									Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/</link>
            <lastBuildDate>Sun, 08 Nov 2026 01:46:25 +0000</lastBuildDate>
                        <title>RE: Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44934</link>
                        <pubDate>Wed, 02 Apr 2025 22:30:47 +0000</pubDate>
                        <description><![CDATA[@alsocold123456 I would have thought it would last a bit longer than that. Its worth checking out, it may have just lost some air pressure, this is something your service engineer would have...]]></description>
                        <content:encoded><![CDATA[<p>@alsocold123456 I would have thought it would last a bit longer than that. Its worth checking out, it may have just lost some air pressure, this is something your service engineer would have checked on the last service.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44934</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44932</link>
                        <pubDate>Wed, 02 Apr 2025 21:55:07 +0000</pubDate>
                        <description><![CDATA[@ashp-bobba thanks ! Ok so it&#039;s likely the expansion vessel. It&#039;s been replaced twice already. Last time about 2yrs ago. Will get in touch with a local heating engineer (again).]]></description>
                        <content:encoded><![CDATA[@ashp-bobba thanks ! Ok so it's likely the expansion vessel. It's been replaced twice already. Last time about 2yrs ago. Will get in touch with a local heating engineer (again).]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AlsoCold123456</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44932</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44931</link>
                        <pubDate>Wed, 02 Apr 2025 21:40:36 +0000</pubDate>
                        <description><![CDATA[Hello, this sound like expansion and low on water pressure, assuming you have a 2 story house you should have a static pressure of around 1 bar, running pressure of around 1.2 bar and antifr...]]></description>
                        <content:encoded><![CDATA[<p>Hello, this sound like expansion and low on water pressure, assuming you have a 2 story house you should have a static pressure of around 1 bar, running pressure of around 1.2 bar and antifreeze mode of between 1 bar and 1.2 bar, the vessel should balance and absorb expansion.</p>
<p>To check this you will need to switch of the system and safely electrically isolate, isolate the expansion vessel and drain it, then using a pump with a gauge pump this vessel through the valve usually at the top to 1.5 bar, place this back into position and refill the system to 1 bar. then fire the unit back up.</p>
<p>If the vessel will not hold its pressure its likely that the bladder is broken and this will need replacing. there are some rules in the UK:</p>
<h2 class="" data-start="1580" data-end="1634"><strong data-start="1583" data-end="1634">2. Servicing Requirements for Expansion Vessels</strong></h2>
<h3 class="" data-start="1635" data-end="1672"><strong data-start="1639" data-end="1672">A. Regular Maintenance Checks</strong></h3>
<ul data-start="1673" data-end="2052">
<li class="" data-start="1673" data-end="1757">
<p class="" data-start="1675" data-end="1757"><strong data-start="1675" data-end="1695">Annual servicing</strong> is recommended, often carried out alongside a boiler service.</p>
</li>
<li class="" data-start="1758" data-end="2052">
<p class="" data-start="1760" data-end="1785">A service should include:</p>
<ul data-start="1788" data-end="2052">
<li class="" data-start="1788" data-end="1884">
<p class="" data-start="1790" data-end="1884"><strong data-start="1790" data-end="1822">Checking pre-charge pressure</strong> of the expansion vessel (usually between <strong data-start="1864" data-end="1882">0.75 - 1.5 bar</strong>).</p>
</li>
<li class="" data-start="1887" data-end="1989">
<p class="" data-start="1889" data-end="1989"><strong data-start="1889" data-end="1921">Re-pressurizing if necessary</strong> using a foot pump or nitrogen (as per manufacturer’s instructions).</p>
</li>
<li class="" data-start="1992" data-end="2052">
<p class="" data-start="1994" data-end="2052"><strong data-start="1994" data-end="2051">Inspecting for leaks, corrosion, or diaphragm failure</strong>.</p>
</li>
</li>
<h3 class="" data-start="2054" data-end="2100"><strong data-start="2058" data-end="2100">B. Signs of a Failing Expansion Vessel</strong></h3>
<ul data-start="2101" data-end="2263">
<li class="" data-start="2101" data-end="2149">
<p class="" data-start="2103" data-end="2149">Frequent pressure drops in the heating system.</p>
</li>
<li class="" data-start="2150" data-end="2203">
<p class="" data-start="2152" data-end="2203">Water leaking from the pressure relief valve (PRV).</p>
</li>
<li class="" data-start="2204" data-end="2263">
<p class="" data-start="2206" data-end="2263">Boiler pressure gauge rising too high when heating is on.</p>
</li>
<h3 class="" data-start="2265" data-end="2298"><strong data-start="2269" data-end="2298">C. Replacement and Repair</strong></h3>
<ul data-start="2299" data-end="2498">
<li class="" data-start="2299" data-end="2377">
<p class="" data-start="2301" data-end="2377">If an expansion vessel fails (e.g., diaphragm rupture), it must be replaced.</p>
</li>
<li class="" data-start="2378" data-end="2498">
<p class="" data-start="2380" data-end="2498">Some vessels have <strong data-start="2398" data-end="2426">external Schrader valves</strong> for easy re-pressurization, while others may need complete replacement.</p>
</li>
<h2 class="" data-start="2505" data-end="2551"><strong data-start="2508" data-end="2551">3. Who Can Service an Expansion Vessel?</strong></h2>
<ul data-start="2552" data-end="2858">
<li class="" data-start="2552" data-end="2649">
<p class="" data-start="2554" data-end="2649">For <strong data-start="2558" data-end="2584">sealed heating systems</strong>, a qualified heating engineer or plumber can service the vessel.</p>
</li>
<li class="" data-start="2650" data-end="2756">
<p class="" data-start="2652" data-end="2756">For <strong data-start="2656" data-end="2688">unvented hot water cylinders</strong>, only a <strong data-start="2697" data-end="2722">G3-qualified engineer</strong> can work on the expansion vessel.</p>
</li>
<h2 class="" data-start="2865" data-end="2902"><strong data-start="2868" data-end="2902">4. Compliance &amp; Best Practices</strong></h2>
<ul data-start="2903" data-end="3201">
<li class="" data-start="2903" data-end="2963">
<p class="" data-start="2905" data-end="2963">Always follow the <strong data-start="2923" data-end="2962">manufacturer's servicing guidelines</strong>.</p>
</li>
<li class="" data-start="2964" data-end="3084">
<p class="" data-start="2966" data-end="3084">Ensure servicing records are kept, especially for <strong data-start="3016" data-end="3029">landlords</strong> (required under the <strong data-start="3050" data-end="3082">Landlord and Tenant Act 1985</strong>).</p>
</li>
<li class="" data-start="3085" data-end="3201">
<p class="" data-start="3087" data-end="3201">Commercial systems may have additional requirements under <strong data-start="3145" data-end="3200">The Pressure Systems Safety Regulations (PSSR) 2000</strong>.</p>
</li>
<p>Expansion is important for the system to run correctly so it may be worth getting a qualified engineer if you are not sure. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44931</guid>
                        <title>Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44930</link>
                        <pubDate>Wed, 02 Apr 2025 19:46:42 +0000</pubDate>
                        <description><![CDATA[Hi all
I&#039;ve noticed that my 8.5kw Mitsubishi Ecodan PUHZ-W85VA2 heat pump w pre-plumbed 250L DHW cylinder EHPT25X-UKHCW system pressure changes depending on the mode of operation.
Heatin...]]></description>
                        <content:encoded><![CDATA[<p>Hi all</p>
<p>I've noticed that my 8.5kw Mitsubishi Ecodan PUHZ-W85VA2 heat pump w pre-plumbed 250L DHW cylinder EHPT25X-UKHCW system pressure changes depending on the mode of operation.</p>
<li>Heating on AutoAdaptation flow temp circa 40C = system pressure 1.5bar</li>
<li>Antifreeze mode flow temp circa 20C = system pressure 0.5bar</li>
<li>System off = system pressure 0bar</li>
<p>Is this normal/expected ?</p>
<p>If not, what could be the cause and how would you go about fixing it ?</p>
<p>I've had this system 7 years and first noticed this about a month ago.</p>
<p>Photo/screenshots from MelCloud attached.</p>
<p>No obvious performance issue noted.</p>
<p>THANKS !</p>
11072
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-system-pressure-changes-an-issue-or-expected/#post-44930</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 01:46:25 by W3 Total Cache
