									Ecodan Wireless Controller changing the room temperature target itself - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/</link>
            <lastBuildDate>Mon, 16 Nov 2026 09:52:22 +0000</lastBuildDate>
                        <title>RE: Ecodan Wireless Controller changing the room temperature target itself</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36407</link>
                        <pubDate>Thu, 24 Oct 2024 12:19:59 +0000</pubDate>
                        <description><![CDATA[Thanks all for your suggestions and input. I&#039;m pretty certain no schedule has been set so I am going to try changing the batteries as @westkent suggested as will report back if it solves the...]]></description>
                        <content:encoded><![CDATA[<p>Thanks all for your suggestions and input. I'm pretty certain no schedule has been set so I am going to try changing the batteries as @westkent suggested as will report back if it solves the problem.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>HJD</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36407</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36402</link>
                        <pubDate>Thu, 24 Oct 2024 10:50:34 +0000</pubDate>
                        <description><![CDATA[had the same issue.
Strange as it may sound I changed the batteries in the wireless controller.
Bobs your uncle]]></description>
<p>Has anyone with the Ecodan Wireless controller experienced it changing the target room temperature itself. Mine has happily sat at 18.5 degrees for all of the last 12 months. However twice in the last week it has automatically changed itself to 29.5 degrees. This has caused complete chaos with the flow temps and cycling!</p>
<p>Any ideas? I am wondering whether the batteries might be going.</p>
<p>had the same issue.</p>
<p>Strange as it may sound I changed the batteries in the wireless controller.</p>
<p>Bobs your uncle </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Westkent</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36402</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36391</link>
                        <pubDate>Thu, 24 Oct 2024 08:00:58 +0000</pubDate>
                        <description><![CDATA[This definitely sounds like a scheduling issue. Our iBoost from a few years ago had a random immersion boost twice a week when it was fitted, which spiked our electricity use unnecessarily, ...]]></description>
                        <content:encoded><![CDATA[<p><span>This definitely sounds like a scheduling issue. Our iBoost from a few years ago had a random immersion boost twice a week when it was fitted, which spiked our electricity use unnecessarily, and we have no idea why it was set like that. We found and removed it. <br /></span></p>
<p><span>I’d suggest you have a look at the schedule and see if there’s a random boost or off-peak setting activated. These can sometimes get overlooked.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36391</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36382</link>
                        <pubDate>Wed, 23 Oct 2024 22:21:32 +0000</pubDate>
                        <description><![CDATA[Strange! Indeed perhaps a schedule on the physical controller or MELCloud?Or could it be that the heat pump is by itself switching to fixed flow temp mode and displaying the flow temperature...]]></description>
                        <content:encoded><![CDATA[<p>Strange! Indeed perhaps a schedule on the physical controller or MELCloud?<br />Or could it be that the heat pump is by itself switching to fixed flow temp mode and displaying the flow temperature.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36382</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36371</link>
                        <pubDate>Wed, 23 Oct 2024 17:22:49 +0000</pubDate>
                        <description><![CDATA[Mine has not missed a beat since installation in 2019 and is still using the original set of batteries.  Have you set any form of schedule in Melcloud?]]></description>
                        <content:encoded><![CDATA[<p>Mine has not missed a beat since installation in 2019 and is still using the original set of batteries.  Have you set any form of schedule in Melcloud?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36371</guid>
                        <title>Ecodan Wireless Controller changing the room temperature target itself</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36367</link>
                        <pubDate>Wed, 23 Oct 2024 16:29:35 +0000</pubDate>
                        <description><![CDATA[Has anyone with the Ecodan Wireless controller experienced it changing the target room temperature itself. Mine has happily sat at 18.5 degrees for all of the last 12 months. However twice i...]]></description>
                        <content:encoded><![CDATA[<p>Has anyone with the Ecodan Wireless controller experienced it changing the target room temperature itself. Mine has happily sat at 18.5 degrees for all of the last 12 months. However twice in the last week it has automatically changed itself to 29.5 degrees. This has caused complete chaos with the flow temps and cycling!</p>
<p>Any ideas? I am wondering whether the batteries might be going.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-wireless-controller-changing-the-room-temperature-target-itself/#post-36367</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-16 09:52:22 by W3 Total Cache
