									FYI :- JG Speedfit pipes and heat pumps - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/</link>
            <lastBuildDate>Mon, 20 Jul 2026 09:51:37 +0000</lastBuildDate>
                        <title>RE: FYI :- JG Speedfit pipes and heat pumps</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/#post-20018</link>
                        <pubDate>Fri, 09 Jun 2023 06:33:23 +0000</pubDate>
                        <description><![CDATA[Sadly still no word from second line support. I&#039;ll give them a ring today, rather than waiting for a response to my email.
Indeed Speedfit appear to be promoting the UFH applications, so ...]]></description>
                        <content:encoded><![CDATA[<p>Sadly still no word from second line support. I'll give them a ring today, rather than waiting for a response to my email.</p>
<p>The UFH manifold in my old property was speedfit pushfit too so they must expected pretty much continuous use there.</p>
<p>Indeed Speedfit appear to be promoting the UFH applications, so it is a bit of a mystery as to why a heat pump would not be supported. I would think that matters is the flow of water and the temperature rather than the thing which warms up the water.</p>
<p>After 10 years no problems.</p>
<p>I felt that the Speedfit system's guarantee had a certain value to it (they being confident that the pipe will last), otherwise one would use other brands of polybutylene (or Pert/Al/Pert) pipe at half the price.</p>
<div id="accel-snackbar" style="left: 50%;top: 50px"> </div>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>ChickenBig</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/#post-20018</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/#post-19847</link>
                        <pubDate>Sat, 03 Jun 2023 14:42:51 +0000</pubDate>
                        <description><![CDATA[Hi
I installed my first heat pump using JP Speedfit fitting entirely. After 10 years no problems. I didnt run it continuously though as the property was super insulated. Just fitted a 5kW s...]]></description>
<p>I installed my first heat pump using JP Speedfit fitting entirely. After 10 years no problems. I didnt run it continuously though as the property was super insulated. Just fitted a 5kW samsung in my new property using the existing radiator pipework but used speedfit elbows on the radiator tails but I did use Hep2o inserts and pipes as they are thinner and metal.</p>
<p>If you have any awkward joints which would be a bitch to get to you could always put a compression joint on those.</p>
<p>From my experience I have had no issues using plastic pipe and fittings with a heat pump. My flow rate is fine as is my COP. Perhaps there might be more of an issue if using a larger sized heat pump?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/#post-19847</guid>
                        <title>FYI :- JG Speedfit pipes and heat pumps</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/#post-19841</link>
                        <pubDate>Fri, 02 Jun 2023 18:57:39 +0000</pubDate>
                        <description><![CDATA[I&#039;ve been considering installing a heat pump using plastic pipes from JG Speedfit for ease of fit (well ... having wrestled with PB pipe it may not be so speedy to fit). Having bought a load...]]></description>
                        <content:encoded><![CDATA[<p>I've been considering installing a heat pump using plastic pipes from JG Speedfit for ease of fit (well ... having wrestled with PB pipe it may not be so speedy to fit). Having bought a load of pipe I thought it best to double-check with JG Speedfit about compatibility; they offer a 50 year guarantee for central heating, cold and hot water. However they exclude recirculating hot water systems from the guarantee, which made me concerned.</p>
<p>The helpdesk stated that the guarantee applies where it will not be constantly running, which seems to imply that a finely tuned heat pump (one operating at reasonable flow for half the year) is out of guarantee. I was given the contact details of second line support but they've not got back to me on this issue.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/jg-speedfit-pipes-and-heat-pumps/#post-19841</guid>
Served from: renewableheatinghub.co.uk @ 2026-07-20 10:51:37 by W3 Total Cache
