									Surface mount or bury primaries for heat pump installation? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/</link>
            <lastBuildDate>Fri, 13 Nov 2026 17:34:43 +0000</lastBuildDate>
                        <title>RE: Surface mount or bury primaries for heat pump installation?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/3/#post-66461</link>
                        <pubDate>Fri, 04 Sep 2026 18:56:07 +0000</pubDate>
                        <description><![CDATA[@jamespa It&#039;s rusting :)]]></description>
                        <content:encoded><![CDATA[@jamespa It's rusting :)]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>tomasmcguinness</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/3/#post-66461</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-66458</link>
                        <pubDate>Fri, 04 Sep 2026 18:48:14 +0000</pubDate>
                        <description><![CDATA[@tomasmcguinness Has it changed colour between photos or is that just the evening light?]]></description>
                        <content:encoded><![CDATA[@tomasmcguinness Has it changed colour between photos or is that just the evening light?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-66458</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-66445</link>
                        <pubDate>Fri, 04 Sep 2026 15:39:59 +0000</pubDate>
                        <description><![CDATA[It&#039;s all in and running!]]></description>
                        <content:encoded><![CDATA[<p>It's all in and running!</p>
15709]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-66445</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-66309</link>
                        <pubDate>Sun, 30 Aug 2026 06:44:16 +0000</pubDate>
                        <description><![CDATA[The installation is almost done!
I&#039;ve written up two posts on my journey so far
Commissioning is the last step!
<p>Hi, </p>
<p>I'm in the early stages of planning my heat pump installation and whilst I know where the pump itself will be sited, I need to work out how to get the water into the garage. The path will see the pipes run up the side access and turn into the garage before getting connected to my heating. The route includes data and power cable.</p>
11508
<p>I have two options.</p>
<p>1. I surface mount the primaries and run them along my neighbour's wall. I then have to either go under the paving or run the pipes up an over. I'll need a bracket of some sort between my neighbour's wall and the heat pump itself as I can't fix them to their failing timber fence. </p>
<p>2. I bury an instulated pipe that holds everything. The problem is that my side access is pretty busy underground with storm, waster and water main pipes. I'm told I should bury the pipe at 600mm, but I don't believe that's possible. At least not all the way. I have photos of this before it was backfilled.</p>
<p>What I want to know is why we can surface mount pipes in insulation, but we're required to put insulated pipes quite deep in the ground.</p>
<p>Has anyone got their primaries buried at a depth less than 600?</p>
<p>The installation is almost done!</p>
<p>I've written up two posts on my journey so far</p>
<p>https://tomasmcguinness.com/2026/08/18/my-heat-pump-installation-part-1/</p>
<p>https://tomasmcguinness.com/2026/08/28/my-heat-pump-installation-part-2/</p>
<p>Commissioning is the last step!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-66309</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64916</link>
                        <pubDate>Wed, 08 Jul 2026 11:50:34 +0000</pubDate>
                        <description><![CDATA[@tomasmcguinness Spot on]]></description>
                        <content:encoded><![CDATA[@tomasmcguinness Spot on]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>pash44pump</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64916</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64915</link>
                        <pubDate>Wed, 08 Jul 2026 11:45:49 +0000</pubDate>
                        <description><![CDATA[@pash44pump I&#039;m glad I made the effort to dig the trench. It&#039;s a much tidier job when nothing is visible.]]></description>
                        <content:encoded><![CDATA[@pash44pump I'm glad I made the effort to dig the trench. It's a much tidier job when nothing is visible.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64915</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64914</link>
                        <pubDate>Wed, 08 Jul 2026 11:41:36 +0000</pubDate>
                        <description><![CDATA[@abernyte seconded. Used to be good friends with my neighbour until I installed solar on the roof facing his garden (fully discussed and agreed) which led to a big falling out afterwards bec...]]></description>
                        <content:encoded><![CDATA[@abernyte seconded. Used to be good friends with my neighbour until I installed solar on the roof facing his garden (fully discussed and agreed) which led to a big falling out afterwards because he didn't like the look of them. Be very wary of using neighbour's wall.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64914</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64776</link>
                        <pubDate>Thu, 02 Jul 2026 16:36:05 +0000</pubDate>
                        <description><![CDATA[@bobflux That&#039;s the stuff. The installer recommended two individual pipes as they have a smaller turning radius. I found the sun&#039;s heat to be very helpful when bending it into place.]]></description>
                        <content:encoded><![CDATA[@bobflux That's the stuff. The installer recommended two individual pipes as they have a smaller turning radius. I found the sun's heat to be very helpful when bending it into place.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64776</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64773</link>
                        <pubDate>Thu, 02 Jul 2026 15:26:04 +0000</pubDate>
                        <description><![CDATA[Watts Microflex Duo, intended for burial, about 45€/m, with 2x 26/32mm Barrier PEX.
It is quite stiff and difficult to manoeuver but it does the job.
                        <content:encoded><![CDATA[<p>Watts Microflex Duo, intended for burial, about 45€/m, with 2x 26/32mm Barrier PEX.</p>
<p>It is quite stiff and difficult to manoeuver but it does the job.</p>
15391
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64773</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64703</link>
                        <pubDate>Mon, 29 Jun 2026 08:37:50 +0000</pubDate>
                        <description><![CDATA[Quick update on this - it&#039;s been quite a long time as progress got delayed due to weather and other priorities!
I ended up with 40m of Microflex UNO pipe. Enough for 18m of flow and return....]]></description>
                        <content:encoded><![CDATA[<p>Quick update on this - it's been quite a long time as progress got delayed due to weather and other priorities!</p>
<p>I ended up with 40m of Microflex UNO pipe. Enough for 18m of flow and return. https://www.watts.eu/en-gb/products/eu/microflex-pre-insulated-piping/pipes-for-heating/1-microflex-uno-6-bar</p>
15351
<p>I managed to get most of the trench down a depth of 50mm, but in some parts it's only 20mm, due to waste pipes.</p>
15352
<p>It was tough going and I had to replace two sections of pipe, which I "disturbed" &#x1f92c; </p>
<p>I added three SWA cables. Power for the heat pump, control for the heat pump and an addition 2.5 for a garden socket (I'm only digging one trench!). Back filled it and added warning tape.</p>
15354
<p>Over the weekend, I shuttered and poured the concrete for the base. I use 12mm hardwood ply and some 2x4s. My wife mixed 0.2m³ of concrete - 22 bags of Blue Circle multi-purpose concrete with Siteworx screed fibres.</p>
15353
<p>Electrician should be coming in the next week or two to get the new circuits wired up and plumber shortly after to take out the boiler and upgrade the plumbing!</p>
<p>Feels like I'm almost there!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/surface-mount-or-bury-primaries/paged/2/#post-64703</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 17:34:43 by W3 Total Cache
