									Mid terrace - ASHP Install location - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/</link>
            <lastBuildDate>Fri, 15 May 2026 01:43:01 +0000</lastBuildDate>
                        <title>RE: Mid terrace - ASHP Install location</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/4/#post-28939</link>
                        <pubDate>Mon, 18 Mar 2024 16:39:52 +0000</pubDate>
                        <description><![CDATA[If you used the wall mounted option, it would improve air flow as there is no fence that high. You still have the problem of the 1m rule for planning though.]]></description>
                        <content:encoded><![CDATA[<p>If you used the wall mounted option, it would improve air flow as there is no fence that high. You still have the problem of the 1m rule for planning though.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/4/#post-28939</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28938</link>
                        <pubDate>Mon, 18 Mar 2024 16:30:13 +0000</pubDate>
                        <description><![CDATA[@samiebon1 No complaints or problems, there is a big enough space between it and houses behind so sound is not an issue. Lots of the houses a long here have significant extensions into their...]]></description>
                        <content:encoded><![CDATA[@samiebon1 No complaints or problems, there is a big enough space between it and houses behind so sound is not an issue. Lots of the houses a long here have significant extensions into their back yards, I don't have any, so I imagine if they are all okay the heat pump would be fine. Although I didn't do a formal planning application.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>EcoBaker</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28938</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28937</link>
                        <pubDate>Mon, 18 Mar 2024 16:23:31 +0000</pubDate>
                        <description><![CDATA[@ecobaker Thanks for the pictures! Did you have any planning application challenges with that? Just thinking from the visual impact. 
I think getting it past the partner test would be harde...]]></description>
                        <content:encoded><![CDATA[<p>@ecobaker Thanks for the pictures! Did you have any planning application challenges with that? Just thinking from the visual impact. </p>
<p>I think getting it past the partner test would be harder than the planning application!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>samiebon1</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28937</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28935</link>
                        <pubDate>Mon, 18 Mar 2024 15:59:47 +0000</pubDate>
                        <description><![CDATA[Have you considered wall mounting it. I&#039;m in a similar 1915 two bed mid terrace. On the back wall of my house there isn&#039;t a window for the first floor, so there was space to mount the ASHP, ...]]></description>
                        <content:encoded><![CDATA[<p>Have you considered wall mounting it. I'm in a similar 1915 two bed mid terrace. On the back wall of my house there isn't a window for the first floor, so there was space to mount the ASHP, the flow and return follow the gutter line, round the side of the house and into the loft space where the hot water tank is. See the pics.</p>
6799
6801
6800
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28935</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28913</link>
                        <pubDate>Sun, 17 Mar 2024 17:57:16 +0000</pubDate>
                        <description><![CDATA[&#x1f60e;]]></description>
<p>data as a singular noun is no longer incorrect; it has been made correct by common usage and understanding.</p>
<p>This is the sort of English up with which I shall not put!</p>
<p>&#x1f60e; </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28913</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28906</link>
                        <pubDate>Sun, 17 Mar 2024 13:29:31 +0000</pubDate>
                        <description><![CDATA[This is the sort of English up with which I shall not put!]]></description>
<p>This is the sort of English up with which I shall not put!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28906</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28905</link>
                        <pubDate>Sun, 17 Mar 2024 11:05:09 +0000</pubDate>
                        <description><![CDATA[One datum, many data. That is the grammatically correct form. However, English is a living language and so, as @editor says, data as a singular noun is no longer incorrect; it has been made ...]]></description>
                        <content:encoded><![CDATA[<p>One datum, many data. That is the grammatically correct form. However, English is a living language and so, as @editor says, data as a singular noun is no longer incorrect; it has been made correct by common usage and understanding.</p>
<p>Interesting that language is one of the few instances where many wrongs do indeed make a right.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28905</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28904</link>
                        <pubDate>Sun, 17 Mar 2024 10:55:37 +0000</pubDate>
                        <description><![CDATA[@editor That’s absobloominglutely fine Mars, I’m one of those annoying sods who constantly shout at the radio (Radio Four mostly but increasingly, Radio Three as well these days!) for use of...]]></description>
                        <content:encoded><![CDATA[@editor That’s absobloominglutely fine Mars, I’m one of those annoying sods who constantly shout at the radio (Radio Four mostly but increasingly, Radio Three as well these days!) for use of poor enunciation, pronunciation, and grammar! I feel that those in such positions of influence on how we speak should be setting a good example. Oops Sorry! I’ll dismount my soapbox now and get on with preparing lunch… Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28904</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28903</link>
                        <pubDate>Sun, 17 Mar 2024 10:35:10 +0000</pubDate>
                        <description><![CDATA[Love the grammatical attention to detail in your post construction. &#x1f923;
I&#039;m a word and grammar geek. Data is traditionally considered a plural noun, so &quot;here are the data&quot; is grammati...]]></description>
<li>Here is the data (here are the data?)</li>
<p>Love the grammatical attention to detail in your post construction. &#x1f923;</p>
<p><span>I'm a word and grammar geek. Data is traditionally considered a plural noun, so "here are the data" is grammatically correct. In modern usage, "data" is now treated as a mass noun (like "information"), so it takes a singular verb form, as in "here is the data." </span></p>
<p>I just sounds odd when you say "here are the data" out loud.</p>
<p>Apologies for the brief deviation away from the topic. As you were.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28903</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28902</link>
                        <pubDate>Sun, 17 Mar 2024 10:16:12 +0000</pubDate>
                        <description><![CDATA[@morgan Here is the data (here are the data?) from the last couple of weeks taken from my Homely Dashboard app. I have left out the less relevant items on the graphs but think this shows the...]]></description>
                        <content:encoded><![CDATA[<ul>
<li>@morgan Here is the data (here are the data?) from the last couple of weeks taken from my Homely Dashboard app. I have left out the less relevant items on the graphs but think this shows the salient figures. (I have asked Homely if it might be
6797
possible to extend the history timeline so as I might be able to see the SCOP as well as the COP.) Regards, Toodles.</li>
</ul>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/mid-terrace-ashp-install-location/paged/3/#post-28902</guid>
