									Is my heat pump correctly sized? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/</link>
            <lastBuildDate>Sun, 15 Mar 2026 23:54:43 +0000</lastBuildDate>
                        <title>RE: Is my heat pump correctly sized?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/paged/2/#post-2565</link>
                        <pubDate>Wed, 27 Oct 2021 20:33:58 +0000</pubDate>
                        <description><![CDATA[@helensq, welcome to the forums. The reliability of the system comes down to how well it’s designed and installed.
Heat pumps do work. But they must be sized and installed correctly. I do t...]]></description>
                        <content:encoded><![CDATA[<p>@helensq, welcome to the forums. The reliability of the system comes down to how well it’s designed and installed.</p>
<p>Heat pumps do work. But they must be sized and installed correctly. I do think they require tinkering and tweaking to get them working efficiently, but the degree of tinkering will vary from person to person. <br /><br />The biggest issue facing heat pumps for the foreseeable future will be sky high electricity tariffs. This is going to make pumps very expensive to run compared to gas and oil. </p>
<p>Leaks are not an issue reserved for heat pumps. Our leak that we dealt with recently stemmed from a vent on our back up oil boiler.</p>
<p>If you specific questions, I’d be happy to address and answer those.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/paged/2/#post-2565</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2558</link>
                        <pubDate>Wed, 27 Oct 2021 17:50:19 +0000</pubDate>
                        <description><![CDATA[Hi
New member here looking in earnest at ASHP for our imminent new self build.  I had assumed that it was a no brainer but am beginning to wonder…
I am particularly struck by how much ‘tin...]]></description>
<p>New member here looking in earnest at ASHP for our imminent new self build.  I had assumed that it was a no brainer but am beginning to wonder…</p>
<p>I am particularly struck by how much ‘tinkering’ and hands-on adjustments have to be done just to keep it running - clearing filters, dealing with leaks, data monitoring and adjusting settings etc.  Is that because the systems are more fragile and unstable than the marketers would have us believe? </p>
<p>We will be retirees and planning on using this system through into our frail old age, so want a system that will give us straightforward, reliable warmth as and when we are old and infirm.  We are beginning to think we would essentially be early adopters of a technology that still needs lots of maturing and therefore not a good idea at this stage?</p>
<p>Would be very interested in your views.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>helensq</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2558</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2524</link>
                        <pubDate>Sun, 24 Oct 2021 07:03:06 +0000</pubDate>
                        <description><![CDATA[@kev-m, it always happens in winter. Three years on the trot, but like I said to Derek at least it’s happened in October as opposed to December.]]></description>
                        <content:encoded><![CDATA[<p>@kev-m, it always happens in winter. Three years on the trot, but like I said to Derek at least it’s happened in October as opposed to December.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2524</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2523</link>
                        <pubDate>Sun, 24 Oct 2021 07:01:46 +0000</pubDate>
                        <description><![CDATA[@derek-m, we’ve had two outages in back to back years in December so an October outage is definitely better. 
Partially good news is that we’ve found a wet spot that’s originating from behi...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m, we’ve had two outages in back to back years in December so an October outage is definitely better. </p>
<p>Partially good news is that we’ve found a wet spot that’s originating from behind our oil boiler (the back up) which indicates something’s gone wrong there. Contacted about six heat engineers yesterday who just aren’t interested in coming out or just cleared our calls.</p>
<p>Home Emergency insurance (AXA) equally useless in sourcing anyone. Hopefully Global Energy can send someone out early next week. House was snug though with the fires going. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2523</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2521</link>
                        <pubDate>Sat, 23 Oct 2021 17:24:26 +0000</pubDate>
                        <description><![CDATA[Posted by: @editor 
Our system went on the fritz last night, so we&#039;re without heating again. Smell of glycol in the utility room, pressure on the expansion vessel has dropped to zero and no...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="1" data-postid="2516" data-mention="editor">
<div class="wpforo-post-quote-author"><strong> Posted by: @editor </strong></div>
<p>Our system went on the fritz last night, so we're without heating again. Smell of glycol in the utility room, pressure on the expansion vessel has dropped to zero and no visible or obvious leaks. Getting hold of a plumber is a nightmare (as always). So it's back to the fires for today and tomorrow and hopefully Global Energy Systems can get someone out to us early next week.  </p>
<p>Hi Mars,</p>
<p>Looking on the bright side, at least it did not happen in the depths of Winter. Have you tried re-pressurising your system and looking for leaks, also the rate by which the pressure falls will give some indication as to the size of the leak.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2521</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2520</link>
                        <pubDate>Sat, 23 Oct 2021 15:28:49 +0000</pubDate>
                        <description><![CDATA[@editor, oh no, just the wrong time of year for that to happen. Hope you get it sorted soon.]]></description>
                        <content:encoded><![CDATA[<p>@editor, oh no, just the wrong time of year for that to happen. Hope you get it sorted soon.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2520</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2519</link>
                        <pubDate>Sat, 23 Oct 2021 15:27:16 +0000</pubDate>
                        <description><![CDATA[@saz, it sounds like you are familiar with ASHPs.  The Arotherm plus claims to be able to heat to 60 deg plus or so efficiently rather than the 50 plus from others.  It&#039;s supposed to be able...]]></description>
                        <content:encoded><![CDATA[<p>@saz, it sounds like you are familiar with ASHPs.  The Arotherm plus claims to be able to heat to 60 deg plus or so efficiently rather than the 50 plus from others.  It's supposed to be able to cope with very cold weather better and/or run with smaller radiators but it sounds like something isn't right with yours.  It's definitely worth checking the flow temps.  If your house was heated by a flow temp of 50 degrees (or whatever) then it still will be irrespective of which heat pump supplies the energy. </p>
<p>Unless your HW is set very high or it's very cold weather (well below zero) your immersion shouldn't be on.  As you say, your high temp Arotherm should just about be able to to do the Legio cycle itself so you should definitely have a word with the installer.  Is the heat pump heating the HW at all?  Can you turn the immersion off and see what happens?</p>
<p>We have a smallish 4 bed bungalow that's quite well insulated and our installer thought an 11 kW pump was too small.  We have a 14kW one.     </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2519</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2518</link>
                        <pubDate>Sat, 23 Oct 2021 14:37:13 +0000</pubDate>
                        <description><![CDATA[@saz, we have a unit from Global Energy Systems - a British brand. We have an immersion connected to our solar PV so we were able to reheat out hot water at least. The fires are on and the h...]]></description>
                        <content:encoded><![CDATA[<p>@saz, we have a unit from Global Energy Systems - a British brand. We have an immersion connected to our solar PV so we were able to reheat out hot water at least. The fires are on and the heaters all be in the bedroom tonight connected to a smart plug to come on and go off throughout the night.</p>
<p>If there was a leak, it would have been better because we'd know what were dealing with - but we can't ID the issue. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2518</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2517</link>
                        <pubDate>Sat, 23 Oct 2021 14:22:19 +0000</pubDate>
                        <description><![CDATA[Oh no @editor Am I right in thinking you have the Arotherm plus also? I&#039;m using a portable radiator and boiling kettles again at mo until this immersion issue of mine is sorted. Do you have ...]]></description>
                        <content:encoded><![CDATA[<p>Oh no @editor Am I right in thinking you have the Arotherm plus also? I'm using a portable radiator and boiling kettles again at mo until this immersion issue of mine is sorted. Do you have an immersion on your system? If so, is it on a fused spur?</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Saz</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2517</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2516</link>
                        <pubDate>Sat, 23 Oct 2021 13:48:57 +0000</pubDate>
                        <description><![CDATA[Our system went on the fritz last night, so we&#039;re without heating again. Smell of glycol in the utility room, pressure on the expansion vessel has dropped to zero and no visible or obvious l...]]></description>
                        <content:encoded><![CDATA[<p>Our system went on the fritz last night, so we're without heating again. Smell of glycol in the utility room, pressure on the expansion vessel has dropped to zero and no visible or obvious leaks. Getting hold of a plumber is a nightmare (as always). So it's back to the fires for today and tomorrow and hopefully Global Energy Systems can get someone out to us early next week.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-my-heat-pump-correctly-sized/#post-2516</guid>
