									Is it KISS or constant – weather compensation vs. set flow temperature? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/</link>
            <lastBuildDate>Fri, 13 Nov 2026 16:46:28 +0000</lastBuildDate>
                        <title>RE: Is it KISS or constant – weather compensation vs. set flow temperature?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-45265</link>
                        <pubDate>Mon, 14 Apr 2025 10:40:34 +0000</pubDate>
                        <description><![CDATA[@cliffhanger Mine has a &#039;space heating off&#039; setting!  Otherwise turn down thermostat if you have one and it&#039;s set up to call for heat]]></description>
                        <content:encoded><![CDATA[@cliffhanger Mine has a 'space heating off' setting!  Otherwise turn down thermostat if you have one and it's set up to call for heat]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-45265</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-45261</link>
                        <pubDate>Mon, 14 Apr 2025 07:59:00 +0000</pubDate>
                        <description><![CDATA[Hi
Just as an aside.  My system is heating only.
What is the best way of turning a weather compensation setup off in the summer?   I thought of turning the stat back on to its lowest temp,...]]></description>
<p>Just as an aside.  My system is heating only.</p>
<p>What is the best way of turning a weather compensation setup off in the summer?   I thought of turning the stat back on to its lowest temp, in this case 10c.  Won't go any lower. </p>
<p>Or setting the heating curve to its lowest?</p>
<p>Cliff</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>cliffhanger</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-45261</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44965</link>
                        <pubDate>Thu, 03 Apr 2025 15:09:36 +0000</pubDate>
                        <description><![CDATA[I had to laugh at this as I do exactly the same thing, I read on here someone explain it well, the body is running at 36c so anything less will feel cold. As I explain to friends it is actua...]]></description>
                        <content:encoded><![CDATA[I had to laugh at this as I do exactly the same thing, I read on here someone explain it well, the body is running at 36c so anything less will feel cold. As I explain to friends it is actually magic that heats my house! <br />
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Grantmethestrength</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44965</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44645</link>
                        <pubDate>Fri, 28 Mar 2025 09:20:48 +0000</pubDate>
                        <description><![CDATA[We ran our radiations at anywhere between 30-35C over winter. At 30C I struggle to tell they are on. If I place my face over the top of the radiator, I can just about feel warm air convectin...]]></description>
                        <content:encoded><![CDATA[<p>We ran our radiations at anywhere between 30-35C over winter. At 30C I struggle to tell they are on. If I place my face over the top of the radiator, I can just about feel warm air convecting on my face. At 32C I can feel they are warm to the touch, and at 35C they are (relatively) positively hot!</p>
<p>I still walk around touching the radiators to see if they are on - I just need to trust the room thermostat, which doesn't lie.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44645</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44640</link>
                        <pubDate>Fri, 28 Mar 2025 09:01:53 +0000</pubDate>
                        <description><![CDATA[Indeed.  Its weird at first but you get used to it and actually it is more comfortable because the temperature gradients are less.
There is a school of thought pursued by some installers th...]]></description>
<p>What's struck me is how cool the rads are.  They don't feel they could warm anything!  But they do of course.  Now we are at the end of March the system's not going to be tested at lower temperatures which to me is the breaker.</p>
<p>Indeed.  Its weird at first but you get used to it and actually it is more comfortable because the temperature gradients are less.</p>
<p>There is a school of thought pursued by some installers that having cool radiators leads to call outs (which is probably true).  Thus some installers force a minimum FT of 37, which is roughly the point at which radiators feel warm.  This of course increases the cost to the householder.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44640</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44638</link>
                        <pubDate>Fri, 28 Mar 2025 08:53:48 +0000</pubDate>
                        <description><![CDATA[Okay. I have setup the system using just weather compensation.   There is something called &#039;thermal blockade&#039; on my smart controller which turns off the stat rather than turn it to maximum. ...]]></description>
                        <content:encoded><![CDATA[<p>Okay. I have setup the system using just weather compensation.   There is something called 'thermal blockade' on my smart controller which turns off the stat rather than turn it to maximum.  </p>
<p>I'm going to video the heat curve but at the moment it starts at 18(20c) and runs to 45(-30).  -5c = 33c. The OAT is 10c and the system is stable at 19.5c.   I tried a lower curve but the pump cycled as expected, 25c is the lowest it will go.</p>
<p>To be continued</p>
<p>Cliff</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44638</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44048</link>
                        <pubDate>Sun, 16 Mar 2025 09:38:47 +0000</pubDate>
                        <description><![CDATA[Away at present. Hence the delay.  Will get back asap.
Cliff]]></description>
                        <content:encoded><![CDATA[<p>Away at present. Hence the delay.  Will get back asap.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/3/#post-44048</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/2/#post-43858</link>
                        <pubDate>Thu, 13 Mar 2025 14:08:11 +0000</pubDate>
                        <description><![CDATA[Thanks. I&#039;ve seen the video several times at the beginning and frankly its useless.   I expected more detail.   If as cathode Ray says to largely ignore the design temp then it become easier...]]></description>
<p>You should watch it but Grant seem to have come up with the worst of all options (no surprise frankly!) and then described it in a muddle headed way.  To first order I think you use it like this</p>
<p>The leftmost point on the curve is fixed.</p>
<p>You can adjust the outdoor temperature at which the flow temperature reaches its max (60C) by adjusting the 'curve' control. </p>
<p>You can adjust an intermediate point (ant thus the curvature) using the 'shift control</p>
<p>So I would start by setting an initial curve using a combination of the two which passes through 45@-3 (call this 42<a style="cursor: auto" title="Anonymous">@0</a>, rather easier to see)</p>
<p>Then shift it down bit by bit in accordance with the bulletted instructions above, probably using the 'shift' control or whichever one/combination keeps it approximately straight, or with a slight uplift from straight in the 3-10 region</p>
<p>Thanks. I've seen the video several times at the beginning and frankly its useless.   I expected more detail.   If as cathode Ray says to largely ignore the design temp then it become easier to experiment.</p>
<p>I'll get back soon</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/2/#post-43858</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/2/#post-43853</link>
                        <pubDate>Thu, 13 Mar 2025 13:38:10 +0000</pubDate>
                        <description><![CDATA[@cliffhanger suggest you reread my post above, I edited it after you looked at it.  I found a video which helps a bit, but Grant do seem to have come up with something that isnt particularly...]]></description>
                        <content:encoded><![CDATA[<p><span>@cliffhanger suggest you reread my post above, I edited it after you looked at it.  I found a video which helps a bit, but Grant do seem to have come up with something that isnt particularly self-explanatory (its nothing like Vaillant, Fujitsu, ideal who use preset curves)</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/2/#post-43853</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/2/#post-43852</link>
                        <pubDate>Thu, 13 Mar 2025 13:25:03 +0000</pubDate>
All one can say is many thanks for the help from all and more importantly patience!
Will now push on with pictures.   I do have the manual incidentally.  Yeah it&#039;s not altogether...]]></description>
<p>All one can say is many thanks for the help from all and more importantly patience!</p>
<p>Will now push on with pictures.   I do have the manual incidentally.  Yeah it's not altogether clear.</p>
<p>Regards</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/is-it-kiss-or-constant/paged/2/#post-43852</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 16:46:28 by W3 Total Cache
