner, I was quite pleased to get 76%. I think the fact that I got so many correct is due to following the posts on the for...]]></description>
                        <content:encoded><![CDATA[<p>Fail! &#x1f615;  Though I must admit, as a humble, non-techie ASHP owner, I was quite pleased to get 76%. I think the fact that I got so many correct is due to following the posts on the forum, so thank-you. I was also delighted that I was awarded the certificate despite failing! Thanks for the fun and the learning experience.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Lizzie</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/paged/2/#post-45551</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45550</link>
                        <pubDate>Tue, 22 Apr 2025 13:21:01 +0000</pubDate>
                        <description><![CDATA[@steve81uk, that&#039;s a cracking score, well done! I designed the quiz so most people with decent low-temp heating knowledge should hit around 80% to pass, while scores between 80-95% are reall...]]></description>
                        <content:encoded><![CDATA[@steve81uk, that's a cr<span>acking score, well done! I designed the quiz so most people with decent low-temp heating knowledge should hit around 80% to pass, while scores between 80-95% are really for those with deep technical know-how of the units inside and out. 93% is </span>still the score to beat.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45550</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45549</link>
                        <pubDate>Tue, 22 Apr 2025 12:58:05 +0000</pubDate>
                        <description><![CDATA[Just had a go at this - scored 83. Not bad for just a homeowner with an ASHP and an interest in system design and how to extract the most efficiency. Many of the questions I got wrong were t...]]></description>
                        <content:encoded><![CDATA[Just had a go at this - scored 83. Not bad for just a homeowner with an ASHP and an interest in system design and how to extract the most efficiency. Many of the questions I got wrong were the technical ones from Graham/Brendan/Patrick that need a little more hardware knowledge.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Steve D</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45549</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45477</link>
                        <pubDate>Fri, 18 Apr 2025 12:58:01 +0000</pubDate>
                        <description><![CDATA[@allyfish thanks for the feedback and glad it was fun!
85% is respectable.]]></description>
                        <content:encoded><![CDATA[<p>@allyfish thanks for the feedback and glad it was fun!</p>
<p>85% is respectable.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45477</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45473</link>
                        <pubDate>Fri, 18 Apr 2025 11:03:04 +0000</pubDate>
                        <description><![CDATA[That was fun, thank you @editor. 85%, which is just as well after 35years in the HVAC industry. Some careless answers on my part, and maybe a couple of ambiguous questions. Some howlers in t...]]></description>
                        <content:encoded><![CDATA[<p>That was fun, thank you @editor. 85%, which is just as well after 35years in the HVAC industry. Some careless answers on my part, and maybe a couple of ambiguous questions. Some howlers in there as well from the pro contributors :)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45473</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45432</link>
                        <pubDate>Thu, 17 Apr 2025 13:52:22 +0000</pubDate>
                        <description><![CDATA[@jamespa amazing. You crushed it! Go here and click View Certificate in the top right hand corner.]]></description>
                        <content:encoded><![CDATA[@jamespa amazing. You crushed it! Go <a href="https://renewableheatinghub.co.uk/courses/the-great-british-heat-pump-quiz/" target="_blank" rel="noopener">here</a> and click View Certificate in the top right hand corner.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45432</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45430</link>
                        <pubDate>Thu, 17 Apr 2025 13:42:16 +0000</pubDate>
                        <description><![CDATA[I paid my fiver and enjoyed the random questions I got.  How do you get the certificate (I passed)]]></description>
                        <content:encoded><![CDATA[<p>I paid my fiver and enjoyed the random questions I got.  How do you get the certificate (I passed)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45430</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45422</link>
                        <pubDate>Thu, 17 Apr 2025 12:58:42 +0000</pubDate>
                        <description><![CDATA[@ashp-bobba DM me two questions, and I&#039;ll add them to the quiz... there are over 100 questions loaded already, but it randomly serves up 100 of those.]]></description>
                        <content:encoded><![CDATA[@ashp-bobba DM me two questions, and I'll add them to the quiz... there are over 100 questions loaded already, but it randomly serves up 100 of those.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45422</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45420</link>
                        <pubDate>Thu, 17 Apr 2025 12:39:26 +0000</pubDate>
                        <description><![CDATA[@editor I thought it was great, I was more focused on what questions the other experts were issuing and wondering what questions I would have offered :)
I also tried to do it at the same ti...]]></description>
                        <content:encoded><![CDATA[<p>@editor I thought it was great, I was more focused on what questions the other experts were issuing and wondering what questions I would have offered :)</p>
<p>I also tried to do it at the same time as helping CB with his Ecodan on here, taking an order, answering the phone and helping my team in the office haha so that my excuse for getting a couple wrong (I also don't know everything ASHP) just enough one might say. </p>
<p>I think it covered a lot of the technical language you hear fired around and highlights the importance of how one element can effect another. Key as always is design, application and commissioning.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/the-great-british-heat-pump-quiz/#post-45420</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 01:38:07 by W3 Total Cache
