									Midea HP - how to force it to run at low temperature. - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-hp-how-to-force-it-to-run-at-low-temperature/</link>
            <lastBuildDate>Sun, 08 Nov 2026 01:52:39 +0000</lastBuildDate>
                        <title>Midea HP - how to force it to run at low temperature.</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-hp-how-to-force-it-to-run-at-low-temperature/#post-21133</link>
                        <pubDate>Tue, 05 Sep 2023 10:17:40 +0000</pubDate>
                        <description><![CDATA[Hello all,
I am running one of the midea clones (10kw &quot;Hyundai&quot;) to my full satisfaction. This is a DIY installation with the help of Graham Hendra&#039;s video&#039;s (many thanks!).
This summer I ...]]></description>
                        <content:encoded><![CDATA[<p>Hello all,</p>
<p>I am running one of the midea clones (10kw "Hyundai") to my full satisfaction. This is a DIY installation with the help of Graham Hendra's video's (many thanks!).</p>
<p>This summer I installed PV and thus have "free" electrical energy available. I have sunny weather at the moment and October is approaching so I wanted to take the opportunity and use the sunny weather to heat up our slab (we have full UFH).</p>
<p>I have set a schedule for the HP to run at 27C between 9am and 6pm. This is interrupted for DHW between 1-3pm. The HP is separated from the UFH with a heat exchanger and the pump for the UFH runs 08:58-13:02 and 14:48-18:02. </p>
<p>What I am seeing is that the HP heats for some 30-45 minutes in the morning to never switch on for heating again. It does run its DHW cycle though. I noticed that the HP showed an ambient temperature of 27 or so degrees (it is at a sunny spot) so I already raised the max ambient temperature for heating (T4HMAX) to 35C. The return flow temperature that I read does not go above 22C so I guess the HP should see some a demand for heat.</p>
<p>Because we have wooden flooring, I do not want to set too high of an input temperature and start with 25-27 degrees.</p>
<p>Does anyone of you have an idea how I can force my HP to just run at 25, 26, 27 degrees between 9 and 6?</p>
<p>Many thanks for your suggestions and advice!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>MPHB</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/midea-hp-how-to-force-it-to-run-at-low-temperature/#post-21133</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 01:52:39 by W3 Total Cache
