									Next steps on my ASHP journey: Radiators and Pipework - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/</link>
            <lastBuildDate>Fri, 13 Nov 2026 17:29:27 +0000</lastBuildDate>
                        <title>RE: Next steps on my ASHP journey: Radiators and Pipework</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/6/#post-66920</link>
                        <pubDate>Sun, 20 Sep 2026 16:00:01 +0000</pubDate>
                        <description><![CDATA[I have one of these fitted which also allows you to regulate the flow should you need finer control, although I just leave mine fully open and turn the circulation pump(s) down to achieve th...]]></description>
                        <content:encoded><![CDATA[<p>I have one of <a href="https://pirateheatingsupplies.com/product/28mm-flow-balancing-valve-with-fill-and-flush-5-40ltr-infbv28/" target="_blank" rel="noopener">these</a> fitted which also allows you to regulate the flow should you need finer control, although I just leave mine fully open and turn the circulation pump(s) down to achieve the desired flow level. It seems pretty accurate and matches the digital flow meter connected to the heat pump controls. I like having something as a quick visual check as well as the digital flow meter which will be of more benefit to those running monitoring systems. </p>
<p><img class="lazy" src="data:image/svg+xml,%3Csvg%20xmlns%3D%22http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg%22%20viewBox%3D%220%200%201%201%22%3E%3C%2Fsvg%3E" data-src="https://pirateheatingsupplies.com/wp-content/uploads/2023/06/fill-n-flush-valve-600x600.png" /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/6/#post-66920</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/6/#post-66919</link>
                        <pubDate>Sun, 20 Sep 2026 14:26:08 +0000</pubDate>
                        <description><![CDATA[First up once I have a flow meter fitted is to simply measure flow speeds and hence flow rates at the three available pump speeds with the existing system. Since it may be that there is no i...]]></description>
                        <content:encoded><![CDATA[<p>First up once I have a flow meter fitted is to simply measure flow speeds and hence flow rates at the three available pump speeds with the existing system. Since it may be that there is no issue. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Rob of York</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/6/#post-66919</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66918</link>
                        <pubDate>Sun, 20 Sep 2026 07:54:42 +0000</pubDate>
                        <description><![CDATA[@jamespa since going back to bed and reading again this morning, I have looked for the edit or delete options &#x1f641; 
There shouldn&#039;t be a requirement for elevated flow temperatu...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa since going back to bed and reading again this morning, I have looked for the edit or delete options &#x1f641; </p>
<p>There shouldn't be a requirement for elevated flow temperatures, as the newly specified radiators can emit the required heat at a the planned 40° to 42.5° flow temperature with respective DT5 or DT7. Pushing higher DT across flow and return may work IF the heatpump allows it. But ultimately it's a compromise.</p>
<p>Rob is concerned about the cost and disruption for replacement of the 15mm secondaries. However would it be possible to extend the 22mm primaries to the mid point of the 15mm secondaries. Creating two 15mm secondary branches downstairs and two 15mm secondary branches upstairs... If a pair of surface mounted of pipes is OK, then it may be possible to only lift the upstairs hallway floor to a suitable point, then drop down and create a small access downstairs to connect onto the existing pipes.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Singlespeed</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66918</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66917</link>
                        <pubDate>Sun, 20 Sep 2026 07:02:28 +0000</pubDate>
                        <description><![CDATA[That&#039;s not really the case.  Average surface temperature (to first order flow temperature) determines energy transfer from rad to room.  This needs to equal the room loss. 
DT will then be ...]]></description>
<p>But remember that your design criteria heat requirement will only occur for a few days per year (or even just a few hours at a time) and increasing the flow temperature to 50° or even 55° if required would transfer a lot of extra heat energy for the same flow rate</p>
<p>That's not really the case.  Average surface temperature (to first order flow temperature) determines energy transfer <em>from rad to room. </em> This needs to equal the room loss. </p>
<p>DT will then be determined by that and flow rate.  All else being constant, inreasing FT will not reduce the required flow rate or DT.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66917</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66916</link>
                        <pubDate>Sun, 20 Sep 2026 06:52:29 +0000</pubDate>
                        <description><![CDATA[@singlespeed 
Thanks, however, I think there is more to it than flow temperatures, which is the main factor affecting heat pump efficiency.
Radiator temperature difference to room temperat...]]></description>
                        <content:encoded><![CDATA[<p>@singlespeed </p>
<p>Thanks, however, I think there is more to it than flow temperatures, which is the main factor affecting heat pump efficiency.</p>
<p>Radiator temperature difference to room temperature is what determines their output. Radiator temperature is the average of flow and return temperatures. Hence a flow temperature of 50C or 55C has the potential to deliver far more emitter output than 40C or 45C.</p>
<p>The power that can be transferred from the heat pump however depends on the difference between flow and return temperatures, irrespective of what the flow temperature is. dT10 here transfers twice as much power as dT5 and half as much as dT20, which is typical for gas boilers.</p>
<p>Heat pump systems are typically designed for dT5, however, this needs 4x the flow rate as dT20 to transfer the same amount of power. Further some heat pumps effectively set the flow rate to be constant e.g. Vaillant Aerotherm 7kW defaults to 0.333l/s, and lets dT vary. This flow rate may well be a stretch for my pipework, hence wanting to figure this out pre-install. (It appears this heat pump can be set to 50% of that flow rate which should be fine).</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66916</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66915</link>
                        <pubDate>Sun, 20 Sep 2026 02:48:36 +0000</pubDate>
                        <description><![CDATA[You&#039;ve spent ages deliberating over flow rates being potentially noisy, whilst running your preferred lower flow temperature.
But remember that your design criteria heat requirement will on...]]></description>
<p>These reasonable radiator changes should mean we can run a maximum radiator temperature of 37.5C with flow temperature of between 40C and 42.5C depending on what flow rate and DT the pipework cans support.</p>
<p>You've spent ages deliberating over flow rates being potentially noisy, whilst running your preferred lower flow temperature.</p>
<p>But remember that your design criteria heat requirement will only occur for a few days per year (or even just a few hours at a time) and increasing the flow temperature to 50° or even 55° if required would transfer a lot of extra heat energy for the same flow rate. Obviously that would affect the COP for a bit. However you could find there's actually no need to go that high once you have the system running.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66915</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66764</link>
                        <pubDate>Mon, 14 Sep 2026 22:45:12 +0000</pubDate>
                        <description><![CDATA[If you have a flowmeter and two temperature probes, then you can calculate power, so you have a thermal power meter. Won&#039;t accumulate kWh like a real heat meter but still useful.
Thermal ca...]]></description>
                        <content:encoded><![CDATA[<p>I think a flow meter (about £60) and the thermal camera that I already have should suffice for that.</p>
<p>If you have a flowmeter and two temperature probes, then you can calculate power, so you have a thermal power meter. Won't accumulate kWh like a real heat meter but still useful.</p>
<p>Thermal camera is too inaccurate for this, but there are cheap digital thermometers with remote probes which you can tape to your pipes. Wrap in insulation and it's pretty accurate.</p>
<br />
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66764</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66760</link>
                        <pubDate>Mon, 14 Sep 2026 21:09:48 +0000</pubDate>
                        <description><![CDATA[Posted by: @grahamf
 if you are planning to install a flow meter, I would suggest considering a heat meter instead
Thanks for the link to the monitoring kit. However, it&#039;s quite expensiv...]]></description>
<p><strong>Posted by: @grahamf</strong></p>
<p><span> if you are planning to install a flow meter, I would suggest considering a heat meter instead</span></p>
<p>Thanks for the link to the monitoring kit. However, it's quite expensive for the initial investigation that I'd like to do, i.e. find out what the flow rate and the flow and return temperatures are with the boiler running and the circulation pump on each of its 3 settings. I think a flow meter (about £60) and the thermal camera that I already have should suffice for that.</p>
<blockquote>
<p><span>it is worth thinking carefully about what this careful two stage approach buys you.</span></p>
<p>The radiators are 55-years old and in some cases showing signs of sludge on the thermal camera images. We plan to replace them in the not too distant future anyway irrespective of whether we go for an ASHP or not. Further, the sizing isn't significantly influenced by that decision either, since we are going for K2s (K3s ruled out as too wide) and keeping to the same lengths as the existing type 20s but extending the heights into wasted space under the windows. There is one new radiator added in the kitchen-breakfast room which is a little cold at present, and where we found the blanked off pipes to a missing radiator that was removed during changes to the kitchen that pre-date us moving in. These reasonable radiator changes should mean we can run a maximum radiator temperature of 37.5C with flow temperature of between 40C and 42.5C depending on what flow rate and DT the pipework cans support. As the gas boiler runs weather compensation that adjusts the flow temperature down to 30C, it seemed a useful idea to make a low temperature heating trial using the boiler to mimic a heat pump, before installing one.</p>
<p>The really useful point that you made earlier was about the VAT. Saving £670 on unnecessary tax changes the rationale about when to do the radiator upgrade. Without the difference in VAT, it made sense to do the radiator upgrade first and gain more information before making the final decision on an ASHP. With the difference in VAT, that decision clearly needs to be made before the radiator changes. </p>
<p>I still think knowing something about flow rates and flow and return temperatures would be useful to address concerns about the pipework; however, I can do that with the existing radiators in place, with only the requirement to get a flow rate meter fitted.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66760</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66758</link>
                        <pubDate>Mon, 14 Sep 2026 19:14:52 +0000</pubDate>
                        <description><![CDATA[@rob-of-york I realise you feel the need to be cautious, but it is worth thinking carefully about what this careful two stage approach buys you.  There are two possible outcomes.  You will c...]]></description>
                        <content:encoded><![CDATA[<p>@rob-of-york I realise you feel the need to be cautious, but it is worth thinking carefully about what this careful two stage approach buys you.  There are two possible outcomes.  You will conclude that the heat pump:</p>
<ol>
<li>Will provide enough heat at the lower flow temperature.</li>
<li>Won't provide enough heat at the lower flow temperature.</li>
</ol>
<p>If it works well and you decide that a heat pump will be OK, then you just wasted £700 on VAT.  OK you might save some money by buying a smaller heat pump that will still do the job, but you can't be sure that your experiment will help that decision.<br /><br />If you conclude that the heat pump won't do the job, then you just wasted £4,000 on radiators that you may not need with a gas boiler.<br /><br />In the end, you just have to be brave and go for it.  Even if you take the two stage approach, you will still have to summon up the courage to go ahead with the ASHP in Stage 2.  <br /><br />I too was nervous about installing an ASHP.  Lots of people told me that the project would fail.  I decided to design for a relatively low flow temperature (42C) to give myself room for manoeuvre.  I was also very careful to choose a good installer - one that Mars recommended.  We violently agreed not to use a buffer tank, go open loop and run it 24 hours per day on weather compensation.  I was still nervous, but I still had options to improve our insulation or some aspects of the system.<br /><br />In practice, the system is running a SCOP of more than 4 and possibly closer to 5.  The house was lovely and warm (20C) all last winter. On the coldest night of the year at -5C outside, the flow temperature was still under 40C.<br /><br />Of course, you must follow your instincts and go with the risk profile that you feel comfortable with, but make sure you are clear about which risks you are mitigating and which you are not.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66758</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66749</link>
                        <pubDate>Mon, 14 Sep 2026 16:41:01 +0000</pubDate>
                        <description><![CDATA[@rob-of-york-york if you are planning to install a flow meter, I would suggest considering a heat meter instead.  This measures flow and return temperatures as well.  Combining this with the...]]></description>
                        <content:encoded><![CDATA[<p>@rob-of-york-york if you are planning to install a flow meter, I would suggest considering a heat meter instead.  This measures flow and return temperatures as well.  Combining this with the flow rate gives you the heat output from the boiler or heat pump.The Heat Pump Monitor web site can get you set up with a full independent monitoring system which includes a heat meter, electricity meter (or buy a Shelly) and a Raspberry Pi running their software.<br /><br />https://heatpumpmonitor.org/</p>
<p><a href="https://shop.openenergymonitor.com/level-3-heat-pump-monitoring-bundle-emonhp/">https://shop.openenergymonitor.com/level-3-heat-pump-monitoring-bundle-emonhp/</a></p>
<div>It is not cheap, but it provides all sorts of insights into your system.  I have not bought it myself yet, but I am very tempted!<br /><br /></div>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/next-steps-on-my-ashp-journey-radiators-and-pipework/paged/5/#post-66749</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 17:29:27 by W3 Total Cache
