									Getting the best out of a heat pump - is Homely a possible answer? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/</link>
            <lastBuildDate>Tue, 21 Apr 2026 16:11:50 +0000</lastBuildDate>
                        <title>RE: Getting the best out of a heat pump - is Homely a possible answer?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/35/#post-54096</link>
                        <pubDate>Sat, 06 Dec 2025 16:26:05 +0000</pubDate>
                        <description><![CDATA[Oh and it was installed by Stevie Wonder!]]></description>
                        <content:encoded><![CDATA[<p>Oh and it was installed by Stevie Wonder!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Grantmethestrength</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/35/#post-54096</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54094</link>
                        <pubDate>Sat, 06 Dec 2025 16:22:44 +0000</pubDate>
                        <description><![CDATA[@vanq my set up which is a pretty standard kit for the Aerona3 R32 has a timer for the immersion (top most box) a timer for DHW (second box down) and the heat pump controller (third box down...]]></description>
                        <content:encoded><![CDATA[@vanq my set up which is a pretty standard kit for the Aerona3 R32 has a timer for the immersion (top most box) a timer for DHW (second box down) and the heat pump controller (third box down) and the EPH remote thermostat controller (bottom box). Because why have one controller when you can have four? Cheers Grant!
12930]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54094</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54081</link>
                        <pubDate>Sat, 06 Dec 2025 10:19:09 +0000</pubDate>
                        <description><![CDATA[@grantmethestrength thanks, yes I did that. But couldn’t get it so I could use the normal buttons (heating schedule, dhw etc) they all still then had an annoying 3 beeps. What did you use?]]></description>
                        <content:encoded><![CDATA[@grantmethestrength thanks, yes I did that. But couldn’t get it so I could use the normal buttons (heating schedule, dhw etc) they all still then had an annoying 3 beeps. What did you use?]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Vanq</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54081</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54080</link>
                        <pubDate>Sat, 06 Dec 2025 09:38:15 +0000</pubDate>
If it is this controller press the plus and minus buttons and the snowflake button together at the same time for a few seconds this should get you into the installer menu.]]></description>
12896
If it is this controller press the plus and minus buttons and the snowflake button together at the same time for a few seconds this should get you into the installer menu.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54080</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54075</link>
                        <pubDate>Sat, 06 Dec 2025 09:04:35 +0000</pubDate>
                        <description><![CDATA[yes to both, probably.  External controls for ashps (and many modern boilers) are largely superfluous and frequently counterproductive.
The possible problem is if ufh and radiators are set ...]]></description>
<p>Would I essentially be able to do the same for the Heatmeister as a first step, set all to max then control on the grant?  Does that also work for hot water</p>
<p>yes to both, probably.  External controls for ashps (and many modern boilers) are largely superfluous and frequently counterproductive.</p>
<p>The possible problem is if ufh and radiators are set up to run at different temperatures which they might be.  You need to check this and might need to maintain the mixing function of the manifold.  Many heat pumps can control this as well don't know if the Grant can or not.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54075</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54044</link>
                        <pubDate>Fri, 05 Dec 2025 15:33:47 +0000</pubDate>
                        <description><![CDATA[As a followup, I have the Aerona Remote controller, and don&#039;t seem to be able to edit and control the device from there.  Each time I go to press any of the main buttons just get 3 beeps.  C...]]></description>
                        <content:encoded><![CDATA[<p>As a followup, I have the Aerona Remote controller, and don't seem to be able to edit and control the device from there.  Each time I go to press any of the main buttons just get 3 beeps.  Can get into installer mode but can't see any parameters in either the Chofu/Grant manuals to turn this off.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54044</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54039</link>
                        <pubDate>Fri, 05 Dec 2025 14:15:11 +0000</pubDate>
Here’s the pictures  
doesnt look to have a normal value to control the heating downstairs only for hot water and upstairs to me but does seem to have a pump for both 
there ...]]></description>
                        <content:encoded><![CDATA[<p>@transparent</p>
<p>Here’s the pictures  </p>
<p>doesnt look to have a normal value to control the heating downstairs only for hot water and upstairs to me but does seem to have a pump for both </p>
<p>there are 2 separate manifolds for the UFH</p>
12917
12918
12919
12923
12921
12920
12922
12924
12925]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54039</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54038</link>
                        <pubDate>Fri, 05 Dec 2025 14:08:23 +0000</pubDate>
                        <description><![CDATA[@jamespa Hey, apologies for the delay, new job role so not been at home much.
Have you got a buffer/low loss header?I dont think so no
Where is your Grant controller/temperature sensor l...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa Hey, apologies for the delay, new job role so not been at home much.</p>
<li>Have you got a buffer/low loss header?<br />I dont think so no</li>
<li>Where is your Grant controller/temperature sensor located?<br />Controller is internal, it has an outside temperature on the display</li>
<li>Does UFH cover the whole house or have you got radiators in part?<br />UFH is full downstairs - controlled by the Heatmeister.  Then the nest controls the upstairs radiators and the hot water.</li>
<p>Would I essentially be able to do the same for the Heatmeister as a first step, set all to max then control on the grant?  Does that also work for hot water?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-54038</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-53201</link>
                        <pubDate>Mon, 24 Nov 2025 13:10:57 +0000</pubDate>
                        <description><![CDATA[Absolutely.  Dont use it!
Seriously Nest, like other smart thermostats (other than Homeley, Havenwise, Adia), are wholly unsuitable for heat pump control.  You should be able effectively to...]]></description>
<p>But wait an hour or two and someone else will jump in with some Nest insights.</p>
<p>Absolutely.  Dont use it!</p>
<p>Seriously Nest, like other smart thermostats (other than Homeley, Havenwise, Adia), are wholly unsuitable for heat pump control.  You should be able effectively to disable it by turning the target temperature up to max and setting it to be on 24x7, so that its constantly calling for heat.  Then  use your heat pump native controller to adjust WC so you are comfortable.</p>
<p>Once thats done settings can be finessed if necessary (eg by using zone valves/TRVs as limiters in case of solar gain) but until the basics are right then any temperature sensors/thermostats should all be set to max so the heat pump can do its thing without interferance.</p>
<li>Have you got a buffer/low loss header?</li>
<li>Where is your Grant controller/temperature sensor located?</li>
<li>Does UFH cover the whole house or have you got radiators in part?</li>
</ul>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-53201</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-53189</link>
                        <pubDate>Mon, 24 Nov 2025 10:22:58 +0000</pubDate>
                        <description><![CDATA[Well I can get all my UFH flow monitors to show &quot;all at max flow&quot; simply by having the circulating pump on full!
But that&#039;s not efficient of course.The shorter loops would be returning wate...]]></description>
<p>balance those knobs so the numbers in the clear part all match? currently they look all full/red</p>
<p>Well I can get all my UFH flow monitors to show "all at max flow" simply by having the circulating pump on full!</p>
<p>But that's not efficient of course.<br />The shorter loops would be returning water which still retains lots of energy.</p>
<p>In your case there's also the issue of the upstairs radiators.<br />Somehow they need to be balanced with whatever the ground-floor manifold is taking.</p>
<p>Have a look at <a href="https://renewableheatinghub.co.uk/the-importance-of-radiator-balancing-for-efficient-heating-introducing-the-flow-regulating-valve/" target="_blank" rel="noopener">this article about a flow-regulating valve for radiators</a>.<br />It's similar to those on your UFH manifold but allows you to see the water speed for each radiator.<br />If you read to the bottom of the text, you'll find a discount for Forum Members. &#x1f60a; </p>
12714
<p>Q. Then how do it make sure the valve (not sure where this is or if there is one for the downstairs system) and the pump are "open", as assume they're also in that heating control box.</p>
<p>You've got manual butterfly valves at the end of the UFH manifold, which don't have to full open. Mine aren't on my upstairs manifold.</p>
<p>But I assume you're referring to a motorised valve and a speed control for the pump.</p>
<p>The only motorised valve I'd expect to find is the 3-port (2-way) unit which shuts off the space-hating circuit when the DHW cylinder calls for heat.<br />That should continue to operate as normal because the control system is dictated by a temperature sensor on that cylinder.</p>
<p>If you think we need to know more about "the" pump then post a photo.<br />But do you actually have one?<br />The entire system might just be using the pump inbuilt to the ASHP.</p>
<p>Q. How do I then set the actual temperature? Assume its controlling the flow temp at source and some trial and error until thats correct?</p>
<p>You should have an Outside Air Temperature (OAT) sensor, which connects back to the ASHP control unit.</p>
<p>And there's a system called Weather Compensation (WC) which allows the installer to select an appropriate WC curve for your house.</p>
<p>Those two mechanisms 'instruct' the heat-pump how to choose the required flow temperature and speed.<br />Setting up the WC curve is one of most often discussion points on this forum.<br />Type <em>WC curve</em> into the search box (spyglass at top right of this screen) and you'll find scores of results!</p>
12718
<p>Q. That'd count for the Neo's but then obviously there is the Nest to consider.</p>
<p>That's beyond my knowledge-set I'm afraid.</p>
<p>But wait an hour or two and someone else will jump in with some Nest insights.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/getting-the-best-out-of-a-heat-pump-is-homely-a-possible-answer/paged/34/#post-53189</guid>
