Solar PV installed, now time for an ASHP
Agreed, in fact, the company that carried out a full survey earlier this year were very particular about what was and what wasn’t allowed within the MCS guidelines to comply with the BUS grant. I suspect that keeping the old (to them, undersized) tank would have been a no-no. I wanted a small tank but they insisted the tank had to follow some guidelines about number of bedrooms and the minimum tank capacity. I began to feel that this wasn’t a case of installing a system I could use but that of a typical user when I sell the house (no such plans by the way) how much of this was caution to ensure MCS approval I know not.
Regards, Toodles
Posted by: @jeff
Hi Jeff,
What happened to bathe with a 'friend', to save water and energy, that being 'heat' energy. 😋
- 2,112 Topics
- 46.4 K Posts
- 35 Online
- 3,408 Members
@prunus, @jamespa is correct, but removing the buffer ...
By Brendon Uys , 4 hours ago
By Mars , 22 hours ago
By Prunus , 1 day ago
By benson , 3 days ago
By Wh0am3ye , 4 days ago
By TechnoGeek , 6 days ago
By seatonian , 1 week ago
