									MIDEA MHC-V16W/D2RN8-Β Power Input Limitation - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-mhc-v16w-d2rn8-%ce%b2-power-input-limitation/</link>
            <lastBuildDate>Tue, 18 Aug 2026 04:55:11 +0000</lastBuildDate>
                        <title>RE: MIDEA MHC-V16W/D2RN8-Β Power Input Limitation</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-mhc-v16w-d2rn8-%ce%b2-power-input-limitation/#post-24594</link>
                        <pubDate>Sat, 09 Dec 2023 06:42:29 +0000</pubDate>
                        <description><![CDATA[I performed some more tests...
With power input limitation set to 8, the lowest output that I get from the ASHP is around 3kW with 10oC external temperature at 38oC water temperature (with ...]]></description>
                        <content:encoded><![CDATA[<p>I performed some more tests...</p>
<p>With power input limitation set to 8, the lowest output that I get from the ASHP is around 3kW with 10oC external temperature at 38oC water temperature (with WC).</p>
<p>With this setup I have now 2 cycles / hour ... I think it is better now...</p>
<p>There is no option to measure the COP but I consume 12kWh/24h for heating (140 sq.m. - fancoil thermsotats set at 23-24oC) </p>
<p>Have you managed to make it work lower?</p>
<p>Thank you very much!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>LamprosT</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-mhc-v16w-d2rn8-%ce%b2-power-input-limitation/#post-24594</guid>
                        <title>MIDEA MHC-V16W/D2RN8-Β Power Input Limitation</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-mhc-v16w-d2rn8-%ce%b2-power-input-limitation/#post-24171</link>
                        <pubDate>Sun, 03 Dec 2023 14:25:02 +0000</pubDate>
                        <description><![CDATA[Hello, I would like to ask a question.
I have installed a MIDEA MHC-V16W/D2RN8-Β heat pump with MIDEA fan coils and when the weather is hot outside (&gt;15oC) it cycles a lot at the heat mo...]]></description>
                        <content:encoded><![CDATA[<p>Hello, I would like to ask a question.</p>
<p>I have installed a MIDEA MHC-V16W/D2RN8-Β heat pump with MIDEA fan coils and when the weather is hot outside (&gt;15oC) it cycles a lot at the heat mode...</p>
<p>There is an option "Power Input Limitation" on the service menu. Does this reduce the capacity of the heat pump in order to have less cycling?</p>
<p>I have made some tests but I cannot figure what exactly happens with that option.</p>
<p>(I'm sorry for my bad English) </p>
5392]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-mhc-v16w-d2rn8-%ce%b2-power-input-limitation/#post-24171</guid>
Object Caching 55/59 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-08-18 05:55:11 by W3 Total Cache
