									Noisy Wilo Circulation Pump on Joule Preplumbed Cylinder - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/noisy-wilo-circulation-pump-on-joule-preplumbed-cylinder/</link>
            <lastBuildDate>Mon, 05 Oct 2026 17:56:02 +0000</lastBuildDate>
                        <title>RE: Noisy Wilo Circulation Pump on Joule Preplumbed Cylinder</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/noisy-wilo-circulation-pump-on-joule-preplumbed-cylinder/#post-37827</link>
                        <pubDate>Sun, 24 Nov 2024 10:56:32 +0000</pubDate>
                        <description><![CDATA[Our secondary pump attached to the LLH and radiator pipes is a Wilo Pico; this pump is very quiet in normal operation. Have you tried ‘tweaking’ the speed control up or down just a little? I...]]></description>
                        <content:encoded><![CDATA[<p>Our secondary pump attached to the LLH and radiator pipes is a Wilo Pico; this pump is very quiet in normal operation. Have you tried ‘tweaking’ the speed control up or down just a little? I have found the pump does have a ‘sweet spot’ where it is very quiet, (which on our system, coincides with the optimal setting for our LLH balance as it happens). Now this may just be our luck and the system but it might be worth trying if yours is the same model. Regards, Toodles</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/noisy-wilo-circulation-pump-on-joule-preplumbed-cylinder/#post-37827</guid>
                        <title>Noisy Wilo Circulation Pump on Joule Preplumbed Cylinder</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/noisy-wilo-circulation-pump-on-joule-preplumbed-cylinder/#post-37824</link>
                        <pubDate>Sun, 24 Nov 2024 10:45:44 +0000</pubDate>
                        <description><![CDATA[I have a high pitched oscillating noise coming from the joule preplumbed cylinder in my loft. Have been told it is coming from the wilo pump attached to the cylinder. Finding it very disturb...]]></description>
                        <content:encoded><![CDATA[<p>I have a high pitched oscillating noise coming from the joule preplumbed cylinder in my loft. Have been told it is coming from the wilo pump attached to the cylinder. Finding it very disturbing in bedroom and bathroom below. It makes a noise whenever the unit is running for heating or dhw and also, when it just "circulates" to avoid freezing. Joule have said some noise is normal. But I've also been told a high pitched noise isn't normal. Does anyone else have experience of this or any suggestions?</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Lokisam</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/noisy-wilo-circulation-pump-on-joule-preplumbed-cylinder/#post-37824</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-05 18:56:02 by W3 Total Cache
