									Mitsubishi Ecodan &amp; Raspberry Pi automations - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:27:47 +0000</lastBuildDate>
                        <title>RE: Mitsubishi Ecodan &amp; Raspberry Pi automations</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19714</link>
                        <pubDate>Mon, 22 May 2023 06:37:58 +0000</pubDate>
                        <description><![CDATA[Out of interest, how are you interfacing the pi to the eco Ecodan? Is there an API?]]></description>
<p>I started letting a program on the Pi use the controls to make adjustments of the sort I was making manually (which I can't find any way to program into the ecodan controller), but it does goes to sleep if detects someone else using the controls. I've registered on the forum after lurking for a while because I saw a problem I thought I could answer.</p>
<p>Out of interest, how are you interfacing the pi to the eco Ecodan? Is there an API?</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Spud</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19714</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19302</link>
                        <pubDate>Sat, 06 May 2023 18:52:14 +0000</pubDate>
                        <description><![CDATA[Your charts are quite interesting and are a good example of what appears to be happening within a heat pump system. The 3rd was quite a sunny day, and as you state the weather was quite mild...]]></description>
<p>@derek-m </p>
<p>ok thanks Derek,when you’ve got a minute, no rush.... would be interested to hear your thoughts on what’s going on. Although admittedly it’s quite mild now. Also would be interested to hear thoughts on temp differential which is more often 7 rather than 5....</p>
<p>Your charts are quite interesting and are a good example of what appears to be happening within a heat pump system. The 3rd was quite a sunny day, and as you state the weather was quite mild.</p>
<p>The heat pump controller contains several control systems and equations, which hopefully work in conjunction with each other to maintain the indoor temperature within acceptable limits.</p>
<p>The first chart indicates that increasing the desired temperature setting from 18.5C to 19C is sufficient to restart the heat pump. It is obvious that the water pump starts running, since both the LWT and RWT, initially fall slightly, and then start to increase. The fall in temperature is probably due to the cooled water within the pipework and heat emitters, now being circulated around the system, and the fact that the compressor takes some time to increase the pressure and temperature of the refrigerant gas, to the point where thermal energy starts to be transferred from the gas to the water.</p>
<p>The LWT starts to increase, and is followed some time later by the RWT. The delay before the RWT starts to increase is due to the fact that the whole system has been shutdown for an extended period, so both the water within the system and the heat emitters will have cooled to the surrounding temperature. The initial thermal energy produced by the heat pump therefore heats the water, and most of this heat energy is then transferred to the heat emitters, which also start to warm. The rate at which the LWT increases is dictated by the amount of thermal energy being transferred into the volume of water, and the actual RWT. A good analogy would be moving a small block of wood across a table using an elastic band, where one's hand represents the LWT value, the wood the RWT, and the length of the elastic band is the Delta T. With one's hand touching the wood whilst holding the end of the elastic band, both LWT and RWT are the same and Delta T is zero. Moving one's hand away from the wood initially requires little effort, since the elastic band is slack, but as the elastic band becomes taut, moving one's hand requires more effort as the elastic band stretches. Eventually the block of wood will start to move, and the stretch of the elastic band will become reasonable constant. When one stops moving one's hand, the extension of the elastic band will cause the block of wood to continue moving, until there is insufficient supplied force to move it. This can be seen on chart 1 when the compressor stops.</p>
<p>A better example of what happens to the indoor temperature would be a person pulling a sled, over a frozen lake, using a bungee rope. The above description of the block of wood would hold true, but if the person stops suddenly, as the heat pump did, the extension of the bungee rope and the inertia built up in the sled, will cause the sled to continue moving forward, and it could even go past the person pulling it. Although it is not shown on the chart, this is what happened within the system. The indoor temperature represented by the sled, is moved from the starting point (18.5C), to the finishing point (19C), at which point the person (increasing net thermal energy supply) stops. But because the bungee rope needed to be extended to get the sled moving, and keep it moving, the person was required to go past the finishing point, so there is a strong possibility that the sled will also move past the finishing point. To get the sled back to the finishing point, the person would need to move slowly back past the sled, and without extending the bungee rope more than is necessary, gradually pull the sled to the correct location.</p>
<p>So, the reason why the Delta T may be higher under certain conditions is because there is a need for extra thermal energy, to not only to meet the present heat loss, but also to raise the indoor temperature, and therefore the temperature of the water and heat emitters.</p>
<p>To cause the indoor temperature to increase, the heat emitters, and water, need to be warmer than they would normally be if they were just maintaining a constant indoor temperature. Once the desired temperature has been reached, this additional thermal energy causes the indoor temperature to continue increasing for a period of time. The degree by which the temperature increases, above the desired setting, will be dependent upon the amount of excess thermal energy within the system, and the rate of heat loss. Under milder weather conditions the indoor temperature may rise higher above the desired value than under colder conditions.</p>
<p>I hope that the above answers most of your questions.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19302</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19225</link>
                        <pubDate>Wed, 03 May 2023 20:30:36 +0000</pubDate>
ok thanks Derek,when you’ve got a minute, no rush.... would be interested to hear your thoughts on what’s going on. Although admittedly it’s quite mild now. Also would be interest...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19225</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19221</link>
                        <pubDate>Wed, 03 May 2023 18:59:58 +0000</pubDate>
                        <description><![CDATA[The graphs that you obtained are typical of a control system whose response is actually slightly too responsive. I will formulate an explanation in a day or two, if that is okay.]]></description>
<p>MELCloud shows Auto Adapt modulate to pass room temp by 1c.</p>
<p>Yesterday our heating was off all day then- Last night we cold started the heating by moving the target temperature 1/2 a degree above the existing room temp. Ie the room stat showed 18.5c at 19.05pm so we moved the target temperature up to 19c.</p>
<p>It took about 40 minutes to reach 19c whereupon it then abruptly switched itself off. </p>
3858
<p>20 minutes later it switched itself back on even though the room thermostat was still showing the target temperature was reached (19c) however this time it appeared to quietly modulate it’s output over a 32 minute period, progressively lowering the LWT until the room thermostat reached 20c. However the target temperature was still set to 19c.</p>
<p>At 20.42 it switched itself off again for the rest of the night.</p>
3859
<p>The small output of energy can be seen in this 24 hour internal temperature report:</p>
3860
<p>I have also posted this to show the reheating of our hot water tank which has been provided by our solar thermal panel. We are not requiring to use the HP to provide Domestic Hot Water, which should be the case for the remainder of the summer. This will have a direct positive impact on our COP sincerely our DHW cop is around 1:2.</p>
<p>i thought it interesting enough to post this since actions of Auto Adapt have been quite difficult to identify.</p>
<p>The graphs that you obtained are typical of a control system whose response is actually slightly too responsive. I will formulate an explanation in a day or two, if that is okay.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19221</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19220</link>
                        <pubDate>Wed, 03 May 2023 17:12:33 +0000</pubDate>
                        <description><![CDATA[MELCloud shows Auto Adapt modulate to pass room temp by 1c.
Yesterday our heating was off all day then- Last night we cold started the heating by moving the target temperature 1/2 a degree ...]]></description>
                        <content:encoded><![CDATA[<p>MELCloud shows Auto Adapt modulate to pass room temp by 1c.</p>
3858
3859
3860
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19220</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19154</link>
                        <pubDate>Sun, 30 Apr 2023 09:22:21 +0000</pubDate>
                        <description><![CDATA[(Clarification on some new terminology used in the last few posts… incase anyone hasn’t seen these kind of acronyms)
Example:“A basic controller has two inputs, the desired value or setpoin...]]></description>
                        <content:encoded><![CDATA[<p>(Clarification on some new terminology used in the last few posts… incase anyone hasn’t seen these kind of acronyms)</p>
<p>Example:<br />“A basic controller has two inputs, the desired value or setpoint (SP) and the measured value or process variable (PV), along with one output (O/P). When PV = SP, O/P does not change.”</p>
<li>PV= Current Room Temperature (Process Variable)</li>
<li>SP = Set Point or Target Room Temp.(traditionally the Thermostat Setting)</li>
<li>O/P = Output or LWT (leaving water temperature) or Primary Flow. This is the temperature of the water leaving the heat pump.</li>
<li>RWT = Returning Water Temperature or Primary Return. This is the temperature of the water coming back to the Heat pump having warmed up the radiators or emitters.</li>
<li>DT = DeltaT or Diferential Temperature. This is the difference in temperature between “Output” pipe and “Return” pipe. This is a way of showing how much energy has been absorbed by the property at a given point in time…but is an ongoing process of energy transfer if the heat pump is continuing to operate at that speed and compressor output.</li>
</ul>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19154</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19153</link>
                        <pubDate>Sun, 30 Apr 2023 08:31:41 +0000</pubDate>
                        <description><![CDATA[@walkers-heatpump yes I get your curiosity…
in our case, the first start-off after setback for our machine appears to be the slowest to build heat so we’re increasing the time period then t...]]></description>
                        <content:encoded><![CDATA[<p>@walkers-heatpump yes I get your curiosity…</p>
<p>in our case, the first start-off after setback for our machine appears to be the slowest to build heat so we’re increasing the time period then the following steps are a bit closer so the HP isn’t tempted to slow down too much. I guess as @derek-m states it’s about acting on the right information based on the individual house/HP relationship.</p>
<p>The challenge being: what is the right information? 😅</p>
<p>(And what’s best if you then throw Cosy Tarrif into the mix)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/8/#post-19153</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/7/#post-19152</link>
                        <pubDate>Sat, 29 Apr 2023 19:26:47 +0000</pubDate>
                        <description><![CDATA[@sunandair No we just use the Mitsy controls. Have a setback to 17.5° at 6pm, then to 18° at 3:30am, 18.5° at 4:30am and 19° at 5:30am. Not certain I&#039;ve seen it much different yet to the sim...]]></description>
                        <content:encoded><![CDATA[<p>@sunandair No we just use the Mitsy controls. Have a setback to 17.5° at 6pm, then to 18° at 3:30am, 18.5° at 4:30am and 19° at 5:30am. Not certain I've seen it much different yet to the simpler schedule but it may learn and settle</p>
<p>Its interesting what the Mits engineer said, from my experience so far the flow temps do drop but they dont get to where my curve is set. I wonder if they do consider the curve or whether it just effectively makes its own curve - ramps up at first to get temps moving as per Derek and the once temps are up it makes a calculation considering temps outside and adjusts accordingly </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Walkers Heatpump</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/7/#post-19152</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/7/#post-19151</link>
                        <pubDate>Sat, 29 Apr 2023 18:57:47 +0000</pubDate>
                        <description><![CDATA[Hi @walkers-heatpump, interested in the way you have set up your temperature changes especially after a setback. How are you applying your half-degree adjustment to your target temperature I...]]></description>
<p>Have smaller temperature changes from setbacks (?) I've just changed mine to half degree changes now every hour from 3:30am</p>
<p>Hi @walkers-heatpump, interested in the way you have set up your temperature changes especially after a setback. How are you applying your half-degree adjustment to your target temperature I noticed the Ecodan own adjustment has limited schedule numbers of changes. So you may have found a way of building a scheduled increase in room set temperature. </p>
<p>do you have a separate third party schedule?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/7/#post-19151</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/7/#post-19150</link>
                        <pubDate>Sat, 29 Apr 2023 12:56:15 +0000</pubDate>
This is the way that I interpret the reply from the Mitsubishi Engineer.
The controller measures both the outside temperature and the indoor temperature, which it compares again...]]></description>
                        <content:encoded><![CDATA[<p>@sunandair</p>
<p>This is the way that I interpret the reply from the Mitsubishi Engineer.</p>
<p>The controller measures both the outside temperature and the indoor temperature, which it compares against the desired indoor temperature setting.</p>
<p>The fact that he mentions the outside temperature indicates that the controller will be using WC. If your controller is operating in WC mode only, even when correctly adjusted to the heat loss characteristics of your home, it will not keep the indoor temperature constant at the desired value. This is because the controller is only measuring, and responding to, the outside temperature, and does not know what is happening to the indoor temperature.</p>
<p>When operating in AA mode, your controller is measuring the indoor temperature and comparing it against the desired setting, but is also using the WC functionality to do the initial heavy lifting so to speak. So WC sets the LWT at a value dependent upon the outside temperature, if there is solar gain which causes the indoor temperature to start to increase, the controller will see that the indoor temperature is rising above the desired setting, and will use the AA functionality to lower the LWT slightly, to bring the indoor temperature down to the desired setting. So in AA mode, the required LWT is calculated using the WC value +/- the AA value. For reasonably accurate indoor temperature control, it is therefore necessary for the WC settings to match the heat loss characteristics of your home, and the AA responds to limit temperature swings away from the desired setting.</p>
<p>To try to answer your query about overnight setback, let's try to assess what may be happening within your system.</p>
<p>I don't know the settings within the control algorithms used inside the controller, but let's assume that a 0.1C increase or decrease in indoor temperature causes a 1C change in required LWT. So if an overnight setback takes the desired temperature setting from 21C to 18C, the controller will now measure a 3C difference between desired and actual temperature, and will reduce the required LWT by 30C. If WC has calculated a LWT of 35C, then the combined LWT will now be 5C, which I believe will cause the compressor to slow down and stop.</p>
<p>If the WC curve settings require a 1C change in outside temperature to cause a 1C change in required LWT, and the outside temperature falls by 5C overnight, then the WC calculated LWT will now be 40C, which together with the AA calculated adjustment would produce a combined required LWT of 10C. As the indoor temperature reduces, so will the AA calculated adjustment, so if the indoor temperature falls to 19.5C, the combined required LWT will now be 40C - 15C = 25C. The compressor will still probably be stopped.</p>
<p>At the end of the overnight setback, the desired temperature is increased from 18C to 21C, and now exceeds the actual indoor temperature by 1.5C. The combined required LWT will now be 40C + 15C = 55C, which will cause the compressor to be ramped up to full speed. As the indoor temperature and the outside temperature start to increase, the combined required LWT will start to reduce, and the compressor speed will be lowered.</p>
<p>To try to prevent the compressor from operating at high speed, the desired indoor temperature could be raised gradually, say at a rate of 0.5C per hour. Unfortunately this poses a further problem, in that if the setback temperature is 18C, then the first temperature increase would be to 18.5C, which is still below the actual indoor temperature, so the compressor may not actually start. Even when the compressor starts, it could take up to 6 hours for the indoor temperature to reach 21C.</p>
<p>You could try reducing the setback to 19C, 19.5C or even 20C, which may cause the heat pump to restart earlier than desired on colder nights, but would allow gradually ramping the temperature back up to be more effective.</p>
<p>At the end of the day it will probably be a matter of trying different options until you find the ones that work best for you, though what works well under certain weather conditions, may not perform too well the following day.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-raspberry-pi-automations/paged/7/#post-19150</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:27:47 by W3 Total Cache
