									First time wall mounting an ASHP - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/</link>
            <lastBuildDate>Fri, 12 Jun 2026 20:31:17 +0000</lastBuildDate>
                        <title>RE: First time wall mounting an ASHP</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52263</link>
                        <pubDate>Mon, 10 Nov 2025 20:24:22 +0000</pubDate>
                        <description><![CDATA[what you need to do is everything you can to remove the vibration through the wall, these brackets are very good and allow you to adjust a rear foot to level the bracket tilt, I would add so...]]></description>
<p>Hi all,</p>
<p>I have got the go ahead on a job to move their 5kW Samsung R32 from the floor, up onto a wall. I was planning to use these brackets (<a href="https://www.cityplumbing.co.uk/p/pump-house-type-cbr2-l-2-wall-bracket-540mm-long-arm-140kg-for-air-source-heat-pump/p/235753">Pump House Type CBR2-L 2 Wall Bracket 540mm Long Arm 140Kg For Air Source Heat Pump</a>), but as I mentioned I haven't done so before. Is there anything I should look out for, and what difference would this make on efficiency compared to your standard floor mount?</p>
<p>Thank you in advance</p>
<p> what you need to do is everything you can to remove the vibration through the wall, these brackets are very good and allow you to adjust a rear foot to level the bracket tilt, I would add some  aditional 100Kgs antivibe mounts as well, these can come with an 8mm M/M thread each side and would sit straight inside.</p>
<p>Good luck </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52263</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52248</link>
                        <pubDate>Mon, 10 Nov 2025 17:02:06 +0000</pubDate>
                        <description><![CDATA[@bontwoody Try;
Regards, Toodles.]]></description>
                        <content:encoded><![CDATA[<p>@bontwoody Try;</p>
<p>https://youtu.be/MJ_-QzvLyF0?si=t2FaKB1y0yci8_JH</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52248</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52247</link>
                        <pubDate>Mon, 10 Nov 2025 16:45:00 +0000</pubDate>
                        <description><![CDATA[@toodles Ill have to look that one up &#x1f601;]]></description>
                        <content:encoded><![CDATA[@toodles Ill have to look that one up &#x1f601;]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52247</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52246</link>
                        <pubDate>Mon, 10 Nov 2025 16:32:55 +0000</pubDate>
                        <description><![CDATA[@bontwoody Adam Chapman Heat Geek carried out an interesting experiment using mirrors (no smoke) to reflect sunlight back at the pump. Can’t remember which but it is a YouTube presentation o...]]></description>
                        <content:encoded><![CDATA[@bontwoody Adam Chapman Heat Geek carried out an interesting experiment using mirrors (no smoke) to reflect sunlight back at the pump. Can’t remember which but it is a YouTube presentation of his. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52246</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52239</link>
                        <pubDate>Mon, 10 Nov 2025 15:45:33 +0000</pubDate>
                        <description><![CDATA[Im no expert, but if you are raising the heat pump, the air should be warmer than down on the ground and so it should improve its efficiency slightly.]]></description>
                        <content:encoded><![CDATA[<p>Im no expert, but if you are raising the heat pump, the air should be warmer than down on the ground and so it should improve its efficiency slightly.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52239</guid>
                        <title>First time wall mounting an ASHP</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52238</link>
                        <pubDate>Mon, 10 Nov 2025 15:37:35 +0000</pubDate>
                        <description><![CDATA[Hi all,
I have got the go ahead on a job to move their 5kW Samsung R32 from the floor, up onto a wall. I was planning to use these brackets (Pump House Type CBR2-L 2 Wall Bracket 54...]]></description>
                        <content:encoded><![CDATA[<p>Hi all,</p>
<p>Thank you in advance</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Renewables345</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/first-time-wall-mounting-an-ashp/#post-52238</guid>
Served from: renewableheatinghub.co.uk @ 2026-06-12 21:31:17 by W3 Total Cache
