									Good heat loss calculator for ASHP with UFH? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/</link>
            <lastBuildDate>Thu, 21 May 2026 14:53:18 +0000</lastBuildDate>
                        <title>RE: Good heat loss calculator for ASHP with UFH?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33259</link>
                        <pubDate>Thu, 15 Aug 2024 18:17:48 +0000</pubDate>
                        <description><![CDATA[There is a lot said about perfect sizing of heat pump to heat loss, but if you run open loop, there is flexibility. Our house heat loss at -3 is about 3kW at 7 degs about 1 to 1.5kW, but we ...]]></description>
                        <content:encoded><![CDATA[<p>There is a lot said about perfect sizing of heat pump to heat loss, but if you run open loop, there is flexibility. Our house heat loss at -3 is about 3kW at 7 degs about 1 to 1.5kW, but we have 6kW heat pump. It cycles, at min load and I get about 10 to 12 mins on and off an hour. So doesn't short cycle. We are currently doing cooling it has been a mostly wet day so almost no load required and the heat pump compressor has started 8 times in 18 hrs.</p>
<p>Opposite to what a lot will say - I think you are better to be slightly big on heat demand, your radiators end up bigger, so you can run lower flow temperature, your heat pump has some flexibility, if it gets really cold outside. Get it the other way round, you end up running higher temps and the immersion on if it gets really cold.</p>
<p>No zones (well one) is the best for flexibility, and oversized, you may get a very slight CoP hit when it's mild, but not much, when it's cold it runs fine.</p>
<p>So I wouldn't fret to much, 5kW or 4kW you really should be running a 6kW ASHP. Remember you still need 2 to 3 hrs for DHW each day mid winter </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33259</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33254</link>
                        <pubDate>Thu, 15 Aug 2024 17:50:13 +0000</pubDate>
                        <description><![CDATA[@johnmo Thanks, yes I have that cheat sheet and was a bit surprised it was higher than expected. Maybe I should start the Heatpunk project again. Still awaiting Octopus report promised this ...]]></description>
                        <content:encoded><![CDATA[@johnmo Thanks, yes I have that cheat sheet and was a bit surprised it was higher than expected. Maybe I should start the Heatpunk project again. Still awaiting Octopus report promised this week but we will see.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Jancold</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33254</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33252</link>
                        <pubDate>Thu, 15 Aug 2024 17:01:38 +0000</pubDate>
                        <description><![CDATA[Seems high to me
Take a look here]]></description>
<p>@johnmo I revisited the Heatpunk project which I did back in May and put in the data for the floor and ceilings which I had not done and revised the heat loss up to 5070 or 70W/m2.  Does that seem reasonable?</p>
<p>Seems high to me</p>
<p>Take a look here</p>
<p>https://www.heatgeek.com/how-to-size-my-heat-pump-or-boiler-heat-loss-cheat-sheet/</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33252</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33248</link>
                        <pubDate>Thu, 15 Aug 2024 15:46:22 +0000</pubDate>
                        <description><![CDATA[@johnmo I revisited the Heatpunk project which I did back in May and put in the data for the floor and ceilings which I had not done and revised the heat loss up to 5070 or 70W/m2.  Does tha...]]></description>
                        <content:encoded><![CDATA[@johnmo I revisited the Heatpunk project which I did back in May and put in the data for the floor and ceilings which I had not done and revised the heat loss up to 5070 or 70W/m2.  Does that seem reasonable?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33248</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33144</link>
                        <pubDate>Wed, 14 Aug 2024 08:12:19 +0000</pubDate>
                        <description><![CDATA[@johnmo Excellent. I&#039;m going to try and re-instate my Part P electrical qualification which lapsed when I retired.]]></description>
                        <content:encoded><![CDATA[@johnmo Excellent. I'm going to try and re-instate my Part P electrical qualification which lapsed when I retired.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>ash2020</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/3/#post-33144</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33141</link>
                        <pubDate>Wed, 14 Aug 2024 07:18:53 +0000</pubDate>
                        <description><![CDATA[I did the UVC course at a local college, so now qualified.]]></description>
<p>@johnmo You couldn't do an unvented cylinder yourself though.</p>
<p>I did the UVC course at a local college, so now qualified.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33141</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33140</link>
                        <pubDate>Tue, 13 Aug 2024 22:54:56 +0000</pubDate>
                        <description><![CDATA[@johnmo You couldn&#039;t do an unvented cylinder yourself though.]]></description>
                        <content:encoded><![CDATA[@johnmo You couldn't do an unvented cylinder yourself though.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33140</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33136</link>
                        <pubDate>Tue, 13 Aug 2024 20:44:53 +0000</pubDate>
                        <description><![CDATA[Except the floor, sounds good, did the heat punk calc take all this into account?]]></description>
                        <content:encoded><![CDATA[Except the floor, sounds good, did the heat punk calc take all this into account?<br />
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33136</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33133</link>
                        <pubDate>Tue, 13 Aug 2024 20:00:31 +0000</pubDate>
                        <description><![CDATA[@johnmo We have cavity insulation double glazing and loft is mostly well insulated, all except a walkway down the middle. Also the chimney stacks have been removed. Floating floors with no i...]]></description>
                        <content:encoded><![CDATA[@johnmo We have cavity insulation double glazing and loft is mostly well insulated, all except a walkway down the middle. Also the chimney stacks have been removed. Floating floors with no insulation.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33133</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33132</link>
                        <pubDate>Tue, 13 Aug 2024 19:48:03 +0000</pubDate>
                        <description><![CDATA[Hope you plan for plenty of insulation under the pipes. Otherwise the downward heat losses can be pretty big. General recommendation is 150mm PIR. 
Have you considered fan coils? More expen...]]></description>
<p>We are going to install underfloor heating</p>
<p>Hope you plan for plenty of insulation under the pipes. Otherwise the downward heat losses can be pretty big. General recommendation is 150mm PIR. </p>
<p>Have you considered fan coils? More expensive than radiators, less faff than doing UFH correctly. Can do cooling in summer if you want it.</p>
<p>stupid MCS thing</p>
<p>I just didn't bother, we are a new build originally with gas boiler. As soon as house was signed off, I installed the ASHP. Cylinder was £1000 (210L slim line), 6kW Maxa heat pump £1300 from ebay, around £500 for stuff. So around £3k all in. When I bought the ASHP, Viessmann were selling a rebadged Maxa unit for around £4k.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/good-calculator-for-ashp-with-ufh/paged/2/#post-33132</guid>
Object Caching 67/74 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-05-21 15:53:18 by W3 Total Cache
