									rad size and efficiency - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/</link>
            <lastBuildDate>Sun, 06 Sep 2026 21:44:58 +0000</lastBuildDate>
                        <title>RE: rad size and efficiency</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43253</link>
                        <pubDate>Fri, 28 Feb 2025 16:08:33 +0000</pubDate>
                        <description><![CDATA[Adia Thermal sort of advocate this approach and produce some hardware to aid the determination.
In many cases however it will be obvious that an upgrade is needed, best in my view to do the...]]></description>
<p>what if i set the system so its controlling on flow temp only, surely it would then just be a case of seeing which rooms dont get to 20c and upgrade those?</p>
<p>Adia Thermal sort of advocate this approach and produce some hardware to aid the determination.</p>
<p>In many cases however it will be obvious that an upgrade is needed, best in my view to do the calculations up front.  If any are marginal then you could adopt the suck it and see approach for those.  You need an increase in area of a factor of 2 or more if you move from a system designed for a boiler at a flow temp of 70C to a system designed for a heat pump at 45C, but if you have added insulation since the original installation, or the rads were anyway oversized, some may be reusable (some of mine were)</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43253</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43241</link>
                        <pubDate>Fri, 28 Feb 2025 11:19:47 +0000</pubDate>
                        <description><![CDATA[@adamk Yes you can to that. I never use old radiators. If the customer insiste, I walk away, it is not worth it.]]></description>
                        <content:encoded><![CDATA[@adamk Yes you can to that. I never use old radiators. If the customer insiste, I walk away, it is not worth it.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>BU</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43241</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43239</link>
                        <pubDate>Fri, 28 Feb 2025 11:00:28 +0000</pubDate>
                        <description><![CDATA[@heacol 
what if i set the system so its controlling on flow temp only, surely it would then just be a case of seeing which rooms dont get to 20c and upgrade those?]]></description>
                        <content:encoded><![CDATA[<p>@heacol </p>
<p>what if i set the system so its controlling on flow temp only, surely it would then just be a case of seeing which rooms dont get to 20c and upgrade those?</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AdamK</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43239</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43237</link>
                        <pubDate>Fri, 28 Feb 2025 10:40:37 +0000</pubDate>
                        <description><![CDATA[It is just thermodynamics, the higher you move the flow temperature the more it will cost to run, existing radiators may need a higher flow temperature so the heat pump will cost more to run...]]></description>
                        <content:encoded><![CDATA[<p>It is just thermodynamics, the higher you move the flow temperature the more it will cost to run, existing radiators may need a higher flow temperature so the heat pump will cost more to run, your radiator upgrade, will usually be paid for in less than 2 heating seasons.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43237</guid>
                        <title>rad size and efficiency</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43236</link>
                        <pubDate>Fri, 28 Feb 2025 10:19:02 +0000</pubDate>
                        <description><![CDATA[im going to have a Vaillant fitted and just see how it runs with the rads i have currently. how does having potentially undersized rads affect efficiency? or does it only affect comfort? ass...]]></description>
                        <content:encoded><![CDATA[<p>im going to have a Vaillant fitted and just see how it runs with the rads i have currently. how does having potentially undersized rads affect efficiency? or does it only affect comfort? assuming im controlling on weather comp?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/rad-size-and-efficiency/#post-43236</guid>
Served from: renewableheatinghub.co.uk @ 2026-09-06 22:44:58 by W3 Total Cache
