									Pleurococcus on my fins - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/</link>
            <lastBuildDate>Tue, 06 Oct 2026 16:12:25 +0000</lastBuildDate>
                        <title>RE: Pleurococcus on my fins</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/#post-23526</link>
                        <pubDate>Thu, 23 Nov 2023 08:42:29 +0000</pubDate>
                        <description><![CDATA[I’m inclined to agree with Ally. Don’t use anything abrasive. Have you tried a soft brush with soapy water? A mild vinegar solution could also work. I’d apply the solution to the fins with a...]]></description>
                        <content:encoded><![CDATA[<p>I’m inclined to agree with Ally. Don’t use anything abrasive. Have you tried a soft brush with soapy water? A mild vinegar solution could also work. I’d apply <span>the solution to the fins with a spray bottle and let it sit for 10-15 minutes before rinsing it off with clean water.</span></p>
<span></span>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/#post-23526</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/#post-23478</link>
                        <pubDate>Tue, 21 Nov 2023 21:14:47 +0000</pubDate>
                        <description><![CDATA[There are specialist cleaning solutions for heat exchanger fin coils. I would recommend you have the heat exchanger cleaned as part of a professional service. A diluted bleach solution would...]]></description>
                        <content:encoded><![CDATA[<p>There are specialist cleaning solutions for heat exchanger fin coils. I would recommend you have the heat exchanger cleaned as part of a professional service. A diluted bleach solution would kill any biological growth, but needs to be carefully applied. Don't steam clean or apply under high pressure, e.g.: not with a pressure washer. Most ASHP coil fins ae aluminium, copper is much more expensive and used in commercial applications, it's naturally resistant to biological growth.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/#post-23478</guid>
                        <title>Pleurococcus on my fins</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/#post-23475</link>
                        <pubDate>Tue, 21 Nov 2023 18:59:43 +0000</pubDate>
                        <description><![CDATA[Here in Somerset it is seldom dry and I&#039;ve begun to notice that our heat pump fins are turning a bit green. This is pleurococcus and I&#039;m sure it will reduce the efficiency a bit.
I&#039;m thinkin...]]></description>
                        <content:encoded><![CDATA[<p>Here in Somerset it is seldom dry and I've begun to notice that our heat pump fins are turning a bit green. This is pleurococcus and I'm sure it will reduce the efficiency a bit. https://herbaria.plants.ox.ac.uk/bol/plants400/profiles/OP/Pleurococcus</p>
<p>I'm thinking of spraying the fins with 'Patio Magic' which I use on the patio, fence and conservatory when they look a bit green. Any thoughts? </p>
<p>https://www.lovethegarden.com/uk-en/patio-magic</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/pleurococcus-on-my-fins/#post-23475</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-06 17:12:25 by W3 Total Cache
