									Ideal HP290 14kW ASHP - how to optimise - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/</link>
            <lastBuildDate>Tue, 19 May 2026 07:39:42 +0000</lastBuildDate>
                        <title>RE: Ideal HP290 14kW ASHP - how to optimise</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/7/#post-60903</link>
                        <pubDate>Mon, 23 Mar 2026 19:02:33 +0000</pubDate>
                        <description><![CDATA[@cmartinbwmba - this might be useful background knowledge. I had a software/firmware upgrade last week. This caused two issues. Firstly it erased all performance data from 2025 from my contr...]]></description>
                        <content:encoded><![CDATA[<p>@cmartinbwmba - this might be useful background knowledge. I had a software/firmware upgrade last week. This caused two issues. Firstly it erased all performance data from 2025 from my control box (note my HP was changed in December). Secondly the firmware upgrade stops all historical data being recorded month by month.  I will have to wait for the 12 month anniversary of the upgrade before it gets written into the control box data for 2026 March to 2027 March. The iLetComfort app has retained all data however. </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Davesoa</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/7/#post-60903</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/7/#post-59428</link>
                        <pubDate>Sun, 22 Feb 2026 22:56:51 +0000</pubDate>
                        <description><![CDATA[Hi
You can get a stethoscope for less than 10€ on Amazon to listen to your pipes.
Candidates are heat pump compressor, fan, circulator or circulators if you have several.
Then turn off ci...]]></description>
                        <content:encoded><![CDATA[<p>due to the continuing high-pitched noise through the pipes</p>
<p>Hi</p>
<p>You can get a stethoscope for less than 10€ on Amazon to listen to your pipes.</p>
<p>Candidates are heat pump compressor, fan, circulator or circulators if you have several.</p>
<p>Then turn off circulators one by one, then turn off heat pump with the thermostat. It'll probably stop the compressor immediately then still run the internal circulator for a few minutes. Same when it starts, the circulator will start then run for a few minutes, then the fan, then the compressor starts. So you can find the culprit depending on what's on when the noise appears.</p>
<p>If vibration comes from the heat pump and travels through pipes you can put in a flex hose in between to stop propagation. Another culprit can be a bit of junk stuck in a circulator impeller.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/7/#post-59428</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58547</link>
                        <pubDate>Wed, 11 Feb 2026 12:07:04 +0000</pubDate>
                        <description><![CDATA[@ashp-bobba brill thanks again!]]></description>
                        <content:encoded><![CDATA[@ashp-bobba brill thanks again!]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>cmartinbwmba</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58547</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58546</link>
                        <pubDate>Wed, 11 Feb 2026 11:56:23 +0000</pubDate>
                        <description><![CDATA[Perfect this looks like Easy MCS format: so they have design you for 50 flow at -3. So what I advised you 47at -3 is a good start. 
<p>@ashp-bobba couldn't find the design with my handover papers but here is a digital copy they have supplied (I think)</p>
14095
<p>Perfect this looks like Easy MCS format: so they have design you for 50 flow at -3. So what I advised you 47at -3 is a good start. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58546</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58539</link>
                        <pubDate>Wed, 11 Feb 2026 10:54:46 +0000</pubDate>
                        <description><![CDATA[@ashp-bobba couldn&#039;t find the design with my handover papers but here is a digital copy they have supplied (I think)]]></description>
                        <content:encoded><![CDATA[@ashp-bobba couldn't find the design with my handover papers but here is a digital copy they have supplied (I think)
14095]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58539</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58450</link>
                        <pubDate>Mon, 09 Feb 2026 20:48:13 +0000</pubDate>
                        <description><![CDATA[Will dig this out from the document trove sometime hopefully!]]></description>
                        <content:encoded><![CDATA[<p>Will dig this out from the document trove sometime hopefully!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58450</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58449</link>
                        <pubDate>Mon, 09 Feb 2026 20:34:13 +0000</pubDate>
                        <description><![CDATA[Great, rads are good, the curve i gave you is more of a rads design. Try that and see how it goes.
<p>@cmartinbwmba</p>
14082
<p>if you find this to warm in the colder in cold winter just reduce the 47 to 46 and so on, if you find it to warm when outside is spring 15Deg C reduce the 27 to 26 and so on. if you find to cold in either season do the opposite.</p>
<p>I made you a new black line at 57 thats in the middle of 4 and 5 and then 2 lines showing the external temp and 2 pink lines showing the flow at temp. </p>
<p> amazing thanks for your help!! Yes we use rads</p>
<p>Great, rads are good, the curve i gave you is more of a rads design. Try that and see how it goes.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58449</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58448</link>
                        <pubDate>Mon, 09 Feb 2026 20:32:56 +0000</pubDate>
                        <description><![CDATA[@cmartinbwmba No, sorry, I am asking do you have a document that looks simular to what i posted that will show you the design for your home, what i posted was an example that does not apply ...]]></description>
                        <content:encoded><![CDATA[@cmartinbwmba No, sorry, I am asking do you have a document that looks simular to what i posted that will show you the design for your home, what i posted was an example that does not apply to your home. you should have a document that came with your MCS certificate that tells you the whole design and how the company came to that design, it will be quite a few pages and one of the pages will display some of the info like the example i posted.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58448</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58447</link>
                        <pubDate>Mon, 09 Feb 2026 20:32:23 +0000</pubDate>
                        <description><![CDATA[amazing thanks for your help!! Yes we use rads
14082
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58447</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58445</link>
                        <pubDate>Mon, 09 Feb 2026 20:30:17 +0000</pubDate>
                        <description><![CDATA[So I should set that?]]></description>
                        <content:encoded><![CDATA[<p>So I should set that? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ideal-hp290-14kw-ashp-how-to-optimise/paged/6/#post-58445</guid>
Object Caching 61/69 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-05-19 08:39:42 by W3 Total Cache
