									7.5kW Heat Loss, But Quoted a 10kW Midea. No Re-Pipe, No Buffer Tank. Does This Add Up? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/</link>
            <lastBuildDate>Fri, 15 May 2026 02:35:32 +0000</lastBuildDate>
                        <title>RE: 7.5kW Heat Loss, But Quoted a 10kW Midea. No Re-Pipe, No Buffer Tank. Does This Add Up?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/paged/2/#post-61628</link>
                        <pubDate>Sun, 12 Apr 2026 20:31:55 +0000</pubDate>
                        <description><![CDATA[Oh, how I love these old scientists!I&#039;m in with your 5 kW -- thanks, that helped a lot.Overall, I enjoy this conversation very much.I do, while any outsider invariably will think &#039;Oh, it&#039;s  ...]]></description>
                        <content:encoded><![CDATA[<p>Oh, how I love these old scientists!<br />I'm in with your 5 kW -- thanks, that helped a lot.<br />Overall, I enjoy this conversation very much.<br /><br />I do, while any outsider invariably will think 'Oh, it's  t h a t  typical, asking five self-appointed experts and you get six opinions at least!' Which again is true and indeed any first real-expert answer will be 'That depends on ....' with something following no layman can and wants to cope with .... sorry.<br />When any expert answer turns out to be inaccurate, defence will be 'This is because ....' with something following .... etc.<br /><br />In this thread the 'because' is, because there is no real data set, we rely on estimations, and the one which OldScientist put in seems me the best available by now.<br />To get closer, we would need to go the full mile about square meters, wall build, window types, thermal bridges, radiator wattage, and last not least flow resistance, some of which is difficult to see without a dowsing rod, crystal ball and a pair of radar glasses.<br />When in doubt, we need to estimate, guess, predict and forecast, and while doing so, try to cover uncertainties by 'laying to the safe side', with the safe side being something different for anyone involved. And when uncertainties add, whole-number factors will result sooner or later, to one 'safe' side or another. <br />For an installer, 'safe' mostly will be a big heat source, for me here, it's an hydraulic system which can cope with the heat offered. <br /><br />So I assume that even an experienced engineer on-site would have trouble to supply a conclusive answer to the question given in the headline, without the possibility of seeing into walls and listening to water flow.<br /><br />Admittedly, some measuring can be done, but when a pro will be paid for, 't will come out as total write-off -- far too expensive. <br />So it's left to you, Penval, the house owner, to own this problem and to run trials, mimicking heat pump operation, make notes of what the system will show, and discuss here or elsewhere.<br />Or to rely on your installer.<br />Or to pick one of our many opinions.<br />I will be highly interested about any outcome, as, I am sure, many others here -- keep us updated!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>LeJamaisContent</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/paged/2/#post-61628</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61610</link>
                        <pubDate>Sun, 12 Apr 2026 07:09:49 +0000</pubDate>
                        <description><![CDATA[Our house is not dissimilar to yours on paper. We had a heat loss calculation of around 7.4kW and previously used around 1600-1800L of oil per year, so same ballpark. We&#039;ve had some insulati...]]></description>
                        <content:encoded><![CDATA[<p>Our house is not dissimilar to yours on paper. We had a heat loss calculation of around 7.4kW and previously used around 1600-1800L of oil per year, so same ballpark. We've had some insulation upgrades, and because we only heat to 20C, the actual heat loss is probably more like 5kW (I don't think we have ever delivered more than 120kW of heat in a 24h period)</p>
<p>We have a 12kW Samsung ASHP, which is actually a 16kW unit software limited to 12kW, and hence can only modulate down to around 4kW minimum output (see @bobflux comments above)</p>
<p>Whilst clearly oversized, we have not found that to overly limit it's efficiency (in fact we are really happy with it's performance). With temps below ~7C we can just about run continuously during the day, and we turn off overnight. Below 5C and we only turn off overnight for around 4h and back on at 4am during our cheap rate slot. If it's around 2C or below, we can run continuously. During milder spring and autumn periods like we are currently having, we may run for a few hours then turn off for a few hours as required, which doesn't affect efficiency. In warmer weather we may turn it on for an hour or two when we first get up, and maybe again for an hour in the evening which is sufficient, so almost like a conventional boiler. All the time we are running a flow temp of 32C due to large radiators, hence it is efficient.</p>
<p>My point is an oversized heat pump isn't necessarily the disaster you may first think, so I certainly would not discount a 10kW unit on a 7.5kW heat loss. And it has some benefits too - you are not continuously operating the unit at the top end of range where it is less efficient, and the DHW reheat times are shorter which you have already highlighted as a potential issue (we can reheat our 160L cylinder in around 20mins). Further, a 10kW unit may only achieve 10kW output under very specific conditions so you may not have as much headroom as the headline figure suggests when it's -3C outside. Overall, a nominally 10kW unit on a 7.5kW heat loss does not seem unreasonable to me. </p>
<p>I'd go so far as to say the actual size of the unit, assuming it is large enough, potentially has less impact than the rest of the system design. The system pipework must be capable of sufficient flow to carry the required amount of heat. If the existing pipework is capable of doing this, it doesn't need replacing. Emitters should be as large as possible - bigger radiators equates to lower flow temperatures which equals lower running costs. Obviously there is a cost trade off between replacing all radiators with the savings that will come from lower flow temperatures. How low you can go with flow temperatures will also be limited by the size of your radiators and the minimum output of your heat pump. For example, the minimum output of our heat pump is ~4kW, and our radiators need a flow temperature of at least 32C to be able to dissipate that amount of heat, so that is the lowest we can effectively go. If we need less heat than that, we are cycling on/off as required. </p>
<p>I definitely agree with others that 99% of homes do not require a buffer tank, although many will benefit from a volumiser (make sure you understand the difference). I would view a buffer tank as a major red flag and discount any quote/installation specifying one on that basis.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61610</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61609</link>
                        <pubDate>Sun, 12 Apr 2026 07:00:01 +0000</pubDate>
                        <description><![CDATA[Second thought, sorry:What I said about 6 kW instead of 7.5 kW against 10 kW, was under the assumption, that at 1600 or 1800 l oil per year the indoor temperature would be around 20°C every ...]]></description>
                        <content:encoded><![CDATA[<p>Second thought, sorry:<br /><br />What I said about 6 kW instead of 7.5 kW against 10 kW, was under the assumption, that at 1600 or 1800 l oil per year the indoor temperature would be around 20°C every day with the usual set back at night.<br /><br />Without knowledge of this being a really good idea, with 1600 l on my own flat I would go to 4 kW at -2°C and think this would work out gladly.<br />A lot of attention then I would put to the temperature range above freezing point -- if there was any evidence that the HP might put too much focus on defrosting, I would switch to the next bigger model.<br />This said, I would strive towards 4 kW @ -2°C (as already said), 3 kW @ 4°C and 2 kW @ 10°C.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61609</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61608</link>
                        <pubDate>Sat, 11 Apr 2026 19:43:53 +0000</pubDate>
                        <description><![CDATA[No buffer, check.No re-pipe, check.6 kW would add up better imo, 10 kW doesn&#039;t at all. Big pump bringing a 200-day-per-year risk of too little demand and HP hiccoughing, small pump a 10-days...]]></description>
                        <content:encoded><![CDATA[<p>No buffer, check.<br />No re-pipe, check.<br />6 kW would add up better imo, 10 kW doesn't at all. Big pump bringing a 200-day-per-year risk of too little demand and HP hiccoughing, small pump a 10-days-per-year risk of having to boost the living room with an oil radiator or like. <br />With 10% undersized rads, 45°C FT is reached soon enough. At such FT you can just loop the DHW into the system temporarily and suffer no waiting times in cold weather. Limitation indeed, you must find a controller which can manage such scenario. Details we would need to discuss here, but I think it's feasible.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61608</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61530</link>
                        <pubDate>Fri, 10 Apr 2026 05:04:15 +0000</pubDate>
                        <description><![CDATA[Yes it&#039;s a shame the manufacturers make this vital information so difficult to access!]]></description>
                        <content:encoded><![CDATA[<p>Yes it's a shame the manufacturers make this vital information so difficult to access!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61530</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61514</link>
                        <pubDate>Thu, 09 Apr 2026 17:25:34 +0000</pubDate>
                        <description><![CDATA[@bobflux
I agree that its a simplification but I think its more serious than flow rate.  An overestimate of house heat loss can result in unnecessary re-plumbing, excessive cycling at relat...]]></description>
                        <content:encoded><![CDATA[<p>@bobflux</p>
<p>I agree that its a simplification but I think its more serious than flow rate.  An overestimate of house heat loss can result in unnecessary re-plumbing, excessive cycling at relatively low temperatures and the heat pump operating permanently at an inefficient point of the compressor curve.  The first is very disruptive and the 2nd and 3rd can significantly reduce COP.    In worst case it can result in a system that is very difficult to control, as we have seen with a couple of low loss (3kW) houses that have been fitted with massively oversized heat pumps or, at the other end of the spectrum, an unnecessary cascade with all the complexity that involves, which we have also seen more than once here.   So IMHO oversizing should be taken as seriously as undersizing.</p>
<p>Your point about ranges is well made.  Daikin likewise only do 2 hardware variants, 8kW and 16kW, everything else is simply software limited.  The Vaillant 3kW is just a limited 5kW and the 10kW a limited 12kW., others do similar.  Reference should always be made to the output table (sometimes difficult to find!), which should specify minimum as well as maximum output.  Also don't forget that the <em>interesting</em> comparison is minimum at high OAT/Low FT vs maximum at low OAT/High FT.  This is often only a 3:1 ratio or a bit less unless (sometimes dirty) tricks have been played by the HP manufacturer artificially to extend it.  Of course with software limited variants it will be less still.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61514</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61512</link>
                        <pubDate>Thu, 09 Apr 2026 16:43:48 +0000</pubDate>
                        <description><![CDATA[IMO &quot;Oversizing the heat pump&quot; is a bit of an over simplification.
What really matters is what water flow rate the heat pump likes, and its modulation range. Oversizing becomes a problem if...]]></description>
                        <content:encoded><![CDATA[<p>IMO "Oversizing the heat pump" is a bit of an over simplification.</p>
<p>What really matters is what water flow rate the heat pump likes, and its modulation range. Oversizing becomes a problem if the heat pump wants a flow rate the piping can't deliver, or it can't modulate low enough so it cycles a lot. That depends quite a bit on manufacturer, model, etc.</p>
<p>Quite often several models from the same manufacturer quote different power numbers but they're the same heat pump with different software settings, ie different upper limits on the modulation range, but the lower limit is the same. In this case, if the required power is below the lower limit, the smaller heat pump will cycle just as much as the bigger one.</p>
<p>Then there's what the heat pump decides to do with the flow. For example my LG 16kW has a modulation range of about 3.5-16 kW. While the nominal flow specified in the docs is 2.7 m3/h which is huge, it doesn't care much about it and it is perfectly happy working at half that, deltaT simply increases. This wastes a bit of efficiency but it's not a nightmare scenario. It will only throw an error and shut down if flow is ridiculously low and deltaT gets over 20°C. On the other hand, some other brands' software may be a lot pickier about flow and decide to throw errors and shut down much more easily.</p>
<p>Another example, I don't know about Midea so I'll give numbers for LG. They sell two monoblocs, 16kW and 9kW. Then the 12-14kW are the 16kW with software limit, and the 7kW is the 9kW with software limit. In this case, whether you get the 7 or the 9, it's the same heat pump. But going to 12kW would mean an increase in the lower limit of the modulation range, which may be an issue. What I mean is, just because you pick the heat pump size "just right" doesn't mean the low end of the modulation range lands where you need it.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61512</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61510</link>
                        <pubDate>Thu, 09 Apr 2026 14:40:50 +0000</pubDate>
                        <description><![CDATA[Many thanks to all. Really appreciate and will try to answer questions asap. We have one more quote to come so time to read review of the install.]]></description>
                        <content:encoded><![CDATA[<p>Many thanks to all. Really appreciate and will try to answer questions asap. We have one more quote to come so time to read review of the install. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Penval</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61510</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61479</link>
                        <pubDate>Wed, 08 Apr 2026 20:37:17 +0000</pubDate>
                        <description><![CDATA[I am going to review the whole thing, every inch, how hard or easy to install, how it fits or it will not fit, what it costs and so on. we install on Monday next week for the week, it should...]]></description>
<p>@ashp-bobba </p>
<p>That is a very interesting new angle on how to use the Adia technology, basically to 'deal' with some edge cases where the alternative is massive disruption or taking a risk that loss is in fact overestimated.</p>
<p>I'm looking forward to hearing the results!  With a few hours of cheap leccy and this level of intelligence, I can see that quite a few iffy cases suddenly become clear.</p>
<p>I am going to review the whole thing, every inch, how hard or easy to install, how it fits or it will not fit, what it costs and so on. we install on Monday next week for the week, it should only take 3 days but I gave us the week so we can film and comment, review and discuss.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61479</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61478</link>
                        <pubDate>Wed, 08 Apr 2026 20:34:50 +0000</pubDate>
                        <description><![CDATA[@ashp-bobba 
That is a very interesting new angle on how to use the Adia technology, basically to &#039;deal&#039; with some edge cases where the alternative is massive disruption or taking a risk th...]]></description>
                        <content:encoded><![CDATA[<p>@ashp-bobba </p>
<p>I'm looking forward to hearing the results!  With a few hours of cheap leccy and this level of intelligence, I can see that quite a few iffy cases suddenly become clear.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/retrofit-ashp-choices/#post-61478</guid>
