									One room is colder than the rest of the house - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/</link>
            <lastBuildDate>Sat, 14 Nov 2026 17:46:52 +0000</lastBuildDate>
                        <title>RE: One room is colder than the rest of the house</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/paged/2/#post-51428</link>
                        <pubDate>Tue, 28 Oct 2025 15:03:34 +0000</pubDate>
                        <description><![CDATA[@jamespa thanks for all the advice.  Just so you know, I&#039;m not ignoring it but pulling it together to try and work out a plan of action.  I&#039;m currently measuring what the rooms are heating t...]]></description>
<p>Yes.  There is nothing sacrosanct about DT5 even on aggregate, and certainly not for any individual radiator.  Furthermore if all the rads have been balanced for DT5 then its possible that all have LSVs turned down, whereas at least one, preferably several, should be fully open.</p>
<p>Installers, if they balance at all, will usually balance for equal deltaT on the basis that this is how the system was designed, it can be done relatively quickly, and if all the calculations are correct this <em>should</em> result in the design room temperatures.   But design loss and actual loss are two different things so in practice a basic balance for deltaT may need to be tweaked to get the desired room temps.  Turning down one LSV is unlikely to have a major effect on others and yes its generally a better approach than turning down the TRV if only because it ensures that the volume of the radiator is always in circuit to help with cycling and defrost.</p>
<p>If <em>all</em> your upstairs rooms are reaching 24-25 then turning down all the LSVs may not be the thing to do (but neither is having them all switching on and off on TRVs).  More likely you could turn up some of the LSVs downstairs (reducing deltaT and thus raising output), perhaps turn them down a bit upstairs, and reduce the WC curve a tad.</p>
<p>@toodles has written an article on <a href="https://renewableheatinghub.co.uk/radiator-balancing-lockshield-valve-guide/" target="_blank" rel="noopener">balancing</a> for equal room temp/desired temp differences (as opposed to balancing for DeltaT); its worth a read.</p>
<p>That said one doesn't have to get obsessive about eliminating TRVs.  I have one out of ~14 rads on a TRV, its in the 'visitor' bedroom and I do it as a courtesy to visitors.  I started off with all the upstairs on TRVs and all the downstairs open loop, but gradually adjusted the LSVs until the TRVs became unnecessary.  Some installers will say TRVs upstairs, open downstairs.  That's not optimum but not completely silly, however it does risk roughly halving the system volume if they all shut down simultaneously, which will half cycle time (bad) at any given set of conditions and reduces the water available for defrost.</p>
<p>@jamespa thanks for all the advice.  Just so you know, I'm not ignoring it but pulling it together to try and work out a plan of action.  I'm currently measuring what the rooms are heating to so I have an idea at least of what might need doing.  So far, the Lounge, which contains the Primary Pod is ranging between 21.8c and 22.5c; the kitchen is between 21.6c and 21.9c; the dining area follows the lounge quite closely (perhaps 0.2c warmer); the hallway is running at around 0.5c warmer than the lounge.  Upstairs the rooms I've measured are running at around 23c to 25c.  </p>
<p>Anyway, as I say I'm pulling together all the advice to act on.  I also have a call out with Octopus to try and speak to someone in more detail about how the Cosy works.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AndrewJ</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/paged/2/#post-51428</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/paged/2/#post-51425</link>
                        <pubDate>Tue, 28 Oct 2025 14:54:32 +0000</pubDate>
                        <description><![CDATA[Honestly, I don&#039;t know.  I can see that it is ramping up to 1.75kWh of power but on other occasions it might be around 0.7kWh.
<p>Is that because it's putting out more heat than the property requires at this time of year? ASHPs can only modulate their output so low (typically to around a third to a quarter of full output) and achieving continuous running is not always possible this time of year as even at minimum output the heat pump may still be cycling or turning on/off by the thermostat (depending how it's been set up).</p>
<p>Honestly, I don't know.  I can see that it is ramping up to 1.75kWh of power but on other occasions it might be around 0.7kWh.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/paged/2/#post-51425</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51408</link>
                        <pubDate>Tue, 28 Oct 2025 12:32:47 +0000</pubDate>
                        <description><![CDATA[Is that because it&#039;s putting out more heat than the property requires at this time of year? ASHPs can only modulate their output so low (typically to around a third to a quarter of full outp...]]></description>
<p>@andrewj The advantage of making the adjustment on the LSV is that the setting is a constant rather than a variable one and this ‘constant load’ is much better for the ‘low and slow’ operation of a heat pump. Gas boilers were frequently running dynamically but heat pumps benefit from a constant flow resistance from the emitters. Regards, Toodles.</p>
<p>I'm finding that the Octopus Cosy doesn't work like that but cycles around the thermostat temp.  Still trying to get a little more info out of Octopus before I look at the approach @jamespa has detailed in other posts.</p>
<p>Thanks both - I'll take a look at adjusting LSVs and read your article about balancing Toodles.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51408</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51327</link>
                        <pubDate>Mon, 27 Oct 2025 20:41:04 +0000</pubDate>
                        <description><![CDATA[I would personally be sceptical about reaching any conclusion that goes against the norm of heat pumps.  In the end the Cosy is a heat pump, subject to the same laws of thermodynamics  as ev...]]></description>
<p>I would personally be sceptical about reaching any conclusion that goes against the norm of heat pumps.  In the end the Cosy is a heat pump, subject to the same laws of thermodynamics  as every other heat pump, which are pretty dominant in both the way they work and the factors that affect efficiency.  Its true Octopus might have played games with the controller but if they were particularly clever games other manufacturers would likely do the same.  Most likely they behave in one of a small number of obvious ways.</p>
<p>The cycling around the thermostat temp is (almost certainly) because the thermostat the primary control for the heat pump rather than the weather comp curve.  Put another way the weather comp curve is set higher than it needs to be to maintain the desired temp.  As a result the room overheats, the heat pump is then is cut off by the thermostat, and once the temp has dropped the heat pump switches back on again.  Most if not all heat pumps can work like this and so long as the WC curve isnt too far out its not a bad way to operate.  However its generally best for comfort and cost first to get the C curve as close (ie as low) as possible.  If you do that its quite possible that you will conclude that the thermostat control isnt needed at all and so will set it above the desired temp so it has no effect.  Some heat pumps have a specific setting to disable it.</p>
<p>My Vaillant can operate in this mode.  At either end of the season I do operate it this way to deal with solar gain, which becomes significant.  However by now I have switched to pure weather compensation; the internal room temperature sensor is disabled from having any real time controlling effect.  This is more comfortable in my house, but of course that is house and person dependent.</p>
<p>One thing that isn't at all clear is whether the room temp setting on the Octopus also modifies the WC curve.  On the Vaillant and a few other heat pumps it does.   There are two ways this could work (both of which are available on the Vaillant ans some other heat pumps).  One is that the WC curve you set assumes a target room temperature of (say) 20C, and if you set the target temp to something else the WC curve is displaced but otherwise the room temp setting has no 'real time' effect.  Another way is that the room temp setting is used 'real time' to adapt the WC curve in an attempt to adjust to the house.  Generally the adaption is limited in extent only to a limited extent to prevent the control loop becoming unstable.</p>
<p>We dont know which (or which combination) of the above Octopus applies, unfortunately as the instruction manual is a bit dumbed down, but I think its likely its one or a combination of these, possibly selectable in the installer menu.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51327</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51316</link>
                        <pubDate>Mon, 27 Oct 2025 18:45:14 +0000</pubDate>
                        <description><![CDATA[I&#039;m finding that the Octopus Cosy doesn&#039;t work like that but cycles around the thermostat temp.  Still trying to get a little more info out of Octopus before I look at the approach @jamespa ...]]></description>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51316</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51308</link>
                        <pubDate>Mon, 27 Oct 2025 17:30:11 +0000</pubDate>
                        <description><![CDATA[@andrewj The advantage of making the adjustment on the LSV is that the setting is a constant rather than a variable one and this ‘constant load’ is much better for the ‘low and slow’ operati...]]></description>
                        <content:encoded><![CDATA[@andrewj The advantage of making the adjustment on the LSV is that the setting is a constant rather than a variable one and this ‘constant load’ is much better for the ‘low and slow’ operation of a heat pump. Gas boilers were frequently running dynamically but heat pumps benefit from a constant flow resistance from the emitters. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51308</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51307</link>
                        <pubDate>Mon, 27 Oct 2025 17:29:50 +0000</pubDate>
                        <description><![CDATA[Yes.  There is nothing sacrosanct about DT5 even on aggregate, and certainly not for any individual radiator.  Furthermore if all the rads have been balanced for DT5 then its possible that a...]]></description>
<p>Is this true even at the expense of DeltaT?  My bathrooms upstairs rooms are reaching 24-25c with TRVs fully open but were recently balanced to a DeltaT of 5c along with all other radiators.  I presume by closing down the LSV it will have an impact elsewhere in the system and other radiators would need to be re-balanced?  Is that still a better approach than turning down the TRV?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51307</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51306</link>
                        <pubDate>Mon, 27 Oct 2025 17:13:46 +0000</pubDate>
                        <description><![CDATA[Is this true even at the expense of DeltaT?  My bathrooms upstairs rooms are reaching 24-25c with TRVs fully open but were recently balanced to a DeltaT of 5c along with all other radiators....]]></description>
<p>.... the latter adjusted on the lockshield valve not by fiddling with TRVs ...</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51306</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51303</link>
                        <pubDate>Mon, 27 Oct 2025 17:00:25 +0000</pubDate>
                        <description><![CDATA[Its key to understand this, and it applies more generally.  &#039;Unheated&#039; rooms are in fact heated from adjacent rooms, which means that the rads in those rooms need a higher flow temperature t...]]></description>
<p>i hadnt really considered the heat loss reducing on the 1st floor. that makes sense.</p>
<p>Its key to understand this, and it applies more generally.  'Unheated' rooms are in fact heated from adjacent rooms, which means that the rads in those rooms need a higher flow temperature than would otherwise be the case in order to increase their output, which reduces efficiency. </p>
<p>Thus it doesn't necessarily save money to leave rooms unheated unless they settle at a very low temperature.  This is rarely the case because insulation between rooms is almost invariably much poorer than insulation between the house and the outside world.</p>
<p>Generally the most efficient and cheapest way to run a heat pump is 24*7 with all rooms heated to within 3C of each other, the latter adjusted on the lockshield valve not by fiddling with TRVs, which should (like thermostats) normally either be set to maximum or to 2C above target temperature if the room tends to overheat due to solar gain.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51303</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51301</link>
                        <pubDate>Mon, 27 Oct 2025 16:52:47 +0000</pubDate>
                        <description><![CDATA[@pie_eater This may be the reason that the prospective installers had suggested replacing some radiators with higher output? Oversized emitters may be ‘throttled back’ via the LSV whereas an...]]></description>
                        <content:encoded><![CDATA[@pie_eater This may be the reason that the prospective installers had suggested replacing some radiators with higher output? Oversized emitters may be ‘throttled back’ via the LSV whereas an emitter that cannot provide sufficient oomph when fully open will not provide the level of comfort you may require. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/one-colder-room/#post-51301</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 17:46:52 by W3 Total Cache
