									Help…my NIBE heat pump has faulted again! - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/</link>
            <lastBuildDate>Fri, 16 Oct 2026 05:48:32 +0000</lastBuildDate>
                        <title>RE: Help…my NIBE heat pump has faulted again!</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58699</link>
                        <pubDate>Sat, 14 Feb 2026 16:45:54 +0000</pubDate>
                        <description><![CDATA[Thanks for the pictures, they tell quite a story but nothing you can immediately do anything about.
The gague is a measuring device not something you can adjust.  The value it shows suggest...]]></description>
14135
14136
14137
14139
14138
<p>@jamespa I’ve attached a picture of a temp gauge on one of the manifolds. Not sure if that’s what you’re referring to? We only have underfloor pipes now. The heat curve was set at 0 so I’ve increased it to 1 but you did say to decrease it should I leave at 0 or put lower?</p>
<p>Thanks for the pictures, they tell quite a story but nothing you can immediately do anything about.</p>
<p>The gague is a measuring device not something you can adjust.  The value it shows suggests that adjustments would likely be beneficial.</p>
<p>Unfortunately its not going to do any good at all changing things individually.</p>
<p>You need to</p>
<p>Turn all thermostats including any heatmiser ones to max</p>
<p>Turn the mixing valve to max</p>
<p>Operate the heat pump 24*7</p>
<p>The house will very likely overheat</p>
<p>Only once all of the above are done</p>
<p>Turn the heating curve down until the house is at the right temperature, making a change not more than every 24 hrs</p>
<p>If necessary balance the loops to get the relative room temperatures right.</p>
<p>What you are trying to do is to heat the house with the heat pump at the lowest possible flow temp, which occurs when the output from the ufh just equals the loss from the house and everything is operating continuously.  Fortuitously, for most houses, this is <em>both</em> the most comfortable <em>and</em> the lowest cost, perhaps the only example I know of thermodynamics working in our favour!</p>
<p>I would not recommend doing any of this until you understand it all, and I am happy to explain it if you tell me what you dont understand.</p>
<p>If you post a picture of the manifold I can probably tell you what various bits do and which ones you may need to change.</p>
<p>Also, how many water pumps can you see in total?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58699</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58695</link>
                        <pubDate>Sat, 14 Feb 2026 16:02:09 +0000</pubDate>
                        <description><![CDATA[@jamespa I’ve attached a picture of a temp gauge on one of the manifolds. Not sure if that’s what you’re referring to? We only have underfloor pipes now. The heat curve was set at 0 so I’ve ...]]></description>
                        <content:encoded><![CDATA[14135
14136
14137
14139
14138
@jamespa I’ve attached a picture of a temp gauge on one of the manifolds. Not sure if that’s what you’re referring to? We only have underfloor pipes now. The heat curve was set at 0 so I’ve increased it to 1 but you did say to decrease it should I leave at 0 or put lower?]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Fiona</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58695</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58694</link>
                        <pubDate>Sat, 14 Feb 2026 15:34:25 +0000</pubDate>
                        <description><![CDATA[Once (with perhaps the occasional minor tweak).
But unless the company who visited came back every day for a week at least, they haven&#039;t finished it and have more likely set it up in a way ...]]></description>
<p>@jamespa how often should things like this be done as it was all set and checked by the company who came to do the report and remediation work last Feb so we assumed it was all set up correctly and not to touch if for fear of buggering it all up.</p>
<p>Once (with perhaps the occasional minor tweak).</p>
<p>But unless the company who visited came back every day for a week at least, they haven't finished it and have more likely set it up in a way to minimise the probability of call out rather than maximise comfort and minimise cost.  If your heatmiser thermostats are operational (is not set <em>at</em> <em>least</em> a couple of degrees above target) then they haven't really done it at all.</p>
<p>Everything I am suggesting is reversible so you cant really bugger it up.  </p>
<p>Unfortunately there is currently no substitute for the homeowner making these adjustments themselves because installers don't have the time and as yet there is no common automated way of doing it.  Many here including me have done it;  in the vast majority of cases it has improved things and in many it has solved long standing problems completely.</p>
<p>Let me know if you want to go ahead and if so which bis need more explanation.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58694</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58689</link>
                        <pubDate>Sat, 14 Feb 2026 13:46:16 +0000</pubDate>
                        <description><![CDATA[@jamespa how often should things like this be done as it was all set and checked by the company who came to do the report and remediation work last Feb so we assumed it was all set up correc...]]></description>
                        <content:encoded><![CDATA[@jamespa how often should things like this be done as it was all set and checked by the company who came to do the report and remediation work last Feb so we assumed it was all set up correctly and not to touch if for fear of buggering it all up.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58689</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58688</link>
                        <pubDate>Sat, 14 Feb 2026 13:35:38 +0000</pubDate>
                        <description><![CDATA[Ok it&#039;s important they are done right and together.  What don&#039;t you know how to do, I&#039;m sure we can provide a more detailed explanation.
Based on this discussion alone I presume this has no...]]></description>
<p>Thanks you. I’m not sure I know how to do some of the things you’ve suggested but will give it a try</p>
<p>Ok it's important they are done right and together.  What don't you know how to do, I'm sure we can provide a more detailed explanation.</p>
<p>Based on this discussion alone I presume this has not yet been done in which case, apart from trying to find the energy consumption in kWh, I would concentrate on making these adjustments which will take a couple of weeks to complete because you need to change the weather compensation slowly and allow things to settle for 24hrs between each change.  Once they are done we can reassess the position.</p>
<p>Please ask first about the things you don't understand in the changes I am suggesting.  There is no such thing as a silly question, we all have to start somewhere!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/3/#post-58688</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58687</link>
                        <pubDate>Sat, 14 Feb 2026 13:26:51 +0000</pubDate>
                        <description><![CDATA[Thanks you. I’m not sure I know how to do some of the things you’ve suggested but will give it a try.]]></description>
                        <content:encoded><![CDATA[<p>Thanks you. I’m not sure I know how to do some of the things you’ve suggested but will give it a try.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58687</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58686</link>
                        <pubDate>Sat, 14 Feb 2026 13:24:52 +0000</pubDate>
                        <description><![CDATA[OK.  There is some useful information in that but really we need the answers to as many of the questions that I asked as possible to avoid speculating.  Also consumption needs to be in kWh n...]]></description>
                        <content:encoded><![CDATA[<p>OK.  There is some useful information in that but really we need the answers to as many of the questions that I asked as possible to avoid speculating.  Also consumption needs to be in kWh not GBP because prices fluctuate.  If you want to try to answer the questions then please do, but as I say there is no pressure to do so.</p>
<p>Your heatmiser thermostats are almost certainly a major part of the problem, both in terms of cost and comfort.  You could do worse than turning them all to maximum so that they are effectively disabled, and then adjusting the weather compensation curve down until the house is at the right temperature, if necessary adjusting the flow valves on the loops to balance the temperatures in different rooms.  Whilst you do this (and afterwards) the heat pump should be on 24*7.     If there is a mixer on the manifolds this also needs to be disabled by turning the target temperature to maximum.</p>
<p>If you haven't already done this you are missing the most important part of getting an ashp based system to work well at both maximum comfort and minimum cost, and it's very likely you would see a significant improvement by adjusting the way the system is operated.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58686</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58684</link>
                        <pubDate>Sat, 14 Feb 2026 11:22:45 +0000</pubDate>
                        <description><![CDATA[@jamespa I will look for the plans. We had the house completely renovated in 2022. It was on TV so I can DM you the programme if you want to get a feel for the house. It’s a converted barn a...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa I will look for the plans. We had the house completely renovated in 2022. It was on TV so I can DM you the programme if you want to get a feel for the house. It’s a converted barn and stables dating back probably to 1700/1800s. We added 50mm to the walls and insulation to any roof space we could. Had the floors dug out so we could insulate as much as possible too. The barn roof is not insulated but we have put in a door to at least keep that room separate. We have heatmeiser thermostats. No radiators as all as all removed. No heating in the two upstairs rooms as was told heat rises but both rooms are cold &#x1f976; in winter!</p>
<p>We were paying £180 per month for gas and electric before all the work and we are now paying circa £260 a month if we average it out over a full year. It’s hard to know if this is normal given electricity prices have risen but it’s definitely more than we were led to believe so possibly our lack of understanding. The house is open plan so not sure if that is one of the issues. We have two manifolds as it’s a really long house!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58684</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58678</link>
                        <pubDate>Sat, 14 Feb 2026 10:18:20 +0000</pubDate>
                        <description><![CDATA[Understood.  You shouldn&#039;t be paying eye watering electricity bills to be cold.  You should be paying about the same as you would pay with gas and you should be warm other than when the temp...]]></description>
<p>As you say we need to make the best of this system I think as we wouldn’t get our money back for a long time if we switched back to gas as much as I feel like doing that!</p>
<p>it’s the eye watering electricity bills to be cold which is what stresses me out more than anything!</p>
<p>Understood.  You shouldn't be paying eye watering electricity bills to be cold.  You should be paying about the same as you would pay with gas and you should be warm other than when the temperature falls below about 4C for an extended period</p>
<p>To see if we can help can you provide any of the following information:</p>
<li>Description of your house: Layout, construction, age, level of insulation (if you have floor plans then all the better) and floor area</li>
<li>Any design information provided by your installer, or anyone subsequently however vague</li>
<li>Type of emitters, radiators, UFH, fancoil? and how many were changed when the heat pump was fitted</li>
<li>Some pictures of the heat pump, the hot water tank and any other tanks you know of as well as the area around them</li>
<li>A summary of the problems you are experiencing, being as specific as possible</li>
<li>How you currently operate it (timed, on thermostat/TRVs etc)</li>
<li>How much energy you used annually for heating the house before the heat pump was fitted</li>
<p>If you dont have all of this tell us what you do have, it may be possible to make some suggestions.</p>
<p>Dont feel obliged to reply if you dont want to, its entirely at your option.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58678</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58659</link>
                        <pubDate>Fri, 13 Feb 2026 21:34:08 +0000</pubDate>
                        <description><![CDATA[@jamespa I meant to say I attached the report from the independent company in my reply to editor above. I’ve removed their details]]></description>
                        <content:encoded><![CDATA[@jamespa I meant to say I attached the report from the independent company in my reply to editor above. I’ve removed their details]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/helpmy-nibe-has-faulted-again/paged/2/#post-58659</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-16 06:48:32 by W3 Total Cache
