									My NIBE ASHP Nightmare: No Commissioning, High Bills and a Hostile Installer - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/</link>
            <lastBuildDate>Sun, 12 Apr 2026 23:52:40 +0000</lastBuildDate>
                        <title>RE: My NIBE ASHP Nightmare: No Commissioning, High Bills and a Hostile Installer</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-58392</link>
                        <pubDate>Mon, 09 Feb 2026 12:25:25 +0000</pubDate>
                        <description><![CDATA[That&#039;s not bad.
We&#039;ve had visitors to this forum with cycling 20x per hour!
If &#039;James&#039; can&#039;t or won&#039;t resolve the issues, then you could take this issue to CAB with the prospect of them ru...]]></description>
<p>I now believe that my installer over sized my heat pump so it is still cycling at about 1 to 1½ hours</p>
<p>That's not bad.</p>
<p>We've had visitors to this forum with cycling 20x per hour!</p>
<p>If 'James' can't or won't resolve the issues, then you could take this issue to CAB with the prospect of them ruling that he should refund some of your money for 'services' that weren't carried out. Those include</p>
<li>commissioning the system to use as a little energy (input) as possible as per Building Regs Part-L</li>
<li>producing full system drawings and operating instructions</li>
<li>application for BUS</li>
<li>registering the installation with MCS</li>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-58392</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-58271</link>
                        <pubDate>Sat, 07 Feb 2026 17:45:15 +0000</pubDate>
                        <description><![CDATA[er, if you do this how will the heat pump ever know to switch on? The obvious thing is to tie it to the heat pump&#039;s water pump so it switches on whenever the heat pumps pump switches on.  Th...]]></description>
<p>I now believe that my installer over sized my heat pump so it is still cycling at about 1 to 1½ hours. This means that the UFH pumps are running 24/7 and for much of the time are circulating increasingly cooler water while the heat pump is off. I am looking at installing a single pump in the heat pump to UFH supply line. The problem I have is that I need a way of sensing when the heat pump switches on so that it will switch on the “supply pump”. This will result in the pump running only while the heat pump is on. Anyone got any ideas?</p>
<p>er, if you do this how will the heat pump ever know to switch on? The obvious thing is to tie it to the heat pump's water pump so it switches on whenever the heat pumps pump switches on.  Then if, for example, it runs a sniffing cycle it will sniff from the UFH which is what you need.  basically you need to be careful to think this mod through.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-58271</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-58251</link>
                        <pubDate>Sat, 07 Feb 2026 13:47:54 +0000</pubDate>
Update
I just thought that I would post an update. I have still not been able to get any information from my installer so I have contacted the manufacturer in Sw...]]></description>
                        <content:encoded><![CDATA[<p>@transparent </p>
<div>
<p><span> </span></p>
</div>
<div>
<p><span>Update</span></p>
</div>
<div>
<p><span>I just thought that I would post an update. I have still not been able to get any information from my installer so I have contacted the manufacturer in Sweden and asked them to try and take some action.</span></p>
</div>
<div>
<p><span>I contacted OFGEM and found that no application has been made for the BUS Grant. No paperwork has been submitted to the local building control.</span></p>
</div>
<div>
<p><span>As recommended I bought several of the “fridge” digital thermometers and have been taking readings at various points on the system. They have been really useful. I have made several adjustments and the thermometers can very quickly indicate a result.</span></p>
</div>
<div>
<p><span>When I ordered the UFH there was a miscommunication as to what would be the heat source. To cover all possibilities they assumed that it would be a “Boiler System”. As a result they included a mixer valve for each manifold(2). My plumber assumed that it should be fitted and I didn’t know any different. I have now discovered that even with the mixer vale in the fully closed position it still allows for some mixing. This has resulted in the supply temperature drop from pre-mixer valve to post mixer valve of 5C. Wunda have sent replacement valves. My plumber will remove the mixers. At the same time he remove some of the 90 degree bends to improve the flow.</span></p>
</div>
<div>
<p><span>I now believe that my installer over sized my heat pump so it is still cycling at about 1 to 1½ hours. This means that the UFH pumps are running 24/7 and for much of the time are circulating increasingly cooler water while the heat pump is off. I am looking at installing a single pump in the heat pump to UFH supply line. The problem I have is that I need a way of sensing when the heat pump switches on so that it will switch on the “supply pump”. This will result in the pump running only while the heat pump is on. Anyone got any ideas?</span></p>
</div>
<div>
<p><span>I have also discussed replumbing the volumizer.</span></p>
</div>
<div>
<p><span>I have been in contact with NIBE customer care and told them about the problems with my installer. I am waiting for their response. It may be necessary for me to contract an MCS installer to come and commission my installation and generate all the necessary paperwork. Probably an expensive exercise but I may be able to get the Grant.</span></p>
</div>
<div>
<p><span>I used Heat Punk to calculate the “heat loss” for my house. (something else that my installer didn’t do) Thank you for suggesting the program. If you can use standard parameters it is very straightforward. Any “custom” inputs require a little more thought. Their Customer Care, both telephone and email are great.</span></p>
</div>
<div>
<p><span>Since I started to write this update I have had an email from NIBE UK. They said that the installer (they use his first name, James) will call me next week. They also said that all future communications on this matter must only be conducted with the installer. In other words they “wash their hands of the matter”. Since in the last 5 months he didn’t commission or complete any of the required paperwork, including the BUS Grant application, I do not have any expectations of a resolution.</span></p>
</div>
<div>
<p><span>Thanks again to the Forum. You have been a huge help.</span></p>
</div>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Mike @ Camelot</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-58251</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57410</link>
                        <pubDate>Wed, 28 Jan 2026 19:56:53 +0000</pubDate>
                        <description><![CDATA[True... but I&#039;ll be the one derailing this topic if I respond here.
Firstly I know how to reduce the number of power cuts, in which we can make a difference.
Secondly, this...]]></description>
<p>I really feel that there are way too many power cuts in the UK.</p>
<p>True... but I'll be the one derailing this topic if I respond here.</p>
<p>Firstly I know how to reduce the number of power cuts, in which we can make a difference.</p>
<p>Secondly, this is another instance of customers in SE England being treated differently by their DNO to those of us living elsewhere.<br />That DNO is UK Power Networks, which appears to be operating outside the norms which other DNOs implement.</p>
<p>The DNO 'UKPN' is more than 75% owned by UK Power Networks Holdings Ltd. which has 10 of its 14 listed Directors based in China.</p>
<p>UK Power Networks Holdings Ltd. is between 25% to 50% owned by Cki Number 1 Limited.</p>
<p>Cki Number 1 Limited is more than 75% owned by Cki Number 2 Limited</p>
<p>Cki Number 2 Limited is more than 75% owned by Cki Number 3 Ltd.</p>
<p>Cki Number 3 Ltd is owned by Ck Infrastructure Holdings Limited, which is based in Bermuda.</p>
<p>All companies in that chain substantially share the same directors.</p>
<p>In effect it's an international financial company which holds an Ofgem Licence to act as DNO for three regions in England.<br />Whatever gets discussed at Board level is unlikely to have much to do with power outages in East Sussex or Kent!</p>
<p>Further discussion needs to be in a new topic...<br />... so that @mike-camelot can revert to being worried solely about his hostile installer!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57410</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57397</link>
                        <pubDate>Wed, 28 Jan 2026 17:47:03 +0000</pubDate>
                        <description><![CDATA[We used to one or two powercuts a year but I believe they may have put us on a different type of circuit, so it became a lot better. 
Not long ago, when going on a hike in Herts we heard ab...]]></description>
                        <content:encoded><![CDATA[<p>We used to one or two powercuts a year but I believe they may have put us on a different type of circuit, so it became a lot better. </p>
<p>Not long ago, when going on a hike in Herts we heard about some case where roadworks changed water drainage and some local substation was being flooded on a regular basis. What amazed me is this seemed to be going on for over a year!   </p>
<p>I remember thinking about it, all talk and no action..</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57397</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57328</link>
                        <pubDate>Tue, 27 Jan 2026 16:59:18 +0000</pubDate>
                        <description><![CDATA[@transparent, not wanting to derail this thread, I really feel that there are way too many power cuts in the UK. This is a relatively small country and homeowners are paying a stupid amount ...]]></description>
                        <content:encoded><![CDATA[@transparent, not wanting to derail this thread, I really feel that there are way too many power cuts in the UK. This is a relatively small country and homeowners are paying a stupid amount of money for grid maintenance, upkeep, etc. We're OK where we are, but family in East Sussex/Kent have power outages lasting upwards of 6 hours on a fortnightly basis. It's nuts.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57328</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57319</link>
                        <pubDate>Tue, 27 Jan 2026 16:40:28 +0000</pubDate>
                        <description><![CDATA[Thanks Mike. Glad to know that you and the house are both intact.
I have access to many of the NGED in-house data and network maps, within a &#039;partnership agreement&#039;.That means I can &#039;see&#039; t...]]></description>
                        <content:encoded><![CDATA[<p>Thanks Mike. Glad to know that you and the house are both intact.</p>
<p>I have access to many of the NGED in-house data and network maps, within a 'partnership agreement'.<br />That means I can 'see' the connections in your area, and statistics on the physical cables.</p>
<p>Whilst I don't know which is your house, I can already see that you are connected to a pole-mounted local substation, which will be one of:</p>
<li>Awliscombe 31/1248</li>
<li>Losses Farm 31/4426</li>
<p>The substation reference number is on the pole at 2m above ground level.</p>
<p>The '31' refers to the Bulk Supply Point (transformers) from which the 33kV cabling originates that you are connected to.</p>
<p>I have a particular interest in increasing network resilience.<br />That means I keep a lookout for areas which suffer power-cuts more than once for the same reason.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57319</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57306</link>
                        <pubDate>Tue, 27 Jan 2026 12:46:29 +0000</pubDate>
                        <description><![CDATA[@transparent No problems today. We had a power cut Sunday night Monday. I don&#039;t what time the power went off.It came back at 01.32. I think that it was about 1 hour duration but I can&#039;t be  ...]]></description>
                        <content:encoded><![CDATA[@transparent No problems today. We had a power cut Sunday night Monday. I don't what time the power went off.It came back at 01.32. I think that it was about 1 hour duration but I can't be  certain. I have lived here for 2 ½ years. In that time there have been 3 other cuts. One lasted for 18 hours when a sub station had a problem.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57306</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57296</link>
                        <pubDate>Tue, 27 Jan 2026 11:46:04 +0000</pubDate>
                        <description><![CDATA[@mike-camelot Your house is an area which has been extensively flooded overnight.
Can you give us any news on both the way your SIP house has been affected, and the situation in the surroun...]]></description>
                        <content:encoded><![CDATA[<p>@mike-camelot Your house is an area which has been extensively flooded overnight.</p>
<p>Can you give us any news on both the way your SIP house has been affected, and the situation in the surrounding villages?</p>
<p>Here's a snapshot of NGED's power-cut map for 11:30 today (27th Jan) showing East Devon where Mike lives.<br />For the benefit of readers in other parts of the UK, the main A30 has been closed due to flooding east of Exeter.</p>
13790
<p><a href="https://www.devon.gov.uk/news/devon-county-council-leader-calls-severe-weather-resilience-investment/" target="_blank" rel="noopener">Yesterday, the Leader of Devon County Council, Cllr Julian Brazil, has stated that the region lacks resilience</a>.</p>
<p>That's true in so many ways: roads, railways, internet connectivity, electricity supplies, housing, ecological imbalance and food production.</p>
<p>There's probably a lot of 'knowledge' on this Forum which could be tapped into, with a view to developing a more resilient society and infrastructure.<br />The 'solutions' are not going to magically appear from Westminster.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/4/#post-57296</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/3/#post-57122</link>
                        <pubDate>Sun, 25 Jan 2026 09:57:44 +0000</pubDate>
                        <description><![CDATA[@mike-camelot I thought it did have ufh from memory on one of the later updates. Sorry! BUT at first I used an equivalent radiator from the W/m2 heating from the under floor pipe spacing. Th...]]></description>
                        <content:encoded><![CDATA[<p>@mike-camelot I thought it did have ufh from memory on one of the later updates. Sorry! BUT at first I used an equivalent radiator from the W/m2 heating from the under floor pipe spacing. Then </p>
<p>Its a bit of a pain but the more you understand your system in detail the better, then the trade-offs are what you want, not what’s easiest for the trades-people.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/my-nibe-ashp-nightmare-no-commissioning-high-bills-and-a-hostile-installer/paged/3/#post-57122</guid>
