									Mitsubishi Ecodan R290 10kW performance - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/</link>
            <lastBuildDate>Fri, 13 Nov 2026 16:57:22 +0000</lastBuildDate>
                        <title>RE: Mitsubishi Ecodan R290 10kW performance</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54918</link>
                        <pubDate>Tue, 23 Dec 2025 13:50:33 +0000</pubDate>
                        <description><![CDATA[And to you too.  Wishing you a very enjoyable festive season not worrying about COPs, and where the only flow rates of relevance are potentially the alcoholic ones!
<p>@sheriff-fatman Thank you, food for thought. I think that I am about to be distracted by Christmas. Happy Christmas</p>
<br /><br />And to you too.  Wishing you a very enjoyable festive season not worrying about COPs, and where the only flow rates of relevance are potentially the alcoholic ones!
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Sheriff Fatman</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54918</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54916</link>
                        <pubDate>Tue, 23 Dec 2025 13:37:50 +0000</pubDate>
                        <description><![CDATA[@sheriff-fatman Thank you, food for thought. I think that I am about to be distracted by Christmas. Happy Christmas]]></description>
                        <content:encoded><![CDATA[@sheriff-fatman Thank you, food for thought. I think that I am about to be distracted by Christmas. Happy Christmas]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Ecoste</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54916</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54907</link>
                        <pubDate>Tue, 23 Dec 2025 10:28:50 +0000</pubDate>
                        <description><![CDATA[I have the CN105 &#039;dongle&#039; connected to my system, which I&#039;d recommend as an inexpensive purchase if you want to get as much info as the heat pump will provide to you.  I can see the outputs ...]]></description>
<p>Sorry I dont know the answer to that as I dont have a Mitsubishi myself.  Perhaps @sheriff-fatman knows.  I imagine somewhere in the installer section it would appear, or in some kind of 'live monitor' or 'current readings' or some sort, maybe in a 'service' section of the installer menu?.  Its almost bound to be there somewhere, heat pumps measure everything!</p>
<p><br /><br />I have the CN105 'dongle' connected to my system, which I'd recommend as an inexpensive purchase if you want to get as much info as the heat pump will provide to you.  I can see the outputs from this in real time via the Home Assistant feed, so can provide a bit of insight into this.<br /><br />Within the list of data that it spits out there are two items listed as Heat Pump Input Power and Heat Pump Output Power, which immediately gives the impression that you're getting exactly the info you want.  However, both only seem to report in full kWh, as the graph of recent input power shows.<br /><br /></p>
13185
13186
<p>Separately, there are also various figures shown as 'computed' inputs and outputs.  I assume the source of this is also directly from the heat pump, rather than anything built into the dongle to create these calculations, but this data is more in line with what you'd expect to see, as there is more variation within the figures shown at 2 decimal places.  There are additional, separate outputs showing the figures split by whether they're being used for Heating, DHW or Cooling.  Logically, these must simply feed from whichever of the binary settings for each function is set to 1 at that time.  In the image below, the input power is going to DHW.<br /><br /></p>
13187
13188
<p>These are some of the raw sources of data I used to create the integration into the Open Energy Monitor data reporting.  Doing so was the 'lightbulb' moment for me that the output figures aren't measured, but are simply based on the same theoretical calculations using flow rate, deltaT, etc that you're using in your manual calculations, and the output data is therefore only as good as the quality of the input data going into them.  Short of adding one of the expensive flow monitoring kits from Open Energy Monitor the above numbers are the best available option, and there's far more within it than you can see using the reporting within MelCloud or from the controller, but it still feels like the input figures are being estimated in the reporting.<br /><br />The other obvious limitations are that flow rate is reported as a whole number and the delta T always reports with 0.5°C granularity, which will introduce rounding errors into the calculations, but nothing to the extent that the figures would become unreliable.  It will just introduce an additional margin of error into the reporting.<br /><br />Beyond that, I have an electricity meter fitted near the water cylinder as part of the installation, which I assume is a standard thing, but could be wrong.  I can use the readings to sense check the totals against the cumulative system reporting, or to measure the movement between two time points, e.g. to sense check a daily output.  It would be helpful if I could interrogate the meter directly, but I have no ability to do so currently.  I don't know if the heat pump itself is using this data directly.  Logic suggests it should be, as otherwise why is the meter there at all, so perhaps this is the source of the whole number input power figures referred to above, as this would be a logical explanation why the increments are in whole numbers.  If so, then it would confirm that the input usage reporting is based on reality, as it is being fed directly from meter data. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54907</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54901</link>
                        <pubDate>Tue, 23 Dec 2025 09:08:02 +0000</pubDate>
                        <description><![CDATA[Sorry I dont know the answer to that as I dont have a Mitsubishi myself.  Perhaps @sheriff-fatman knows.  I imagine somewhere in the installer section it would appear, or in some kind of &#039;li...]]></description>
<p>How would you check what the pump thinks the power consumption is?</p>
<p>Thanks for the data.  In some ways its <em>too</em> steady, some noise/variation would help us understand whether the limited resolution of the readout was a factor or not.  Im sure mother nature will oblige over the next few days.  I think the key here is to keep collecting it to see what that tells us.  Some really cold weather would be good as, when its cold, factors other than the actual compressor consumption' become less significant and fixed sensor errors ditto.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54901</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54889</link>
                        <pubDate>Mon, 22 Dec 2025 20:54:51 +0000</pubDate>
                        <description><![CDATA[@ecoste For what it&#039;s worth, this is my equivalent data for the same time period which had the same external temperature (8°C) as yours was reporting.  The outputs are via Mel Pump and the O...]]></description>
                        <content:encoded><![CDATA[@ecoste For what it's worth, this is my equivalent data for the same time period which had the same external temperature (8°C) as yours was reporting.  The outputs are via Mel Pump and the Open Energy Monitor configuration I've set up within Home Assistant.  My system was cycling at intervals of around 1hr 20minutes at the time, so the output isn't as stable as yours, but there are various snapshots of data in the output that might be of use as a comparative.  I've currently got the tolerance set to +3/-7 on the flow temperature target, rather than the standard +5/-5, which is a change I made at the weekend based on some older Ecodan-related posts I'd read on the forum.<br /><br />I'd be happy to provide comparative data while you're investigating your own system, if it's of use to you, albeit it's from a system with an overall heating COP of 3.01 to date, so potentially not one that you're looking to emulate.  I'll caveat that with the fact that it's saving me around 55% on my energy bills relative to using gas last year, so doing a satisfactory job from a bigger picture.<br /><br />
13182
<br />
13183]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/6/#post-54889</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54872</link>
                        <pubDate>Mon, 22 Dec 2025 18:56:35 +0000</pubDate>
                        <description><![CDATA[@jamespa  I appreciate the questioning, you are correct it is important to have certainty. How would you check what the pump thinks the power consumption is? I do have 2 years of data to sup...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa  I appreciate the questioning, you are correct it is important to have certainty. How would you check what the pump thinks the power consumption is? I do have 2 years of data to support my 300W assumption, but it would be better to have a measured value rather than a derived one.The mixing tank temperature is a Mitsubishi entry on the chart, I don't think that there is a corresponding sensor.</p>
<p>Thank you for the link to openheatpump monitor.</p>
<p>Here's a data set for 25 readings at 5 minute intervals from this afternoon.</p>
13175
<p>Here's the Melcloud Hourly Temperature report, showing stability of flow and return temperatures</p>
<div>
13176
</div>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54872</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54829</link>
                        <pubDate>Mon, 22 Dec 2025 12:44:49 +0000</pubDate>
                        <description><![CDATA[All noted, Im not doubting you, just trying to be certain (and hopefully help you be certain) that what you are measuring is real and representative of the heat pump itself not the system.  ...]]></description>
<p>@jamespa The 2 pumps was a decision by the installer, I don't think that they are necessary but at the moment it is a small difference in energy consumption. They are in proportional pressure mode. I have a Joule Cyclone cylinder CY205L, no LLH.</p>
<p>I am measuring COP using the Mitsubishi temperature sensors and flow sensor. The flow and return temperatures are consistent with the entry and exit temperatures for the radiators, which I have measured independently. The temperature sensors track the hot water cycle, see the attached screen shot.</p>
<p>If I vary the pump settings the flow varies as expected, it is 27 l/min at the max setting.</p>
<p>The electrical readings have been validated against the data from my electricity supplier Octopus, I get half hourly reading data and can see instantaneous readings. I allow 300w for the background house usage, which is the maximum, it varies between 100W and 300W.</p>
<p>I recognise that the data is not very accurate, integer granularity, but even allowing for this it is a long way off the specification.</p>
<p>I would be very interested in any other Ecodan R290 users' experience.</p>
<p>All noted, Im not doubting you, just trying to be certain (and hopefully help you be certain) that what you are measuring is real and representative of the heat pump itself not the system.  Because its not as blatant as previously, you are going to have an uphill battle trying to get this fixed (if there is still a fault, which there may be), so <em>absolute certainty</em> is key.   I would <em>definitely</em> check what the pump thinks power consumption is, neither Mitsubishi nor your installer is going to take any notice at all of 'I allow 300w for the background house usage, which is the maximum, it varies between 100W and 300W, particularly as it is well known that the national average electricity consumption is about 400W.  I'm presuming that 'mixing tank temperature in the plot is a phantom.</p>
<p>To my mind if its <em>that</em> far from the spec under steady state conditions lasting 12 hours then its not working correctly.  It might be worth reviewing the absolute numbers as opposed to COPs/Percentages just to take a view on margins of error.</p>
<p>I dont have an Ecodan R290 so cant add personal experience.  There are however 5 Mitsubishi R290 heat pumps on <a href="https://heatpumpmonitor.org/?other=1&amp;filter=query:refrigerant:R290:eq:t,hp_manufacturer:Mitsubishi:eq:t&amp;period=all&amp;minDays=0" target="_blank" rel="noopener">openheatpumpmonitor</a>, it might be worth looking at those </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54829</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54824</link>
                        <pubDate>Mon, 22 Dec 2025 11:40:05 +0000</pubDate>
                        <description><![CDATA[@sheriff-fatman You may be able to vary the pump speed by using the controls on the pump.]]></description>
                        <content:encoded><![CDATA[@sheriff-fatman You may be able to vary the pump speed by using the controls on the pump.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54824</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54823</link>
                        <pubDate>Mon, 22 Dec 2025 11:38:42 +0000</pubDate>
                        <description><![CDATA[@jamespa The 2 pumps was a decision by the installer, I don&#039;t think that they are necessary but at the moment it is a small difference in energy consumption. They are in proportional pressur...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa The 2 pumps was a decision by the installer, I don't think that they are necessary but at the moment it is a small difference in energy consumption. They are in proportional pressure mode. I have a Joule Cyclone cylinder CY205L, no LLH.</p>
13153
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54823</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54809</link>
                        <pubDate>Mon, 22 Dec 2025 09:33:29 +0000</pubDate>
                        <description><![CDATA[Interesting.  Thanks for the info.That would explain the lack of movement in the flow speed and the delta T observations might just have been short-term variance, given the limited window.
<p>@sheriff-fatman The FTC7  with third party cylinder and pump does not control the pump speed, there is a menu item for pump speed and the value can be varied but the control unit does not have an output to control pump speed. Mitsubishi have confirmed this when I asked them.</p>
<br /><br />Interesting.  Thanks for the info.<br /><br />That would explain the lack of movement in the flow speed and the delta T observations might just have been short-term variance, given the limited window.
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mitsubishi-ecodan-r290-10kw-performance/paged/5/#post-54809</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 16:57:22 by W3 Total Cache
