									Samsung Joule Wriggling Out Of Their Warranty - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/</link>
            <lastBuildDate>Fri, 12 Jun 2026 21:23:35 +0000</lastBuildDate>
                        <title>RE: Samsung Joule Wriggling Out Of Their Warranty</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-45003</link>
                        <pubDate>Fri, 04 Apr 2025 15:06:39 +0000</pubDate>
                        <description><![CDATA[@rickk54 I&#039;ve just been looking into warranties and came across your case, which is now two years old, but how did this play out in the end?]]></description>
                        <content:encoded><![CDATA[@rickk54 I've just been looking into warranties and came across your case, which is now two years old, but how did this play out in the end?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-45003</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-16547</link>
                        <pubDate>Sun, 19 Feb 2023 18:14:31 +0000</pubDate>
                        <description><![CDATA[@editor he did the usual resistance checks between phases but it wasn’t conclusive. He has subsequently had it tested and he sent me the videos which proved that the windings were damaged. T...]]></description>
                        <content:encoded><![CDATA[@editor he did the usual resistance checks between phases but it wasn’t conclusive. He has subsequently had it tested and he sent me the videos which proved that the windings were damaged. The assumption is that these were damaged in June and became apparent in January’s cold snap. I worry that the new compressor is also damaged by something within the unit.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>RickK54</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-16547</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-16521</link>
                        <pubDate>Sun, 19 Feb 2023 10:41:43 +0000</pubDate>
                        <description><![CDATA[@rickk54, did the Samsung engineer do any diagnostics before replacing the compressor to ensure that the compressor was indeed at fault?]]></description>
                        <content:encoded><![CDATA[@rickk54, did the Samsung engineer do any diagnostics before replacing the compressor to ensure that the compressor was indeed at fault?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-16521</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-16511</link>
                        <pubDate>Sat, 18 Feb 2023 23:11:45 +0000</pubDate>
                        <description><![CDATA[An interesting twist with this one. The engineer from Joule was on the verge of sanctioning a replacement compressor and mains connector under warranty when his boss overruled him and said t...]]></description>
                        <content:encoded><![CDATA[<p>An interesting twist with this one. The engineer from Joule was on the verge of sanctioning a replacement compressor and mains connector under warranty when his boss overruled him and said that it wasn’t a warranty claim. He said that the failed isolator back in June last year caused the compressor failure in January this year. <br /><br />it also turns out that Joule engineer was wrong about an electrical component missing inside the Samsung unit. This was the connection from the isolator switch to the Samsung box…it turned out to be a Buck standard plastic isolator block which is still in the unit….not tampered with after all. Surely this would be enough to convince them to cover it but no! </p>
<p>In the end we have paid a Samsung approved engineer to replace the compressor at our cost of just under £1,000. We were hoping that this would fix things. It did for 15 hours and then we got an E464 error. Basically the same issue.</p>
<p>This is starting to rack up costs as chances are our engineer will want to change the PCBs too.</p>
<p>I officially hate Samsung Joule - potential buyers look elsewhere! </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-16511</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15561</link>
                        <pubDate>Sat, 04 Feb 2023 10:55:52 +0000</pubDate>
                        <description><![CDATA[Thank you for your advice. We’re not out of the woods yet but it seems like we’re winning as Samsung are going to provide a new compressor and termination block under warranty. We’re still d...]]></description>
                        <content:encoded><![CDATA[<p>Thank you for your advice. We’re not out of the woods yet but it seems like we’re winning as Samsung are going to provide a new compressor and termination block under warranty. We’re still discussing labour but a result so far. Shouldn’t be like this really. We’ve been without it now for almost 2 weeks and relying on old fashioned electric radiators and an immersion with a COP of 1!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15561</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15379</link>
                        <pubDate>Thu, 02 Feb 2023 08:34:42 +0000</pubDate>
                        <description><![CDATA[@rickk54, let us know what the outcome is.]]></description>
                        <content:encoded><![CDATA[@rickk54, let us know what the outcome is.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15379</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15365</link>
                        <pubDate>Wed, 01 Feb 2023 17:51:31 +0000</pubDate>
                        <description><![CDATA[@editor Thank you. Joule are taking it up with Samsung. Hope to hear the final judgement tomorrow. Fingers are crossed!]]></description>
                        <content:encoded><![CDATA[@editor Thank you. Joule are taking it up with Samsung. Hope to hear the final judgement tomorrow. Fingers are crossed!]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15365</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15364</link>
                        <pubDate>Wed, 01 Feb 2023 17:02:40 +0000</pubDate>
                        <description><![CDATA[@rickk54, I&#039;ll see if I can get you answers on this. Will keep you posted.]]></description>
                        <content:encoded><![CDATA[<p><span>@rickk54, I'll see if I can get you answers on this. Will keep you posted.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15364</guid>
                        <title>RE: Samsung Joule Wriggling Out if Their Warranty</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15333</link>
                        <pubDate>Wed, 01 Feb 2023 11:08:18 +0000</pubDate>
                        <description><![CDATA[Five words - &#039;I&#039;ll see you in court&#039;]]></description>
                        <content:encoded><![CDATA[<p>Five words - 'I'll see you in court'</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15333</guid>
                        <title>Samsung Joule Wriggling Out Of Their Warranty</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15332</link>
                        <pubDate>Wed, 01 Feb 2023 10:50:58 +0000</pubDate>
                        <description><![CDATA[We have a Samsung Joule ASHP which developed major issues during the recent cold snap. We were getting E461 errors which were caused by compressor start up issues. The compressor sounded rou...]]></description>
                        <content:encoded><![CDATA[We have a Samsung Joule ASHP which developed major issues during the recent cold snap. We were getting E461 errors which were caused by compressor start up issues. The compressor sounded rough too. Our installer checked it out and diagnosed that it was a compressor issue which likely needed to be replaced. <br /><br /><br />With that I called Joule to say I was looking at a warranty claim. They sent an engineer out who spent the first 30 minutes looking at the software and hardware for any reason to void the warranty.<br /><br />He did find something. Back in June we had power failure to the outside unit. It turned out that the connector block was burned out. Our site electrician fitted a new block and we were back up and running.<br /><br />The Joule engineer made a big thing of this and said the unit had been tampered with. He made a big thing of this in his report.<br /><br />Technically he might be correct but it is the finest of fine lines here. It’s the house connection to the unit. It’s not like we changed a PCB or anything!<br /><br />I’ve just had a call from Joule saying that they will call Samsung but they’re not hopeful. <br /><br />It seems mad to me and we could be losing a 7 year warranty over a technicality. <br /><br />Has anyone else had a similar experience and how did they handle it?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/samsung-joule-wriggling-out-if-their-warranty/#post-15332</guid>
Object Caching 56/62 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-06-12 22:23:35 by W3 Total Cache
