									Help me keep the faith with my air source heat pump installation - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/</link>
            <lastBuildDate>Wed, 18 Nov 2026 21:32:20 +0000</lastBuildDate>
                        <title>RE: Help me keep the faith with my air source heat pump installation</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68266</link>
                        <pubDate>Wed, 11 Nov 2026 19:09:37 +0000</pubDate>
                        <description><![CDATA[Well you have a vibration generator running at some frequency followed by a bunch of filters/resonators which may absorb or amplify vibrations depending on frequency.
If your heat pump has ...]]></description>
                        <content:encoded><![CDATA[<p>Well you have a vibration generator running at some frequency followed by a bunch of filters/resonators which may absorb or amplify vibrations depending on frequency.</p>
<p>If your heat pump has variable circulator speed and it follows compressor speed, then it might be the compressor, but it might also be the circulator... and it is easy for the circulator to send pressure waves into the pipes since it's directly connected to them.</p>
<p>Here's what I did with mine (LG):</p>
<p>- With fixed circulator speed, change compressor speed by tweaking temperature setpoint: no effect on noise. The compressor is barely audible on this heat pump anyway.</p>
<p>- Change circulator speed: observe noise occurs above 75% circulator speed and gets stronger with higher circulator speed, but noise does not change pitch/frequency with circulator speed.</p>
<p>I put my hand on the stainless corrugated flex hose and found it vibrating heavily. It quieted immediately as I tightened it. Conclusion: the flex hose acted as a resonator excited either by the flow or the circulator, like a whistle powered by airflow, and it was so well tuned it did not change in pitch.</p>
<p>If you touch somewhere lightly you can feel vibration without affecting it. If you grab it tight you will add damping at that point. </p>
<p>Can you try grabbing one flex, the other, then both at the same time. At the ends, but also in the middle, since that's the spot where it flaps around the most.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68266</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68263</link>
                        <pubDate>Wed, 11 Nov 2026 17:12:35 +0000</pubDate>
                        <description><![CDATA[@bobflux yeah and im not the only one suffering with this, only seems to affect the 7kw units. to be honest i wanted this as a separate thread but normally when i post an issue with my insta...]]></description>
                        <content:encoded><![CDATA[<p>@bobflux yeah and im not the only one suffering with this, only seems to affect the 7kw units. to be honest i wanted this as a separate thread but normally when i post an issue with my install the admins lump it into the mega thread that started before i even had a heat pump installed.</p>
<p>the flexis seem to reduce the vibration by about 50% which is a rough estimate by holding the insulation either side of the flexis. ive asked some 7kw owners to check theres and some cant even feel vibration on the primaries.</p>
https://community.openenergymonitor.org/t/vaillant-arotherm-excessive-noise-from-compressor/27824/175?page=7]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AdamK</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68263</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68256</link>
                        <pubDate>Wed, 11 Nov 2026 15:35:06 +0000</pubDate>
                        <description><![CDATA[And even with that, it still hums ? Damn]]></description>
                        <content:encoded><![CDATA[<p>And even with that, it still hums ? Damn</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68256</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68255</link>
                        <pubDate>Wed, 11 Nov 2026 15:17:35 +0000</pubDate>
                        <description><![CDATA[@bobflux ive already got two primary pro felxis installed like these but straight ones:]]></description>
                        <content:encoded><![CDATA[<p>@bobflux ive already got two primary pro felxis installed like these but straight ones:</p>
<p>https://www.intatec.co.uk/products/inta-flex-primary-pro-pre-insulated-hoses/</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68255</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68252</link>
                        <pubDate>Wed, 11 Nov 2026 14:11:16 +0000</pubDate>
                        <description><![CDATA[Flex hoses isolate the main installation from vibrations generated by the heat pump :
Full stainless flex hose
Advantages: Lasts forever, doesn&#039;t care about water, corrosion, sun...]]></description>
                        <content:encoded><![CDATA[<p>ive also noticed, although he says it doesnt bother him, that i can hear and feel the hum through my sons bed pillow even at relatively low compressor speeds.</p>
<p>Flex hoses isolate the main installation from vibrations generated by the heat pump :</p>
16017
<p><a href="https://discount-plomberie.com/400-flexibles-extensibles" target="_blank" rel="noopener"><strong>Full stainless flex hose</strong></a></p>
<p>Advantages: Lasts forever, doesn't care about water, corrosion, sunlight, etc. Zero oxygen permeability. Adjustable length (within limits).</p>
<p>Drawbacks: a bit stiff to install, mine resonated like a tuning fork and produced a very loud hum. Solved by wrapping some self-adhesive rubber tape around it. Now completely silent. At the same internal diameter, a bit higher pressure drop than smooth EPDM flex due to corrugations.</p>
16018
<p><strong>Standard stainless braid over EPDM pipe flex hose</strong></p>
<p>Advantages: Cheaper, more flexible, better vibration damping.</p>
<p>Drawbacks: Non adjustable length. EPDM is oxygen permeable. Less resistant to corrosion and weather. Rusts quickly if you get galvanized steel braid by mistake instead of stainless.</p>
<p><a href="https://www.flexej.co.uk/shop/pipe-expansion-bellows/rubber-bellows/flexej-epdm-union-ends/dn32-1%c2%bc-flexej-union-epdm-rubber-bellows-length-200-mm/" target="_blank" rel="noopener"><strong>Flex bellows from video above</strong></a></p>
<p>Advantages: seems to have good vibration damping, reasonable cost.</p>
<p>Drawbacks: cast iron fittings will corrode when exposed to weather, also oxygen permeable but surface area is quite small.</p>
<p><strong>A chunk of Barrier PEX</strong></p>
<p>Advantages: free if you have leftover PEX or just plumb the whole heat pump primary with PEX, does not corrode, oxygen barrier</p>
<p>Drawbacks: sunlight will destroy it so it needs to be inside insulation, needs to be quite long (1m at least) to dampen vibration because it is quite stiff</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68252</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68251</link>
                        <pubDate>Wed, 11 Nov 2026 13:49:52 +0000</pubDate>
                        <description><![CDATA[thought id post again to see if anyone has successfully got Vaillant to come out and fix there 7kw unit. spoke to my Cousin who has designed large refrigeration setups and he said he would b...]]></description>
                        <content:encoded><![CDATA[<p>thought id post again to see if anyone has successfully got Vaillant to come out and fix there 7kw unit. spoke to my Cousin who has designed large refrigeration setups and he said he would be concerned about the vibrations cause the joints to crack, as part of my system was done by a separate plumber who soldered the 28mm runs.</p>
<p>ive also noticed, although he says it doesnt bother him, that i can hear and feel the hum through my sons bed pillow even at relatively low compressor speeds.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-68251</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-67446</link>
                        <pubDate>Sun, 11 Oct 2026 18:45:20 +0000</pubDate>
                        <description><![CDATA[just had Vaillant over to service the HP and asked about the humming noise lots of 7Kw owners are experinceing and didnt get much of a response. seems they are still denying a vibration issu...]]></description>
                        <content:encoded><![CDATA[<p>just had Vaillant over to service the HP and asked about the humming noise lots of 7Kw owners are experinceing and didnt get much of a response. seems they are still denying a vibration issue with the compressors which transfers through the house via the primaries as a 91hz hum when on HW or when ramping to meet heat demand, which if very cold outside can mean constant hum.</p>
<p>this is a sort of fix but i dont think it should be down to people to have fudges like this added to sort the issue. the compressor needs isolating from the heat exchanger.</p>
<p>https://youtu.be/m4YxHzXisGs?si=m5rJ8q_VTl-G1sE0</p>
<p>Mars do you have any suggestions?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-67446</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-64489</link>
                        <pubDate>Wed, 24 Jun 2026 08:08:53 +0000</pubDate>
                        <description><![CDATA[@agentgeorge Circumstances may change things though. I had made an investment in Ripple Energy Project 4 for some thousands of pounds; the whole scheme went belly up. I made a section 75 cla...]]></description>
                        <content:encoded><![CDATA[@agentgeorge Circumstances may change things though. I had made an investment in Ripple Energy Project 4 for some thousands of pounds; the whole scheme went belly up. I made a section 75 claim against my bank as I had paid with my credit card. I think it involved a short visit to my bank with copies of the documentation and one phone call; I received a call back the next day informing me I was being refunded (they had had a fair number of claims on this particular project!) Recharges, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-64489</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-64485</link>
                        <pubDate>Wed, 24 Jun 2026 06:07:12 +0000</pubDate>
                        <description><![CDATA[@adamk it can work. I had a chair i bought was damaged, the company selling it declined to repair it. I got a quote for repair, and asked again. Declined again. I paid to get it repaired. I ...]]></description>
                        <content:encoded><![CDATA[@adamk it can work. I had a chair i bought was damaged, the company selling it declined to repair it. I got a quote for repair, and asked again. Declined again. I paid to get it repaired. I sent that invoice and the emails to barclaycard, asking for a chargeback for only the repair cost. After a long wait i was refunded my costs. Its not a quick process and you have to get proof the company your dealing with declines to fix the issue, but a chargeback is easier than using section 75]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AgentGeorge</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/28/#post-64485</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/27/#post-64484</link>
                        <pubDate>Wed, 24 Jun 2026 00:55:20 +0000</pubDate>
                        <description><![CDATA[Just wondering rather than the fudge fix is it worth going to the credit card company and getting Vaillant to sort it.]]></description>
                        <content:encoded><![CDATA[<p>Just wondering rather than the fudge fix is it worth going to the credit card company and getting Vaillant to sort it.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/help-me-keep-the-faith/paged/27/#post-64484</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-18 21:32:20 by W3 Total Cache
