									Hot water issues with Mitsubishi puhz-hw140v - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/hot-water-issues-with-mitsubishi-puhz-hw140v/</link>
            <lastBuildDate>Tue, 18 Aug 2026 04:38:53 +0000</lastBuildDate>
                        <title>RE: Hot water issues with Mitsubishi puhz-hw140v</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/hot-water-issues-with-mitsubishi-puhz-hw140v/#post-25719</link>
                        <pubDate>Sun, 14 Jan 2024 16:32:12 +0000</pubDate>
                        <description><![CDATA[Hi, I&#039;ve been having complaints that the hot water in the afternoon is not as hot as it was.
Having avoided looking too closely at the system for the past 11 years, I think it&#039;s time to inv...]]></description>
                        <content:encoded><![CDATA[<p>Hi, I've been having complaints that the hot water in the afternoon is not as hot as it was.</p>
<p>Having avoided looking too closely at the system for the past 11 years, I think it's time to investigate the settings. </p>
<p>The ashp is a Mitsubishi puhz-hw140v with a Danfoss controller and wireless thermostat, the controller</p>
<p>is old school, not computerized.</p>
<p>I'm not quite sure why the package avoided using the timing functions on the Mitsubishi controller.</p>
<p>Since I changed the TP4000 default factory setting for condensing gas boilers, apart from the occasional</p>
<p>failure of the wireless link, all has been ok otherwise.</p>
<p>The house is rated at E, area 154m2 with total heating and hot water requirement estimate of 34,230 kwh.</p>
<p>Location is in the southern part of Bucks, not so far from High Wycombe.</p>
<p>Annual electricity consumption is around 10,000 kwh, of which I would think 60% is for heating.</p>
<p>Originally I've had some trouble with the pressure on the dhw system, and issues with the pressure vessels</p>
<p>loosing air, I had to fix these myself as the installer is no longer available and our plumbers don't want to</p>
<p>know.  The main issue I can see is that the ASHP has developed a list of around 6 degrees due to</p>
<p>settlement around the wet end.</p>
<p>I would love to hear any recommendations regarding maintenance &amp; servicing.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Giav</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/hot-water-issues-with-mitsubishi-puhz-hw140v/#post-25719</guid>
Object Caching 55/59 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-08-18 05:38:53 by W3 Total Cache
