									Surge Protection Devices - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/</link>
            <lastBuildDate>Wed, 14 Oct 2026 13:15:21 +0000</lastBuildDate>
                        <title>RE: Surge Protection Devices</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/7/#post-64016</link>
                        <pubDate>Fri, 12 Jun 2026 20:13:23 +0000</pubDate>
i just mean dc in the wire]]></description>
                        <content:encoded><![CDATA[<p>@transparent </p>
<p>i just mean dc in the wire</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/7/#post-64016</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/7/#post-64005</link>
                        <pubDate>Fri, 12 Jun 2026 14:28:50 +0000</pubDate>
                        <description><![CDATA[No.
The shape of the waveform has no bearing on the decision to use an RCD.
BTW. I&#039;m still unsure why you&#039;re making &quot;DC Component&quot; into a plural.Could you give an example for me pl...]]></description>
<p>But my angle was actually on whether an RCD could be justified <em>solely</em> based on the likely DC components?</p>
<p>No.</p>
<p>The shape of the waveform has no bearing on the decision to use an RCD.</p>
<p>BTW. I'm still unsure why you're making "DC Component" into a plural.<br />Could you give an example for me please?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/7/#post-64005</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/7/#post-64004</link>
                        <pubDate>Fri, 12 Jun 2026 14:23:15 +0000</pubDate>
                        <description><![CDATA[In the case of our installation site, I see value in having the RCD fit, so we will have it. In many other cases, since I understand isolators are typically installed near the heatpump (EST ...]]></description>
<p>So would the presence of DC components require RCDs to be fit?</p>
<p>Erm... I can interpret that question in more than one way, so I'm unsure of the angle you're taking.</p>
<p>All Type-B RCDs and RCBOs will correctly trip ii there is an element of Direct Current superimposed onto the mains 50Hz waveform.<br /><em>I've deliberately changed the wording to clarify the concept.</em></p>
<p>The reasons that earth-leakage devices are fitted to circuits is usually to</p>
<li>protect the cable in the event of fire / over-heating</li>
<li>prevent death in the unlikely event of a person touching a live wire or connector</li>
<li>prevent the metal casing on an appliance becoming live due to a short-circuit fault</li>
<p>That decision is the same irrespective of whatever aberrations are present on the sine wave.</p>
<p>In the case of our installation site, I see value in having the RCD fit, so we will have it. In many other cases, since I understand isolators are typically installed near the heatpump (<a href="https://greenheattoolkit.energysavingtrust.org.uk/t/heat-pump-installers-toolkit/heat-pump-system-design/guidance-for-electricians/" target="_blank" rel="noopener">EST guidance</a>), unless the RCD would remove the need for such isolator, it seems to mostly add to costs without significant value.  </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/7/#post-64004</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-64000</link>
                        <pubDate>Fri, 12 Jun 2026 13:08:51 +0000</pubDate>
                        <description><![CDATA[Erm... I can interpret that question in more than one way, so I&#039;m unsure of the angle you&#039;re taking.
All Type-B RCDs and RCBOs will correctly trip if there is an element of Direct Current s...]]></description>
<p>All Type-B RCDs and RCBOs will correctly trip if there is an element of Direct Current superimposed onto the mains 50Hz waveform.<br /><em>I've deliberately changed the wording to clarify the concept.</em></p>
<p><strong>Harmonics:</strong></p>
<p>Are heat pumps inherently a major contributor to these losses? If that is the case, Germany and the Nordics would be having a big problem?</p>
<p>I haven't communicated with grid engineers in countries outside Britain.</p>
<p>Nor have I investigated whether their certification requires lower levels of harmonics to be emitted by heat-pumps than we allow in GB.</p>
<p>We already have an excessive amount of regulation for our electrical installations and appliances.<br />I don't think we've benefited as a result.</p>
<p>As an example, companies who install heat-pumps must be signed up to the RECC (Retail Energy Code).<br />That's a digital library which pulls together all governance issues which were previously published by other organisations.</p>
<p>But would you know if actions taken by a heat-pump installer complied with RECC requirements?</p>
<p>If your heat-pump, storage battery or solar inverter were intermittently ceasing to work, do you know where you'd look in the RECC documentation to find who's responsible?</p>
<p>How could you discover if those faults were being instigated by harmonics?</p>
<p>We've spent £millions creating The RECC, but it lacks the cross-indexing which would make it functionally useful.</p>
<p>Perhaps I'm the only one here who has attempted to consult the RECC on a real-world issue.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-64000</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63996</link>
                        <pubDate>Fri, 12 Jun 2026 12:36:32 +0000</pubDate>
                        <description><![CDATA[Yes, and doubtless, as @transparent observed, more profitable.
My installer somewhat cannily circumvented the whole issue by asking me if I was willing to get the circuit put in before he a...]]></description>
<p>Could it be that Vito's arguably excessive focus on these perceived risks is making all installations more expensive than Vaillant anticipated? </p>
<p>Yes, and doubtless, as @transparent observed, more profitable.</p>
<p>My installer somewhat cannily circumvented the whole issue by asking me if I was willing to get the circuit put in before he arrived.  So he was presented with a signed off 16A circuit (actually capable of 32A in case needed in future, but deliberately down-fused) certified by a qualified electrician to be compliant with regs, with a breaker on the end to which the installer could make a connection.  It meant I had to pay VAT on the installation of the circuit, but at sub £200 (I did first fix myself) that really didn't matter a whole lot.  My 'second choice' installer was proposing to take the exact same approach. </p>
<p>I do realise that this is an unusual route which few would take, helped by the fact that I have worked with the electrician in question for a decade and he is one of those relatively rare tradesmen that you can just trust to do the right, but not excessive, thing.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63996</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63989</link>
                        <pubDate>Fri, 12 Jun 2026 12:05:07 +0000</pubDate>
                        <description><![CDATA[So would the presence of DC components require RCDs to be fit? Vaillant does not seem to be different from other heat pump manufacturers: they state that local regulations would determine su...]]></description>
<p>And not knowing for sure if the DC leakage is solved,</p>
<p>The issue isn't DC <span style="text-decoration: underline">leakage</span>.</p>
<p>Type-B RCDs and RCBOs will trip correctly despite the waveform having a DC component present.</p>
<p>So would the presence of DC components require RCDs to be fit? Vaillant does not seem to be different from other heat pump manufacturers: they state that local regulations would determine such need.   </p>
15250
<p>I've created the above timeline from spreadsheet date sent to me by a DNO.</p>
<p>It shows the absolute deviation of voltage imbalances which are being passed through local substations and on to the higher voltages of the Distribution Grid (11kV and above).</p>
<p>Whilst <span style="color: #333333"><em>losses due to phase imbalances</em></span> are substantially occurring only at the local substation level, harmonics pass right through every transformer on the grid. This is what causes the <span style="text-decoration: underline">audible</span> hum when you're in the vicinity of larger transformers. That's energy being lost.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63989</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63986</link>
                        <pubDate>Fri, 12 Jun 2026 11:35:33 +0000</pubDate>
                        <description><![CDATA[Vito Energy has information on their website about this Hager/Vaillant collaboration. Hager still shows some info in their website. 
Could it be that Vito&#039;s arguably excessive focus on thes...]]></description>
<p>I reiterate that, whilst <span>I agree with your final sentence, n</span><span>either my Vaillant documentation, nor the document </span><a title="trebor12345" href="https://renewableheatinghub.co.uk/participant/trebor12345/">@trebor12345</a><span> produced, appears to </span><em>require</em><span> an RCD at all.  So where <em>exactly</em> in the Vaillant documentation do you believe it say this?  Just because some potentially self motivated (as you rightly point out) installer says something is the case does not mean that it <em>is</em> the case!</span></p>
<p>Vito Energy has information on their website about this Hager/Vaillant collaboration. Hager still shows some info in their website. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63986</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63973</link>
                        <pubDate>Thu, 11 Jun 2026 21:09:06 +0000</pubDate>
                        <description><![CDATA[@transparent  Thanks for confirming this.]]></description>
                        <content:encoded><![CDATA[<p>@transparent  Thanks for confirming this.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63973</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63972</link>
                        <pubDate>Thu, 11 Jun 2026 21:01:06 +0000</pubDate>
                        <description><![CDATA[I don&#039;t believe it&#039;s in the Vaillant documentation.
I can see no functional advantage in a heat-pump being supplied via an RCD.
It&#039;s purely a protective device, and won&#039;t operate at all un...]]></description>
                        <content:encoded><![CDATA[<p>I don't believe it's in the Vaillant documentation.</p>
<p>I can see no functional advantage in a heat-pump being supplied via an RCD.</p>
<p>It's purely a protective device, and won't operate at all unless there is a certain type of fault.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63972</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63969</link>
                        <pubDate>Thu, 11 Jun 2026 20:47:45 +0000</pubDate>
                        <description><![CDATA[I am not missing that, I assure you!
I am trying (and failing) to find in Vailant&#039;s documentation, the underpinning for your statement:
I reiterate that, whilst I agree with your...]]></description>
<p>What am I missing?</p>
<p>The additional profit being made the installers. </p>
<p>I am not missing that, I assure you!</p>
<p>I am trying (and failing) to find in Vailant's documentation, the underpinning for your statement:</p>
<p>It seems odd to me that Vaillant have introduced an AC to DC power supply into their ASHPs which is imposing both errors onto the mains incomer to sufficient extent that the company has teamed up with Hager to recommend a particular protection trip.</p>
<p>...</p>
<p>Consumers shouldn't be asked to spend £600 having an expensive RCD fitted just because the heat-pump power supply has design deficiencies.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/heat-pump-fuse-type/paged/6/#post-63969</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-14 14:15:21 by W3 Total Cache
