									EDLQ016CAV3 - Commissioning Menu - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/edlq016cav3-commissioning-menu/</link>
            <lastBuildDate>Sun, 08 Nov 2026 01:39:46 +0000</lastBuildDate>
                        <title>EDLQ016CAV3 - Commissioning Menu</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/edlq016cav3-commissioning-menu/#post-20297</link>
                        <pubDate>Wed, 12 Jul 2023 21:14:14 +0000</pubDate>
                        <description><![CDATA[Hi all,
Its getting close to the end of the heat pump install (saga -  we are now 3.5 years down the line!)
When i look in the manual it says there is a commissioning menu which can test a...]]></description>
                        <content:encoded><![CDATA[<p>Hi all,</p>
<p>Its getting close to the end of the heat pump install (saga -  we are now 3.5 years down the line!)</p>
<p>When i look in the manual it says there is a commissioning menu which can test actuators or the system as a whole, the only entry I have under that menu is "Air Purge".</p>
<p>If i run air purge (and purge the air), the commissioning menu disappears completely.</p>
<p>I have turned off the DHW schedule and Heating set to OFF as it says to do in the manual but I still don't get the Commissioning menu.   Is it a one time use thing?  I was hoping i could test individual components such as the BUH, Booster without heating the house or cylinder up.</p>
<p>thanks in advance</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>saf1973</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/edlq016cav3-commissioning-menu/#post-20297</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 01:39:46 by W3 Total Cache
