									Melcloud Room temperature reading - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/</link>
            <lastBuildDate>Mon, 13 Jul 2026 12:35:23 +0000</lastBuildDate>
                        <title>RE: Melcloud Room temperature reading</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24133</link>
                        <pubDate>Sat, 02 Dec 2023 21:07:25 +0000</pubDate>
                        <description><![CDATA[@davidalgarve  I don’t have a hydro box so your system is different to mine.  I wouldn’t worry about it if you are using WC it doesn’t use those values anyway.]]></description>
                        <content:encoded><![CDATA[<p>@davidalgarve  I don’t have a hydro box so your system is different to mine.  I wouldn’t worry about it if you are using WC it doesn’t use those values anyway.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24133</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24131</link>
                        <pubDate>Sat, 02 Dec 2023 20:59:30 +0000</pubDate>
                        <description><![CDATA[Obviously I am completely misunderstanding because I thought that the FTC5 was the controller that is mounted on the front of my Hydrobox EHSC-VM2D and my Hydrobox is effectively outside in ...]]></description>
                        <content:encoded><![CDATA[<p>Obviously I am completely misunderstanding because I thought that the FTC5 was the controller that is mounted on the front of my Hydrobox EHSC-VM2D and my Hydrobox is effectively outside in a pool pump room.</p>
<p>Admittedly the whole Hydrobox will gain some heat, but it seems strange that it consistently outputs close to 20C when the ambient goes down to 8-9C.</p>
<p>Also, could you explain why this always give a temperature on the MelCloud, but not on the control panel, using any of the 3 configuration options?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24131</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24126</link>
                        <pubDate>Sat, 02 Dec 2023 20:22:30 +0000</pubDate>
                        <description><![CDATA[The FTC5 is the big metal box with ecodan on the front the remote ftc5 controller is the screen you are looking at.  The thermistor is inside the controller with the screen and will measure ...]]></description>
                        <content:encoded><![CDATA[<p>The FTC5 is the big metal box with ecodan on the front the remote ftc5 controller is the screen you are looking at.  The thermistor is inside the controller with the screen and will measure the temp of where ever it is located and that is the temp you are seeing in melcloud</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24126</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24115</link>
                        <pubDate>Sat, 02 Dec 2023 19:08:34 +0000</pubDate>
                        <description><![CDATA[Sorry for being so dense, but I still do not understand. Where is the &quot;remote controller thermistor&quot; because I don&#039;t have a remote controller. Also, why is MelCloud picking up a temperature ...]]></description>
                        <content:encoded><![CDATA[<p>Sorry for being so dense, but I still do not understand. Where is the "<span>remote controller thermistor" because I don't have a remote controller. Also, why is MelCloud picking up a temperature and </span><span>the FTC5 not doing so. I can't see what in my house, could be forwarding a temperature of 19C right now. </span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24115</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24104</link>
                        <pubDate>Sat, 02 Dec 2023 17:36:47 +0000</pubDate>
                        <description><![CDATA[this is what kev is referring to it only appears in auto adapt mode and it’s getting the values from the remote controller thermistor.  As Kev said in WC mode they don’t do anything.  You ca...]]></description>
                        <content:encoded><![CDATA[<p>this is what kev is referring to it only appears in auto adapt mode and it’s getting the values from the remote controller thermistor.  As Kev said in WC mode they don’t do anything.  You can see in my MELCloud shot the room temp and set temp match</p>
5377
5376
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24104</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24091</link>
                        <pubDate>Sat, 02 Dec 2023 15:00:00 +0000</pubDate>
                        <description><![CDATA[No Problem! The House symbol does not appear on any of the 3 options on the FC 5. I have just tried the other two options and then refreshed MelCloud and the Room Temperature was the same on...]]></description>
                        <content:encoded><![CDATA[<p>No Problem! The House symbol does not appear on any of the 3 options on the FC 5. I have just tried the other two options and then refreshed MelCloud and the Room Temperature was the same on all 3 i.e. 19C. That is as low as I have seen it but does not match ambient at 13C or living room at 21C. I did wonder if it could pick up a wireless signal from a Mitsu AC unit in that room, but that is saying room temp of 20C. These are small differences now but will increase as ambient drops in evening.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24091</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24086</link>
                        <pubDate>Sat, 02 Dec 2023 14:40:05 +0000</pubDate>
                        <description><![CDATA[No you did make yourself clear, it was me! Apologies, the little house symbol isn&#039;t there when on WC.  If you switch to room temp control on the main panel what does it say?  Is it there and...]]></description>
<p>Perhaps I didn't make myself clear in that the room temperature figure that I was referring to is on the Melcloud app. It does not appear on the FTC5. </p>
<p>There is no House symbol on the FTC5 - only the DHW temp</p>
<p>There is only one cable from the FTC5 and that terminates on the main panel at terminal CN22BU</p>
<p>See photos</p>
5369
5370
5371
<p>No you did make yourself clear, it was me! Apologies, the little house symbol isn't there when on WC.  If you switch to room temp control on the main panel what does it say?  Is it there and is it the same as Melcloud?  But again, on WC it isn't used for anything, which I suppose is why it's not there.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24086</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24069</link>
                        <pubDate>Sat, 02 Dec 2023 13:03:00 +0000</pubDate>
                        <description><![CDATA[Perhaps I didn&#039;t make myself clear in that the room temperature figure that I was referring to is on the Melcloud app. It does not appear on the FTC5. 
There is no House symbol on the FTC5 ...]]></description>
                        <content:encoded><![CDATA[<p>Perhaps I didn't make myself clear in that the room temperature figure that I was referring to is on the Melcloud app. It does not appear on the FTC5. </p>
<p>See photos</p>
5369
5370
5371
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24069</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24060</link>
                        <pubDate>Sat, 02 Dec 2023 11:46:34 +0000</pubDate>
                        <description><![CDATA[The room temp sensor isn&#039;t inside the FTC but inside the little control panel.  This comes with a long cable so doesn&#039;t have to be beside or near the FTC itself.The room temp is displayed on...]]></description>
<p>Thanks for your response Kev M.</p>
<p>I am becoming more familiar with the system and I am reasonably optimistic, heading into winter, that I have a much better set up than was done by the contractor at this time last year. However, this is one area where I have not understood what I have, before going on to make changes. Background is that I have an upside down house with radiators mostly fitted with TRV's (legacy of previous gas boiler set up) and a PUHZ-SW120YHA feeding a buffer tank or into a DHW tank</p>
<p>The room setting is on "Main RC" but there is no external wired temperature measurement device. If I understand you correctly, in that case the measurement would come from inside the FTC5, but I am sure that the FTC5 mounted on the Hydrobox in the pool pump room  is not at a temperature of circa 20C with an OAT of 11C.</p>
<p>I am trying to optimise for weather compensation and not a specific room or zone and I understand the options are: TH1/ MainRC/Room RC1-8/Time Zone. </p>
<p>So what would a sensible setting be for Room Sensor? </p>
<p>The room temp sensor isn't inside the FTC but inside the little control panel.  This comes with a long cable so doesn't have to be beside or near the FTC itself.The room temp is displayed on the control panel beside the little house symbol with a thermometer inside.  What does that say? </p>
<p>I think Main RC is the setting you want</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24060</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24043</link>
                        <pubDate>Sat, 02 Dec 2023 09:49:47 +0000</pubDate>
                        <description><![CDATA[Thanks for your response Kev M.
I am becoming more familiar with the system and I am reasonably optimistic, heading into winter, that I have a much better set up than was done by the contra...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for your response Kev M.</p>
<p>So what would a sensible setting be for Room Sensor? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/melcloud-room-temperature-reading/#post-24043</guid>
Object Caching 57/62 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-07-13 13:35:23 by W3 Total Cache
