									Vaillant Tech Support Flagged Low DT: UFH Return Cold, Suspected Zero Flow - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/</link>
            <lastBuildDate>Wed, 18 Nov 2026 23:55:44 +0000</lastBuildDate>
                        <title>RE: Vaillant Tech Support Flagged Low DT: UFH Return Cold, Suspected Zero Flow</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/paged/2/#post-58404</link>
                        <pubDate>Mon, 09 Feb 2026 14:21:28 +0000</pubDate>
                        <description><![CDATA[It will consume more power in the water pump but it is more likely to increase COP than decrease it, because it means that you need a slightly lower flow temperature for any given emitter ou...]]></description>
<p>least, pumping faster than required will consume more power and presumably reduce the COP.</p>
<p>As I get to know my 3.5kW Aerotherm instal I have had a number of calls with Vaillant tech support.  A recent call turned up info that the flow and return DT was about 2C.</p>
<p>It will consume more power in the water pump but it is more likely to increase COP than decrease it, because it means that you need a slightly lower flow temperature for any given emitter output.  Thus there is a tradeoff.  The folks on openergymonitor reckoned that the optimum for the 3.5kW scenario <em>they</em> modelled was about 2C DT as it happens, but the effect is small as long as you dont go too far above DT5.   DT5 is not sacrosanct, its just a design assumption used to size things at design time, actual operation will always differ!  Significantly higher DT is certainly bad news, lower DT (provided you are getting sufficient output) not.  Max flow rate is also not a problem unless there is excessive noise.</p>
<p>With radiators (which I dont think you have), there is an argument for <em>not</em> modulating the pump speed as the resulting output curve combined with the non linear response of the radiators to DT (rad to room) more closely follows the 'ideal'.</p>
<p>Even though I have a Vaillant I have been unable to determine for certain whether it does bother modulating the water pump or not. </p>
<p>In summary unless any of this is actually causing a problem I wouldn't worry about it!  The Vaillant heat pump is pretty good at sorting itself out so long as there is <em>sufficient</em> flow rate.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/paged/2/#post-58404</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/paged/2/#post-58398</link>
                        <pubDate>Mon, 09 Feb 2026 13:11:14 +0000</pubDate>
                        <description><![CDATA[@bornagain Thanks for the comments and comparison with your own system.  My understanding is that the flow rate should automatically adjust to provide a DT of 5.  Like you, my system is runn...]]></description>
                        <content:encoded><![CDATA[@bornagain Thanks for the comments and comparison with your own system.  My understanding is that the flow rate should automatically adjust to provide a DT of 5.  Like you, my system is running ok and perfectly warm.  The reaction I got from the technical advisor suggested all is not well with my system.  I have no comparisons (other than yours) on which to draw a conclusion.  At least, pumping faster than required will consume more power and presumably reduce the COP.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>DavidB</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/paged/2/#post-58398</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58397</link>
                        <pubDate>Mon, 09 Feb 2026 12:48:03 +0000</pubDate>
                        <description><![CDATA[We have a 5kw Aerotherm feeding an existing UFH manifold plus one radiator.
Our flow rate is also 860 lph and the system is performing beautifully with no cycling during the seven hours a d...]]></description>
                        <content:encoded><![CDATA[<p>We have a 5kw Aerotherm feeding an existing UFH manifold plus one radiator.<br /><br /></p>
<p>Our flow rate is also 860 lph and the system is performing beautifully with no cycling during the seven hours a day that it runs.</p>
<p><br />As an aside, with this flow rate, the heat output in kw is the same number as the dT, so a dT of 2c happens to be 2kw.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>bornagain</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58397</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58393</link>
                        <pubDate>Mon, 09 Feb 2026 12:25:37 +0000</pubDate>
                        <description><![CDATA[Hi everyone,  As I get to know my 3.5kW Aerotherm instal I have had a number of calls with Vaillant tech support.  A recent call turned up info that the flow and return DT was about 2C.  On ...]]></description>
                        <content:encoded><![CDATA[<p>Hi everyone,  As I get to know my 3.5kW Aerotherm instal I have had a number of calls with Vaillant tech support.  A recent call turned up info that the flow and return DT was about 2C.  On the back of that I discovered the manifold valves for the UFH were not opening.  I now have a temporary fix on that (thanks Mars) and called Tech support to check if, with the UFH pipes connected, the DT had changed.  Apparently DT is just under 2.  However the tech individual said the flow rate is sitting at 859l/hr - apparently pretty much the maximum.  I have called my installer and hope to get a call back soon but recognise we are in the middle of the heat season so I am not holding my breath.</p>
<p>Can anyone suggest what may be going astray, the impact on system performance at such rates and any suggestion as to anything I can do about it?  </p>
<p>I joined this community a week ago - thanks to everyone for their comments.  My understanding is going up a steep learning curve and I am finding out things which are almost certainly having a negative impact on system efficiency.  This is a great community and really appreciate the assistance.  David </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58393</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58211</link>
                        <pubDate>Fri, 06 Feb 2026 21:03:56 +0000</pubDate>
                        <description><![CDATA[@editor thanks for the tips which I will try before calling my installer on Monday. Again much appreciated.]]></description>
                        <content:encoded><![CDATA[@editor thanks for the tips which I will try before calling my installer on Monday. Again much appreciated.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58211</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58207</link>
                        <pubDate>Fri, 06 Feb 2026 20:38:42 +0000</pubDate>
                        <description><![CDATA[@davidb, if the flow has drifted back to near-closed and the adjuster now isn’t doing anything (bearing in mind that I&#039;m not a plumber or heating engineer) that, for me, points to a failed o...]]></description>
                        <content:encoded><![CDATA[@davidb, if the flow has drifted back to near-closed and the adjuster now isn’t doing anything (bearing in mind that I'm not a plumber or heating engineer) that, for me, points to a failed or stuck flow regulator on the manifold rather than anything the heat pump or controls are doing. With UFH, a trickle like that will happily fool you into thinking things are running normally, while in reality the slab is being starved of energy. Under those conditions, not hitting set temperature is exactly what you’d expect.
<p class="p1">I think that the slow return temperature rise you saw also fits. Some absorption into the slab is normal on start-up, but if the flow control is intermittently or permanently closed, you’ll never get sustained heat transfer... you’re effectively trying to heat a concrete mass with a dribble of water.</p>
<p class="p1">Before you resign yourself to waiting for ferries and installers, there are a couple of low-tech things worth trying. Gently tapping the flow meter body and valve stem can sometimes free a stuck regulator.</p>
<p class="p1">Fully winding the adjuster open and closed a few times can also help if it’s jammed with debris or scale. That solved a similar issue for us a couple of years ago.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58207</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58200</link>
                        <pubDate>Fri, 06 Feb 2026 19:16:06 +0000</pubDate>
                        <description><![CDATA[Update - I have been checking the UFH return manifold, waiting on a rise in temperature.  Response was fairly slow so I figured the heat was being absorbed by the slab.  However I then reali...]]></description>
                        <content:encoded><![CDATA[<p>Update - I have been checking the UFH return manifold, waiting on a rise in temperature.  Response was fairly slow so I figured the heat was being absorbed by the slab.  However I then realised the flow had returned to nearly closed.  Strange, I had it set clearly at just over 1.  I readjusted the flow control only to find it wasn’t operating, regardless of how much I rotate the adjuster.  It looks like I have a hardware failure.  I have no idea what that will take to fix as I am on a Scottish island and my installer on the mainland.  Add to that we have had no ferry service for 2 days due to an easterly gale!  If there are any tricks I can perform to get the flow going, please take to your keyboard.  Thanks to all for their comments.  BW. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58200</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58189</link>
                        <pubDate>Fri, 06 Feb 2026 17:18:36 +0000</pubDate>
                        <description><![CDATA[@steelbadger yes, HP running “normally” and, if you have seen some of my other thread, I have no stove burning.  I have the system in active mode - so control via WC curve only.  With only a...]]></description>
                        <content:encoded><![CDATA[@steelbadger yes, HP running “normally” and, if you have seen some of my other thread, I have no stove burning.  I have the system in active mode - so control via WC curve only.  With only a trickle through the UFH pipes, I am not surprised I haven’t been reaching set temperature.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58189</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58188</link>
                        <pubDate>Fri, 06 Feb 2026 17:18:06 +0000</pubDate>
                        <description><![CDATA[@davidb there isn’t really a universal &#039;rule of thumb&#039; number for UFH flow rates, which is why I was careful not to present 1 l/min as the answer. In your case it was more of a safe, visible...]]></description>
                        <content:encoded><![CDATA[<p class="p1">@davidb there isn’t really a universal 'rule of thumb' number for UFH flow rates, which is why I was careful not to present 1 l/min as <i>the</i> answer. In your case it was more of a safe, visible starting point than anything else.</p>
<p class="p1">UFH flow rates are ultimately a function of heat output, pipe spacing, loop length and design temperature difference, so in a perfect world you’d calculate them loop by loop. But when you’re troubleshooting a system that’s clearly doing almost nothing, the immediate goal isn’t optimisation, it’s simply to get meaningful circulation and see how the system reacts. Going from effectively zero flow to 1 l/min is a big enough step that you’ll feel it quickly in pipe temperatures and see it reflected in system behaviour, without suddenly dumping a load of flow into the circuit and destabilising everything else.</p>
<p class="p1">As you’ve already seen, with the valves barely cracked open the flow pipe warming a short distance from the manifold makes total sense... there just wasn’t enough movement to carry heat back. At 1 l/min you’re now firmly into 'this should actually do something' territory, which gives you useful feedback.</p>
<p class="p1">There’s also a practical reason for not jumping straight to higher numbers. If your UFH is on the same primary circuit as radiators, or shares a buffer/LLH, opening the manifold too far can absolutely throw balancing out elsewhere. UFH likes low and slow by nature, so sneaking up on the flow rather than swinging it wide open is usually the least disruptive way to go.</p>
<p class="p1">On @steelbadger’s point, he’s right to flag the bigger picture. Near-zero flow at the manifold will lead to low system dT because the heat pump is effectively circulating against itself via whatever path offers the least resistance, whether that’s a buffer, bypass or another open circuit. That doesn’t automatically mean anything exotic is broken, but it does mean the UFH loop wasn’t participating in heat delivery at all.</p>
<p class="p1">Given you’re running open loop, no actuators closing things down and the pump appears to be running, the simplest explanation was also the right one here: the flow limiters were basically shut. The key now is to see how the system behaves with some actual circulation... how the UFH responds, whether the return starts to lift and what happens to overall dT and COP once the heat has somewhere useful to go.</p>
<p class="p1">I’d live with 1 l/min for a bit, observe, then adjust incrementally. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58188</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58184</link>
                        <pubDate>Fri, 06 Feb 2026 17:00:12 +0000</pubDate>
                        <description><![CDATA[@editor so simple, thanks.  Reevaluating what I was seeing, the valve was only just cracked open. It meant the flow pipe was warm a meter away from the manifold.  I have set both to your sug...]]></description>
                        <content:encoded><![CDATA[<p>@editor so simple, thanks.  Reevaluating what I was seeing, the valve was only just cracked open. It meant the flow pipe was warm a meter away from the manifold.  I have set both to your suggested 1l/m but curious to know why that figure.  Is that a simple industry rule of thumb?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/flow-meter/#post-58184</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-18 23:55:44 by W3 Total Cache
