									Fitting heat pump plumbing and pipes in advance? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/</link>
            <lastBuildDate>Fri, 15 May 2026 01:33:39 +0000</lastBuildDate>
                        <title>RE: Fitting heat pump plumbing and pipes in advance?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-60707</link>
                        <pubDate>Wed, 18 Mar 2026 11:01:30 +0000</pubDate>
                        <description><![CDATA[@transparent i did alot
of research before opting for a Heat Pump, heat calc surveys, where to site HP, pipe routings, where to site DHW, and how to get heat round the house.
I opted to re...]]></description>
                        <content:encoded><![CDATA[<p>@transparent i did alot</p>
<p>of research before opting for a Heat Pump, heat calc surveys, where to site HP, pipe routings, where to site DHW, and how to get heat round the house.</p>
<p>I opted to remove the ceiling as I didnt want to disturb upstairs rooms get the floors up, to allow changes to Flow Return pipes when old boiler removed, and upgrading feed pipes to each radiator upstairs to 15mm copper.</p>
<p>Warning for future readers of this post:</p>
<p>PEX is useful but be aware the internal diameter is smaller than same size copper pipe for the elbows, T’s etc as you have to fit those inserts to support the pipe which reduce ID so 22mm PEX has equivalent ID to 15mm CU, to maintain same Flow Rate.</p>
<p>If you cant get the flow rate high enough, you will need bigger emitters!</p>
<p>After my system was commissioned, I had issues with slow heat up times in bedrooms; Octopus suggested bigger radiators. I argued for a higher flow rate and had all the 10mm microbore removed and replaced with 15mm CU.</p>
<p>We split the cost 50/50 as it wasnt their preferred solution so wouldn’t absorb the whole cost</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AgentGeorge</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-60707</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-60544</link>
                        <pubDate>Fri, 13 Mar 2026 09:38:45 +0000</pubDate>
                        <description><![CDATA[Great tips, thanks. The PEX/Al/PEX option sounds much more practical than trying to maneuver rigid copper through a 3 m run, and the string idea is a simple but effective way to avoid fishin...]]></description>
                        <content:encoded><![CDATA[<p><span>Great tips, thanks. The PEX/Al/PEX option sounds much more practical than trying to maneuver rigid copper through a 3 m run, and the string idea is a simple but effective way to avoid fishing rods through finished ceilings later on. Having dealt with similar retrofitting challenges on heat pump installations before (</span><a href="https://www.mesa-plumbing.com/heating/heat-pump-services/" target="_blank" rel="noopener noreferrer"><span>https://www.mesa-plumbing.com/heating/heat-pump-services/</span></a><span>), I've seen how professionals approach forward planning like this, and it definitely saves a lot of headaches down the line.</span></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Jonatan</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-60544</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38638</link>
                        <pubDate>Fri, 13 Dec 2024 11:42:54 +0000</pubDate>
                        <description><![CDATA[That&#039;s not a particularly long run.
There are other pipe options than copper which provide better choices for retro-fitting below floors and above ceilings.Pushing 3m of copper pipe beneath...]]></description>
<p>Could I leave some pipes in that space, ready to be used in a year or two? Or some conduit to make it easier to feed pipes through? Or will an installer be able to push pipes in from the end if I can mark the right spot? It's about a 3 meter run, parallel to the joists.</p>
<p>That's not a particularly long run.</p>
<p>There are other pipe options than copper which provide better choices for retro-fitting below floors and above ceilings.<br />Pushing 3m of copper pipe beneath a floor means that you must have 3m of 'space' from which to push it.</p>
<p><span style="color: #808000"><strong>PEX</strong></span>/<span style="color: #333399"><strong>Al</strong></span>/<span style="color: #808000"><strong>PEX</strong></span> is more commonly used for underfloor heating (UFH),<br />but is lightweight and can be pushed through a void easily.</p>
<p>It's semi-flexible, and lengths greater than 3m are supplied as a coil.</p>
9398
<p><span style="color: #808000"><strong>PEX</strong></span> means Cross-linked polyethylene, and the <span style="color: #333399"><strong>Al</strong></span> is for Aluminium between the two PEX layers.</p>
<p><a href="https://www.bes.co.uk/riifo-multilayer-pex-al-pex-pipe-32-x-3-0mm-x-3m-27361/" target="_blank" rel="noopener">Plumbing and heating outlets like BES</a> offer a range of lengths at different bores, and fittings to convert back to copper pipe or brass-threaded couplings.<br />32mm pipe with a 3mm wall thickness each side gives you an internal bore of 26mm.</p>
<p><span style="color: #808000"><strong>PEX</strong></span>/<span style="color: #333399"><strong>Al</strong></span>/<span style="color: #808000"><strong>PEX </strong></span>can be bent by hand, and the aluminium ensures that it stays in that shape.<br />With ingenuity you can guide it around corners!</p>
<p>Remember to slide on a length of pipe insulation before you put fittings onto it.</p>
<p>When fixing floors and walls in place I always leave lengths of polypropylene string to act as pull-throughs for cable at a later date.</p>
<p>Tie each end around an old nail to prevent it accidentally being pulled into a hole...<br />... and label the ends with PVC-tape.</p>
9399
<p>Colours help to differentiate strings emerging at the same spot.</p>
<p><a href="https://www.amazon.co.uk/Polypropylene-Household-Decorative-Wear-Resistant-Agricultural/dp/B07ZQ3KXDP?th=1" target="_blank" rel="noopener">The above set is from Amazon</a>.<br />Other rivers are available.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38638</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38635</link>
                        <pubDate>Fri, 13 Dec 2024 09:15:33 +0000</pubDate>
                        <description><![CDATA[@jamespa Sorry James, I mis-parsed your sentence there! The towel rail when heated by the heat pump will provide a low level warming / drying action to any towels but the plan we adopted is ...]]></description>
                        <content:encoded><![CDATA[@jamespa Sorry James, I mis-parsed your sentence there! The towel rail when heated by the heat pump will provide a low level warming / drying action to any towels but the plan we adopted is to have the electrical element switch on for a few hours in the evening but, with the valve shut to prevent the heating element having to warm circulating water throughout the system. I might add that I only shut one towel rail valve thus allowing for any expansion to take place without pressure on the rail and plumbing. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38635</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38634</link>
                        <pubDate>Fri, 13 Dec 2024 08:53:09 +0000</pubDate>
                        <description><![CDATA[I think thats what I meant by the suggestion to fit an electric element to a towel rail?]]></description>
<p>@jamespa An alternative is to use a dual fuel towel rail. Regards, Toodles.</p>
<p>I think thats what I meant by the suggestion to fit an electric element to a towel rail?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38634</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38633</link>
                        <pubDate>Fri, 13 Dec 2024 08:48:22 +0000</pubDate>
                        <description><![CDATA[@jamespa An alternative is to use a dual fuel towel rail. Regards, Toodles.]]></description>
                        <content:encoded><![CDATA[@jamespa An alternative is to use a dual fuel towel rail. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38633</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38630</link>
                        <pubDate>Fri, 13 Dec 2024 08:33:30 +0000</pubDate>
                        <description><![CDATA[That is what I originally planned, then I fell back to &#039;ignore and rely on heat from adjacent room and steam when the bath is in use.@
The TRV will indeed prevent any overheating.
Not su...]]></description>
<p>Thanks, we're planning on a large normal radiator. Heat Punk suggests that we need a 1800x600mm K2 radiator for a 45 degree flow temperature, but it's possible I've done it wrong! It's a 2x2.5m room with two outside solid brick walls, and I'm adding 70mm of PIR. I'm assuming that a TRV will prevent the room overheating while we insulate and upgrade the radiators in the rest of the house.</p>
<p>That is what I originally planned, then I fell back to 'i<span>gnore and rely on heat from adjacent room and steam when the bath is in use.@</span></p>
<p><span>The TRV will indeed prevent any overheating.</span></p>
<p><span></span></p>
<p>I had been considering turning the old 35mm copper pipe into a heated towel rail. If I do, it sounds like I should just use an electric element and not connect it to the heating.</p>
<p>Not sure about this!  Personally I would either recycle the pipe or turn it into a sculpture.</p>
<p><span> </span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/paged/2/#post-38630</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/#post-38619</link>
                        <pubDate>Thu, 12 Dec 2024 17:40:34 +0000</pubDate>
                        <description><![CDATA[Thanks, we&#039;re planning on a large normal radiator. Heat Punk suggests that we need a 1800x600mm K2 radiator for a 45 degree flow temperature, but it&#039;s possible I&#039;ve done it wrong! It&#039;s a 2x2...]]></description>
                        <content:encoded><![CDATA[<p>Thanks, we're planning on a large normal radiator. Heat Punk suggests that we need a 1800x600mm K2 radiator for a 45 degree flow temperature, but it's possible I've done it wrong! It's a 2x2.5m room with two outside solid brick walls, and I'm adding 70mm of PIR. I'm assuming that a TRV will prevent the room overheating while we insulate and upgrade the radiators in the rest of the house.</p>
<p>I had been considering turning the old 35mm copper pipe into a heated towel rail. If I do, it sounds like I should just use an electric element and not connect it to the heating.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>RobinBennett</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/#post-38619</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/#post-38578</link>
                        <pubDate>Thu, 12 Dec 2024 09:16:55 +0000</pubDate>
                        <description><![CDATA[One more thought if you are doing a bathroom refurb and planning a heat pump later - towel rails are basically more or less useless for heating when run at the low temperatures heat pumps wo...]]></description>
                        <content:encoded><![CDATA[<p>One more thought if you are doing a bathroom refurb and planning a heat pump later - towel rails are basically more or less useless for heating when run at the low temperatures heat pumps work at.  You may want to address this up front.  Solutions include - fit an electric element in addition, use a standard radiator instead (for example a narrow but tall one), ignore and rely on heat from adjacent room and steam when the bath is in use.  </p>
<p>Regarding feed and return pipe sizing this cheat sheet gives you the numbers, you may wish to take a view.</p>
<p>https://www.heatgeek.com/does-my-pipework-need-upgrading-for-a-heat-pump-with-cheat-sheet/</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/#post-38578</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/#post-38560</link>
                        <pubDate>Wed, 11 Dec 2024 17:14:23 +0000</pubDate>
                        <description><![CDATA[You are right about 35mm, my mistake.
The D2 can certainly go through the wall assuming that the porch doesn&#039;t conflict given the levels (look at the diagram of a discharge to understand)...]]></description>
<p>Just to be clear, our old bath waste pipe was copper, about 35mm OD and 32mm ID, probably from around 1950. I was just querying it because when I looked at plumbing supplies, I couldn't see any listed as 32mm, only 35mm<br /><a href="https://www.bes.co.uk/copper-tube-35mm-x-3m-13595/">Copper Tube - 35mm x 3m - 13595</a><br /><a href="https://www.cityplumbing.co.uk/p/wednesbury-plain-copper-tube-length-35mmx3m-table-x-x035l-3/p/313815">Wednesbury Plain Copper Tube Length 35mmx3m (Table X) X035L-3</a><br />I heard somewhere that 'tube' is measured ID, while 'pipe' uses ID and just wanted to check it was the same thing.</p>
<p>You are right about 35mm, my mistake.</p>
<p>I'll try to clarify the situation for the D2 drain. The airing cupboard is on an outside wall, above our porch and next to some patio doors (yes, it's an unusual old house!) so there's nowhere for a heat pump directly below it. Instead we plan the put the pump around the corner, and would rather run pipes under the floor rather than around the outside. I don't think the D2 needs to be follow the same route. Can the D2 just go through the wall in the airing cupboard, and discharge into the gutter of the porch roof, like the old boiler condensate pipe? (the rain water goes into the foul drain, again probably 1950's plumbing)</p>
<p>The D2 can certainly go through the wall assuming that the porch doesn't conflict given the levels (look at the diagram of a discharge to understand) and of course it doesnt have to follow the same route.  I think many will say you cant discharge directly into a gutter, and you certainly cannot discharge directly into a plastic gutter.  I think discharge into a metal hopper (if there is one) is probably acceptable, but again others may disagree.   You are talking steam and boiling water so safety is paramount. </p>
<p>Some argue that it cant discharge onto a flat roof because the roof material might be damaged.  Given that the discharge rarely if ever occurs, and most flat roof coverings are torched on, I personally struggle with this argument!  There is scope for interpretation and of course different plumbers do have subtly different interpretations.  That would be the advantage of doing the UVC at the same time as the bathroom refurb, when the HP man comes he isn't touching it so doesn't need a say.</p>
<p>The most common ;#'recognised' discharge points are just above ground level with a protective mesh to stop people putting their hands under it, and into a suitable foul drainage system.  The rules on length can get quite restrictive if you need more than a couple of bends, possibly forcing you to 28mm rather than 22mm.  You really do need to research this if you are doing it in advance.  On the other hand, perhaps you dont need to.  Since it <em>can</em> (subject to levels) go out through the wall the HP installer can fit it without involving the bathroom.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/fitting-hp-pipes-in-advance/#post-38560</guid>
